HP 1502 (P9617D) pulsing on and off with bad capacitors
  • barefoot
    • Aug 2008
    • 3
    Re: HP 1502 (P9617D) pulsing on and off with bad capacitors
    Thanks a lot for this thread. I also had the exact same board & now works great. Had 3 blown & 4 fat caps. The diode was cooked and turned to powder when I tried to remove, I replaced it with a 1 watt'er.
    • geoffbpl
      • Aug 2008
      And another one to your credit. In my case the zener survived and seems to operate "as advertised", despite having scorched the board. Many thanks for great info.
      • nrgeek
        • Oct 2008
        where to buy caps online ?
        • Scenic
          o.O
          • Sep 2007
          • 2641
          https://www.badcaps.net/forum/showthread.php?t=613
          • joe90
            • Nov 2008
            • 3
            si funciona le cambie los 7 filtros y ya funciona. gracias
            • bilby
              • Dec 2008
              #26
              Many thanks for the useful information here. I picked up a pair of HP1502 monitors at a HAM auction a week ago hoping I could get one working. The smaller caps were bulging in both so after a quick replacement, the first of the two refused to come to life. I couldn't find any schematics so took to tracing the circuit. The voltages of Zener diodes just didn't make any sense, so I decided to reverse the 7.5V SMD Zener on the hunch that a prior attempt at repair had gone wrong.
              I now have two working hp1502 monitors!
              • jadeboi
                • Feb 2009
                #27
                The above solution still works on HP1502 LCD monitor (circa 2004).
                Replaced caps with what was available at Jaycar (Australia), matching Japlytic's values in the first post. Took about 20 minutes. Worked immedialey. One more LCD saved from the rubbish bin.
                • advokit
                  • Mar 2009
                  #28
                  Wow thanks for this! Got given 2 x HP1502 monitors for free and just fixed one using the info from this thread. Now to fix the other one.
                  Thanks heaps.
                  • Demix
                    • Jul 2009
                    • 72
                    #29
                    wow great thread! my brothers monitor started showing the signs of blown caps as it wouldnt turn on and at the time i wasnt really savy with things like this so we just dumped it away in a cupboard but recently i found myself in need of another monitor so i pulled it out and started tinkering with it, i opened it up to find slightly puffy caps which needed changing and also a scorch mark on the board, thing is in this thread ive seen the same scorch mark on all of the pics posted, its right next to C933 and the heatsink looking thingy, (picture attatched) my caps are on the way in the post so i will be able to replace them soon but does anyone know if changing the caps will be enough? its just the burn is in a really random place, thanks in advance guys =] also awesome community here ^^ i stumbled across this place while looking for capacitors
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Stop and take a breath once in a while.
                      Scorch marks are common - they are caused by lack of a heat sink on the inverter driver transistors.
                      At a MINIMUM replace all bulging caps. Even smarter, replace any caps from manufacturers on the bad caps list . Best of all, replace all electrolytic caps (except the big 450V electrolytic) in the power supply. Replacing all caps will cost about $10 for parts.
                      PlainBill
                      • Demix
                        • Jul 2009
                        • 72
                        #31
                        Thanks a lot for the help. =]
                        Also my apologies for the lack of punctuation in my previous post. Im just a little flustered because the laptop im using is playing up at the moment. The processor is running at over 86'c :S . It actually burns my wrists if I take too long typing hehe :P, really not a good thing.
                        Also thanks, i have ordered enough capacitors to replace all of the ones on the list =] once again thanks a lot for the help. When I recieve and replace the caps I will post again with my results.
                        • Demix
                          • Jul 2009
                          • 72
                          #32
                          Hey Again, as ive never done anything like this before i just wanted to check if the caps i have chosen ( based on the specs from the first post of this thread) will be okay hehe. here are the ones ive done so far:
                          See the Attatchments, then these are the other ones i will be replacing later today.
                          C922, C925, C924, C926, C929, C930, C932, C933 - With FK radial elec cap 1000uF 16V - RS Stock Number - 571-656
                          And
                          C201 - With FC radial elec cap 1000uF 25V - RS Stock Number - 571-981
                          This is the site i bought them from -
                          http://uk.rs-online.com/web/
                          Thanks a lot in advance for your help guys =] sorry im such a newbie at all this.
                          • PlainBill
                            • Feb 2009
                            • 7034
                            They should work. At first I thought you had a problem. In the US Panasonic FK series is a surface mount type, but the link at R-S shows it is a through hole type.
                            PlainBill
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              - Deleted -
                              • ASUS ROG Maximus IX Code
                              • Intel Core i5-7600K 3.8GHz
                              • Windows 10 Pro x64
                              • GeForce GT1050
                              • renegade_00
                                • May 2007
                                • 9
                                #35
                                I just wanted to thank all of you guys who contributed to this thread. Because of you awesome people, I was able to save my HP 1502 monitor, and for only about $8. Keep up the great work!
