I have a Tatung LCD monitor that does nothing at all. No LED on power button nothing at all. It had some bad caps which I replaced and that did nothing. I hooked the back lights to a different brand power supply and the display itself works fine. With power plugged in I have voltage on the large yellow transformer on the plug side nearest the big filter cap. Around 60v. I would think that mean the bridge rectifier is fine as well as filter on the output side of the transformer I have nothing. No voltage at all. I checked the resistance on the output and it is roughly 1 ohm. Would that indicate the transformer is dead? It does not seem to have been hot. There is no writing on the transformer to determine a proper replacement. Am I on the right track? Are these transformers some what universal? Any idea what I could replace it with? I would be tempted to buy a board but I can't seem to locate one. It is a LM004 Rev 3.
Help with Tatung TLM-1905 LCD no power at all
Re: Help with Tatung TLM-1905 LCD no power at all
Have you checked the fuse at F1,?
Check for continuity - post result in ohms
Check voltage on each side Black probe on ground screw probe each side with red
Meter on 200vDCPlease upload pictures using attachment function when ask for help on the repair
When troubleshooting consumer electronics, one of the most important voltages to look for is standby DC voltage. This is typcially 5V DC.
In consumer electronics, we rarely need to measure AC.
List pin number and DC voltage for the connector like so (black probe goes on a ground screw on chassis).
pin 1 = 0.0
pin 2 = 5.0--- begin sig file ---
--- end sig file ---
See budm's lcd troubleshooting guide in my sig file link in the above post for the basics.--- begin sig file ---
Originally posted by selldoor View PostI didnt say but you need to post result of voltage test.
Between the BIG cap and the transformer there is a small cap - what voltage is on that meter on vdc200 probe on each leg jointPlease upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostBetween the BIG cap and the transformer there is a small cap - what voltage is on that meter on vdc200 probe on each leg joint
Also testing with meter on 200 vdc the area in orange is the only area of the board with any power at all.Last edited by jbshocks; 02-03-2013, 02:29 PM.
Originally posted by Rtech View PostBut this ground is NOT the same as the other one you used.You must measure across the small cap itself,Black to the side where the stripe, is red to the other side.
Provided that is the Start up cap !! then you need to identify the part code written on U101,on the bottom of the board, as this looks to be the SMPS chip,you then need to find the datasheet for that,see what pin that cap goes to etc.Also there should be a diode connected to the positive side of that cap,the other side of the diode going to the transformer ??
FYI, found this thread. https://www.badcaps.net/forum/showthread.php?t=14042 Same power supply same symptoms. I tested pin 5 to 7 nothing. in fact tested pin 5 to all pins. Only pin 3 was non zero and fluctuated between .8 and .9v. Unfortunately no resolution was posted.
At first look at the datasheet, then 15V DC needed between 5 and 7,which is the same as across the cap,and you have nothing.You need to check the diode connected to the +ve side of the cap, undo one end and check either with resistance or diode test on the meter...POWER OFF for this.You can replace the cap and try that as well, otherwise as these transformers do not usually fail...I have never seen one fail..you would need to replace the chip I suspect.
The required start-up current is typically only 5uA. This
ultra-low start-up current allows designers to supply the
start-up power required by the SG384xG using a
high-resistance and a low-wattage start-up resistor.Thats from the datasheet,so on initial switch on some current is drawn from the Rectifier Bridge to the VCC Pin to start
off the sequence to get the chip running.If the chip is faulty then you could get exactly the symptoms you have.
