Benq fp931 q9t3
  • mig.paiva
    • Portugal
    Benq fp931 q9t3
    I have a Benq 19" that does not start neither the Led lights.
    I checked the Power Board, and not seen swollen capacitors. Apparently voltages are OK. I have 5V (4.9 V) and 3.3 V (3.28 V) to enter the video card.
    I measured the PW_SW signal entering the pin 2 of IC Flash MTV312MV64 which is 3.3 V and when I press the power switch it goes to 0v. I also measured the reset signal that is 0v, it's correct? The LCD shows no sign of life and not try to start....
    I do not have much experience in repairing LCD however it seems to me that this IC MTV312MV64 works as bios/rom lcd ...
    can someone give a hint where to start measuring and what should I measure?
    I have the service manual with schematics for those who need it. How can I upload?
  • Rtech
    • Jul 2010
    • 1095
    Re: Benq fp931 q9t3
    measure the BL _On signal from the video board as you switch on,it should go to approx 3v..it may be called on/off.What you could also do..is WITHOUT the video board plugged in,just apply mains voltage to the Power board, plug in the backlights,and apply 3v from a battery between the on/off and a Gnd pin, and see if the lamps light.If you have not got a battery then a 1kΩ resistor from the 5v to the on/off will suffice.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Re: Benq fp931 q9t3
      If the file is not too big use the manage attachments button, which is found by clicking "go advanced" under quick reply.
      • mig.paiva
        • Portugal
        Re: Benq fp931 q9t3
        The service manual of BENQ FP931 - Q9T3
        • meyerf34
          • Apr 2013
          Re: Benq fp931 q9t3
          Thanks for the service manual!
          My FP931's buttons don't work properly anymore. But it's not a dry joint on the the switch-board (that I checked out by resoldering all of the buttons), but obviously something from the controller board. (Alas, I could not make out any dry joints or busted components there.)
          If you power the monitor up (insert a power cable) it will turn on (LED goes green) and work properly, but not react to any button (menu etc.). But strangely, once it enters energy saving mode (turns off, led goes yellow) you can turn it on and off with the ENTER-button (not ON/OFF-button though).
          So it's not really a big issue, but a bit of a problem if you have to calibrate it etc.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            Re: Benq fp931 q9t3
            hi meyerf are your boards the same as the q9t4 in this post
            https://www.badcaps.net/forum/showthread.php?t=27988
            • meyerf34
              • Apr 2013
              Re: Benq fp931 q9t3
              Hm. It's not the same problem.
              And the Q9T4 (another 19" TFT) seems to be the successor of the FP931, so it's most likely it doesn't have the same circuit-boards.
              But thanks for the link!
              • robrock1
                • Jul 2013
                • 129
                • Ghana
                Re: Benq fp931 q9t3
                The Problem is from the IC myson mtv312mv64, it needs to be reprogrammed! I Have the same problem, i need the firmware and guide how to flash with isp. I am using willem eprom programmer!
                • seppde
                  Benq Zowie XL2540K / Power board failure / 6Pin-SOP-Chip identification
                  by seppde
                  I've got a Benq power board of a XL2540K monitor which suffered from a power cut and is since defective / won't turn on. It's got obvious defects, some blown resistors, some burning around the drain pin of a MOSFET...
                  ... and some 6-pin IC I struggle identifying, that is driving said MOSFET.
                  The IC is labeled as IC601, so someone with a circuit schematic could probably identify it really quick, unfortunately I can't find the schematics.
                  In other power boards of Benq for which I did find the schematics, IC601 is an 8-pin NCP1200 PWM controller - I suppose...
                  02-09-2024, 05:19 AM
                • AJ847.63e
                  BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                  by AJ847.63e
                  Hi All.
                  Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                  The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                  09-18-2023, 06:42 PM
                • ChatBTC
                  Benq EX3501R
                  by ChatBTC
                  Hi!
                  I am new to this site, and found it via LLM ChatGPT.
                  I got a BenQ Ex3501R monitor which i have had for a while now, it works pretty good until recently, it struggles to turn on, i can see the purple welcome screen is shown for a brief time before it vanish again, usually it stays on for a couple of seconds before the main computer screen is shown, but image is still kept black, before i just had to turn it off and on a few times and that would leave it on, but now it takes ever longer to stabilize the image on the screen, ocasionally i can see the computer desktop...
                  01-24-2025, 08:49 PM
                  BenQ JoyBook S52 S53 Laptop Schematic
                  Quanta ED3...
                  11-01-2024, 02:03 PM
                  BenQ S72 Laptop Schematic
                  Inventec Grasshopper Rev 3.0...
                  11-01-2024, 07:23 AM