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  Congratulations
                                  • GeForce GT1050
                                  • Demix
                                    • Jul 2009
                                    • 72
                                    #37
                                    Just a quick post to say the screens now working perfectly just giving it a test to make sure its not going to die within an hour or so, thank you so much for this guys!
                                    • johnboy183
                                      • May 2008
                                      • 119
                                      #38
                                      I have just picked one of these up at the local recycling centre (free) and find it has the all the usual bulged caps identified in this thread but on replacing them find I am left with a working backlight etc but no video (ie white screen).
                                      Funnily enough despite the bulged and leaking caps it was working exactly the same way before I replaced all the duff caps!. After much investigating I became convinced it was a screen panel even though the fuse was intact. However I put the screen in a Dell I have and it fired up lovely! so the screen panel seems to be excluded.
                                      On further testing I noticed the zener diode (ZD 904) mentioned in the thread was running very hot and the board getting more and more scorched by the minute and a nice burning smell! On inspection the diode is now covered in soot and sticky. Any views on this and anyone tell me if the zener could be the cause of the white screen? (thought it might be as the voltages measured at the pins to the video board seem to fluctuate wildly on measuring and at best one shows 7v, one shows 3.3v and one shows 5v - none show 12v)
                                      Thoughts and wisdom appreciated!
                                      • nursiti2009
                                        • Jan 2011
                                        #39
                                        i have LCD HP1502. screen continuous flicker and indicator power lamp too. I try replace All capacitor 470uf/16v (6pcs), 1000uf/16v (1pcs) and 1500uf/25v (1pcs). and the problem same.
                                        what can i do again? please help me.... fix my problem.
                                        • EGuevarae
                                          • Nov 2008
                                          • 1336
                                          Replaced with what?
                                          Screen flickering might be bad lamp(s)
                                          • GeForce GT1050
                                          • speggio91
                                            820-00165 pulsing and stuck at S5
                                            by speggio91
                                            Hello everyone!
                                            I have this board that got slightly water damanged and it is stuck at S5 state. It pulses once every 5 seconds.
                                            When connected the magsafe 2 to the bench psu, the current goes from 0.02A to 0.10A when is pulsing.
                                            When using the genuine magsafe 2 charger, the light turn on and it became green and then amber. The fan is not spinning.
                                            When I tried the SMC bypass mode, the fan spins a quarter every 5 seconds and the pulsing is still present every time the fan spin.
                                            The pulses are present in the CPU Vcore rails on L7320 and L7310....
                                            11-25-2023, 11:25 AM
                                          • MobileXT
                                            MBA 13 2020 820-01958 Pulsing 5V_G3S
                                            by MobileXT
                                            I have a MBA 13" 2020 820-01958 that was pulsing on 5V_G3S and P1V8_G3S power Rail. Also pulsing on the enabled PIN on U7650 PIN4. Pulsing on P5VG3S_EN R7613 PIN 1. Anybody has the same problem? any idea was causing the power rail pulsing. I don't see shorted on the board. Thanks
                                            09-13-2022, 08:34 PM
                                          • ronyan
                                            Macbook Air 820-00165 board power pulsing twice and missing PM_SLP_S4_L
                                            by ronyan
                                            I have a 820-00165 board that is power pulsing twice going from drawing 34mA up to ~350mA then back down to 34. No fan spin. It is missing the PM_SLP_S4_L signal. As I have no previous experience with this particular problem, I've been measuring a lot and have already replaced U1900 and U1950. I've also replaced R5513 near the SMC that looked corroded. The behavior of the power pulsing twice has not changed.
                                            I've watched some of Louis' youtube videos on the issue and have checked the SPI resistors for continuity and they are good, probe points are also excellent, no signs of corrosion....
                                            02-11-2023, 05:30 PM
                                          • chth96
                                            Can I replace KME cap with Samxon GF cap?
                                            by chth96
                                            Hello.
                                            I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                                            Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                                            I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                                            04-17-2024, 07:11 AM
                                          • groomit
                                            Meta Quest 2 not turning on - pulsing amp draw
                                            by groomit
                                            Hi
                                            Following problem regarding a Quest 2 I got with broken USB port and "not turning on".
                                            After replacing the USB/Audio port + cable the Device still refuses to turn on. A USB multimeter is showing a pulsing amp draw ranging from 70 mA to 1.2 A and back.
                                            All obvious caps measured good (no short).
                                            A visual thermal inspection showed two ICs glowing up also pulsing.
                                            One was a Qualcomm PMIC PM8150B which I suspected to be the culprit. But replacing it with a china-replacement made no difference.
                                            The other one I can't identify. It looks like...
                                            04-10-2024, 03:08 PM
