Mirage PI-170DTLA
  • giovanni-oliveri
    • Mar 2013
    • 4
    • Italy
    Mirage PI-170DTLA
    Hello I have a Belinea 1905 S1 19" LCD monitor and the screen is going off after about 1 minute.
    The green led on the front panel stay on, and if I turn the monitor off and turn back on it will work for other minute or so.
    The power supply board model is Mirage Electronics PI-170DTLA Rev:A
    I already have change all the capacitors on this board and nothing have change (except for the hissing sound that have disappeared).
    Please help
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Mirage PI-170DTLA
    2 things I want you to check if it is possible.
    If you have spare CCFL lamps, that are working 100% sure, try using those. If they do not turn off after a couple of minutes, your lamps are not in a good shape and atleast one of them needs replacing.
    For the second test you need a multimeter.
    Turn the multimeter in the area that reads up to 2k (2000) ohms. Find out where the transformer´s secondary pins are and see what the resistance between them are. Do it with both of the transformers and tell us the results.
    • giovanni-oliveri
      • Mar 2013
      • 4
      • Italy
      Thank you I will check those asap.
      Ciao
      • sabre504
        • May 2010
        • 449
        • United Kingdom
        Schematic
        • giovanni-oliveri
          • Mar 2013
          • 4
          • Italy
          Ok I got some finding: after adjusting the brightness and contrast around 20 (max 100) the monitor is working great, no flickering no turning off no hissing sound. I have tested for about 3 hrs and is ok. I guess the CCLF lamps are getting weaker and the inverter is cutting power because of that.
          I hope this could help some one with a similar problem.
          Thank you.
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            That is just a temporary fix. I would recommend you to take care of the problem in the near future.
              by momaka
              03-15-2023, 10:17 PM
            • wattage
              AOC AG493UCX 49-inch monitor - Firmware request
              by wattage
              Hello Badcaps Community,
              The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
              07-13-2025, 04:41 PM
            • ant3202
              HP 27es - LED monitor - Monitor Flashing On - Off
              by ant3202
              Hi Everyone
              Lately I am experiencing the deja-vu incident on one of the led monitor like this.
              https://www.badcaps.net/forum/troubl...lashing-on-off
              The monitor is HP 27es LED Monitor
              https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
              The monitor will randomly blackout and display no signal and will recover again.
              Sometimes need to power and off again to restore the display but...
              03-20-2025, 07:30 PM
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
