I have a Problem on my 21 ' LCD monitor.
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Hello to all Badcaps Forumers.
    I have a 21' Inch lcd Monitor. The Problem is if i Turn On the Power Switch have power and Have Display and Light. But after 3 sec. The Backlight has been off or No lights. double check have display but no light(backlight)
    I Do first in Trouble Shoot
    replace a New Vga Cable no luck.
    i open and i check the board and Try to Re solder all...no luck same as Problem
    Other Hints. Thanks
    There is my Board
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: I have a Problem on my 21 ' LCD monitor.
    Make? model? pictures?
    https://www.badcaps.net/forum/showthread.php?t=10419 start at post 19
    • jetadm123
      • 2169
      Photos don't show up properly.
      • lorins_core
        BlackSmith
        • Dec 2012
        • 551
        • Philippines
        [QUOTE=lorins_core;300878]Hello to all Badcaps Forumers.
        Other Hints. Thanks
        There is my Board
        [/IMG]
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          Here the Picture
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            sorry friend I already to do that. i not hopeless i think they have Solution.
            i check all Caps and I replace all. Diode or Transistor or IC But I dont Know who is The Bad....
            Help...
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              OK so what are the results of the tests you have done?
              What are the resistances of the secondary windings on the inverter transformer.
              • lorins_core
                BlackSmith
                • Dec 2012
                • 551
                • Philippines
                [/IMG]
                here a pic model is codegen. although you have a schematic diagram...
                • lorins_core
                  BlackSmith
                  • Dec 2012
                  • 551
                  • Philippines
                  Follow Up... Pls
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    We are waiting for the results of the testing you have done from the
                    tests in the 2 seconds to black guide.
                    • Askic
                      Problem with monitor DS-D5022QE-B
                      by Askic
                      Hello to all,
                      I have a problem with monitor that is delivered together with CCTV system.
                      The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
                      I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
                      05-31-2023, 03:14 AM
                    • CptChronic
                      Samsung LU32J590UQUXEN Monitor display problem
                      by CptChronic
                      I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                      Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                      But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                      04-24-2023, 04:33 PM
                    • tmhobadcap
                      LG 24MP56HQ-P Monitor Backlight problem?
                      by tmhobadcap
                      I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
                      Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
                      I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
                      10-13-2021, 01:52 PM
                    • tmhobadcap
                      by tmhobadcap
                      10-12-2021, 01:43 PM
                    • Phil Stasik
                      Pioneer PRO-FHD1 Elite Plasma Monitor Start-Up Problem
                      by Phil Stasik
                      Pioneer Pro-FHD1 Elite. Failure to power on.
                      I'm new to this awesome forum, and have been reading like mad, but have not seen the answer to my challenge.
                      We bought this Panasonic plasma monitor 16 years ago and it has never been serviced, so all parts are original, and the unit has never malfunctioned -- until about a month ago. The system fails to power on. At first (a month ago) this happened rarely. We learned to unplug for a few minutes to drain the caps, then re-plug, and the monitor would start normally. Now, we plug-in, turn on the main power switch, and the...
                      01-19-2023, 01:22 AM
