I have an Acer V223w that just started acting strangely. It works fine for a while, then just shuts off. No display, no power light, but the PC still detects it as connected. If I disconnect the power cable for 5 minutes or so, then plug it back in, it will work just fine for a while, then it shuts off again. I was really hoping to find an obviously bad cap when I opened it up, but no such luck. Attached are pictures of the boards.
Acer V223w
Re: Acer V223w
Perhaps it's overheating? It may have an automatic thermal shutoff when the temperature exceeds a certain point. Have you noticed it shut down any sooner on warm days, or later on cool ones? Does the monitor feel warm or hot to the touch before shutting down?
EDIT: I just did a little research and learned that the issue is often caused by an unstable DC input, which is caused by problematic DC filter caps. You may not be able to see the problem, but it is most likely the reason for the issue. You may be better off to just replace the filter caps, even though you don't see the problem.Last edited by DerStrom8; 12-28-2012, 03:40 PM. -
Re: Acer V223w
A cap doesn't have to be bulged or swollen to be bad. You didn't say how long the monitor stays on. If it's longer than a few minutes, try heating the board with a hair dryer to accelerate the shutdown process. This will help isolate the area that may be causing the problem.Comment
Re: Acer V223w
Sorry I didn't give enough detail. The monitor was purchased as a refurb - as-is, no warranty. It worked fine for the first few months. It's no warmer than the other monitor that it is sitting next to. When it is working, it stays on for anywhere from 5 minutes to 30 minutes. The longer the power is disconnected, the longer it will work when it is plugged back in.
Any suggestions as to which specific caps to replace? It may be a few days before I can try the hair dryer trick on it.Comment
Re: Acer V223w
You might get away with the 4 elite caps- we would generally recommend replacing all
except the Big cap BUT what make are caps with 1041 and 1044 on - the ends look like panasonic?? and if replaced when refurbished should be good.
The idea of the hairdryer is partly to locate failing caps.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Acer V223w
Hermei are not great either - replace as well.
And the ky
Replace all except the big one will give a good start to any repair.
You should use good quality caps like Panasonic FM or FR
Rubycon or nichiconLast edited by selldoor; 12-30-2012, 03:49 AM.Please upload pictures using attachment function when ask for help on the repair
Re: Acer V223w
Thanks for helping a girl out. I finally got the replacement caps from mouser and installed them today. The monitor has been working great ever since.
I may have to take apart my Acer AL2016W soon. It has been making an annoying high pitched noise. I was able to make it go away by turning down the brightness.Comment
Re: Acer V223w
Well done - thanks for reporting back - i would do the 2016 sooner rather than later.
Putting it off puts more pressure on other components making what could be a simple cap replacement into a nightmare, as well as more expensive.Please upload pictures using attachment function when ask for help on the repair
Re: Acer V223w
Well, I guess I reported back too soon. It was working great for a few days. Now it's dead again. It will display the Acer logo, then the power LED goes out and there is no display. If I unplug the power cord and immediately plug it back in, the power LED will flicker on for a brief moment. If I leave the power cord unplugged for a long time, when I plug it back in, the monitor will power on just long enough to display the Acer logo and then go out again. Any other suggestions as to what to do next? I do have a Fluke 179 multimeter that I can use to test parts with. Does anyone want a picture of the board after I replaced the caps?Comment
Re: Acer V223w
Hi - Yes please repost straight on front and back pictures.
please post good clearpictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
https://www.badcaps.net/forum/attach...7&d=1280167246
https://www.badcaps.net/forum/attach...6&d=1280167246
https://www.badcaps.net/forum/attach...4&d=1280167246Please upload pictures using attachment function when ask for help on the repair
--- begin sig file ---
--- end sig file ---Comment
Re: Acer V223w
@RC - Thought that would grab your eyePlease upload pictures using attachment function when ask for help on the repair
Re: Acer V223w
i have the same exact monitor. Same pics as the one the guy showed in his first post. I replaced all the caps on the power supply board except one which was a small one........not sure of the rating but i think it was a 25uf / 35v caps.
Now when i turn on the monitor..........its white......the power led comes on turns blue then screen goes white.......
any ideasComment
Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Re: Acer V223w
what's thatLess jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
This specification for the Acer Aspire Aspire 9920 G-933G64HN can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Aspire 9920 G-933G64HN boardview and Aspire 9920 G-933G64HN schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 05:27 AM
This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-07-2024, 05:00 AM
This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:00 AM
This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-07-2024, 04:10 AM
This specification for the Acer Swift SF314-511-55X6 + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF314-511-55X6 + Pack Gold Acer 14'' boardview and SF314-511-55X6 + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 03:10 AM
- Loading...
