Acer V223w
  • wcoyote
    • Dec 2012
    • 14
    Acer V223w
    I have an Acer V223w that just started acting strangely. It works fine for a while, then just shuts off. No display, no power light, but the PC still detects it as connected. If I disconnect the power cable for 5 minutes or so, then plug it back in, it will work just fine for a while, then it shuts off again. I was really hoping to find an obviously bad cap when I opened it up, but no such luck. Attached are pictures of the boards.
  • DerStrom8
    Techie
    • Dec 2012
    • 76
    Re: Acer V223w
    Perhaps it's overheating? It may have an automatic thermal shutoff when the temperature exceeds a certain point. Have you noticed it shut down any sooner on warm days, or later on cool ones? Does the monitor feel warm or hot to the touch before shutting down?
    EDIT: I just did a little research and learned that the issue is often caused by an unstable DC input, which is caused by problematic DC filter caps. You may not be able to see the problem, but it is most likely the reason for the issue. You may be better off to just replace the filter caps, even though you don't see the problem.
    • jetadm123
      • 2169
      Re: Acer V223w
      A cap doesn't have to be bulged or swollen to be bad. You didn't say how long the monitor stays on. If it's longer than a few minutes, try heating the board with a hair dryer to accelerate the shutdown process. This will help isolate the area that may be causing the problem.
      • wcoyote
        • Dec 2012
        • 14
        Re: Acer V223w
        Sorry I didn't give enough detail. The monitor was purchased as a refurb - as-is, no warranty. It worked fine for the first few months. It's no warmer than the other monitor that it is sitting next to. When it is working, it stays on for anywhere from 5 minutes to 30 minutes. The longer the power is disconnected, the longer it will work when it is plugged back in.
        Any suggestions as to which specific caps to replace? It may be a few days before I can try the hair dryer trick on it.
        • selldoor
          Slow Learner
          • 7870
          Re: Acer V223w
          You might get away with the 4 elite caps- we would generally recommend replacing all
          except the Big cap BUT what make are caps with 1041 and 1044 on - the ends look like panasonic?? and if replaced when refurbished should be good.
          The idea of the hairdryer is partly to locate failing caps.
          • wcoyote
            • Dec 2012
            • 14
            Re: Acer V223w
            The 1041 and 1044 caps are HERMEI. All the other caps are Elite, except for the 22uf next to the big cap - it looks to be KY.
            • selldoor
              Slow Learner
              • 7870
              Re: Acer V223w
              Hermei are not great either - replace as well.
              And the ky
              Replace all except the big one will give a good start to any repair.
              You should use good quality caps like Panasonic FM or FR
              Rubycon or nichicon
              • wcoyote
                • Dec 2012
                • 14
                Re: Acer V223w
                Thanks for helping a girl out. I finally got the replacement caps from mouser and installed them today. The monitor has been working great ever since.
                I may have to take apart my Acer AL2016W soon. It has been making an annoying high pitched noise. I was able to make it go away by turning down the brightness.
                • selldoor
                  Slow Learner
                  • 7870
                  Re: Acer V223w
                  Well done - thanks for reporting back - i would do the 2016 sooner rather than later.
                  Putting it off puts more pressure on other components making what could be a simple cap replacement into a nightmare, as well as more expensive.
                  • wcoyote
                    • Dec 2012
                    • 14
                    Re: Acer V223w
                    Well, I guess I reported back too soon. It was working great for a few days. Now it's dead again. It will display the Acer logo, then the power LED goes out and there is no display. If I unplug the power cord and immediately plug it back in, the power LED will flicker on for a brief moment. If I leave the power cord unplugged for a long time, when I plug it back in, the monitor will power on just long enough to display the Acer logo and then go out again. Any other suggestions as to what to do next? I do have a Fluke 179 multimeter that I can use to test parts with. Does anyone want a picture of the board after I replaced the caps?
                    • selldoor
                      Slow Learner
                      • 7870
                      Re: Acer V223w
                      Hi - Yes please repost straight on front and back pictures.
                      please post good clearpictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                      Examples of what is needed
                      https://www.badcaps.net/forum/attach...7&d=1280167246
                      https://www.badcaps.net/forum/attach...6&d=1280167246
                      https://www.badcaps.net/forum/attach...4&d=1280167246
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Re: Acer V223w
                        See my sig file below for budm's basic lcd troubleshooting guide (called LCD TV and Monitor Troubleshooting Guides by budm). It explains what DC voltages you should be looking for.
                        --- begin sig file ---
                        --- end sig file ---
                        • selldoor
                          Slow Learner
                          • 7870
                          Re: Acer V223w
                          @RC - Thought that would grab your eye
                          • Welchs101
                            • Sep 2008
                            • 979
                            Re: Acer V223w
                            i have the same exact monitor. Same pics as the one the guy showed in his first post. I replaced all the caps on the power supply board except one which was a small one........not sure of the rating but i think it was a 25uf / 35v caps.
                            Now when i turn on the monitor..........its white......the power led comes on turns blue then screen goes white.......
                            any ideas
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Re: Acer V223w
                              White screen suggests fuse is open on panel/t-con board.
                              • Welchs101
                                • Sep 2008
                                • 979
                                Re: Acer V223w
                                thanks for responding.......
                                what is panel/t-con board...........i assume this is not the power supply board......is this the logic board?
                                • lexwalker
                                  • Feb 2011
                                  • 307
                                  • Malaysia
                                  Re: Acer V223w
                                  See attachment...
                                  • Behemot
                                    • 4845
                                    • CZ
                                    Re: Acer V223w
                                    I think I got similar problem. The monitor behaves as if it was running but no image. Seems like the image is just like-a "out of viewable area"? So that there is problem either with signal board or the panel board?
                                    • lexwalker
                                      • Feb 2011
                                      • 307
                                      • Malaysia
                                      Re: Acer V223w
                                      Have you tried the torchlight test?
                                      • Behemot
                                        • 4845
                                        • CZ
                                        Re: Acer V223w
                                        what's that
                                          09-06-2024, 05:27 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 05:00 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P2CV + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P2CV + Pack Gold Acer 14'' boardview and SF114-34-P2CV + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
