Destroyed LVDS cable for Dell 2405WFP
  • ItFinallyWorks
    • Dec 2012
    I have an interesting problem. I have a Dell 2405WFP monitor (acquired second hand, history unknown). It had the usual problem with bad caps, which I fixed. It also appears that it took out one of the converters on the logic board (loads the 19V supply (checked with no load) down to about 14V if I connect the logic board, fails to power up when connected, etc), but I need to troubleshoot that further. I'm not really that worried about that since it seems to be fairly common and I work on DC-DC converters for a living.
    The interesting problem is like this. The LVDS cable on this monitor is part twisted pair wires and part flat flex cable. The flat flex looks fine, but the insulation of the twisted pair wires is crumbling and falling off. Literally, just unplugging it, much of the insulation crumbled off into my hand (and I was trying to be gentle). It doesn't fall off in large chunks, its tiny little pieces, like dust. Also, this harness has straight wires in it for power or something low speed. Those look perfectly fine. Its just the twisted pairs (which go through a manufactured, shielded cable) that have problems.
    So, has anybody heard of this? I'm in the electronics industry and what one of my coworkers tells me is that this is typical of wires that have been overheated, but I've never seen insulation degrade like this - the overheated PVC wires I've seen have the insulation fall off in chunks, not dry dust like this. Also, other than the wires, there's no signs of overheating. So, I'm wondering if perhaps the panel itself has been fried or if this is just a manufacturing defect?
    If it is just a manufacturing defect, anybody have some suggestions for repair or replacement? I can't find any on ebay and googling the part number on the label (50.L1E04.001) shows very few results. I doubt the the manufacturer would even talk to me about getting a replacement, assuming they had any. But, repair is difficult since these are tiny high speed differential pairs, so splicing is a bad idea as is covering with heat shrink since I will never be able to get the twist back right. I might be able to get the connectors and pins, but I'm sure I don't have the right crimpers for these.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Destroyed LVDS cable for Dell 2405WFP
    This is the third case of this I have seen in the last week try search
    dell lvds in the forum
    EDIT - its here https://www.badcaps.net/forum/showpo...&postcount=240
    and there is another case of it further down the same post.
    • ItFinallyWorks
      • Dec 2012
      Thanks, looks like I'm not the only one is this boat. Not sure if I would have found that or not. Oddly a forum search for dell lvds doesn't bring up that thread - doesn't look like he used lvds anywhere. Now melt cable does, but I had to know that was the terms used in that post.
      What's really got me interested is how this cable got hot since it isn't located near anything that should be particularly hot. The power supply is located well to one side of the logic board on this monitor. Unless maybe that backlight gets warmer than I think.
      The other interesting thing here is that all the LVDS wires in this cable are destroyed, but wires literally right next to it (as in one slot in the connector over) are perfectly fine. Interesting. The LVDS wires are in a shielded cable where the shield is electrically and mechanically secured to the logic board. Maybe if that board gets quite hot, the connection conducts the heat to the cable? Or maybe those are just more sensitive.
      Anyway, the solutions I've seen look pretty hacky. I do have some nice twisted pair ribbon cable I could hack something up with (and probably have it be vastly better than the other solutions I've seen), but I worry about signal integrity or robustness. Best would be replacing the cable or the wires, but this could be a design flaw so a replacement might not be any better.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Well I thought kazkasneaiskaus repair attempt was much better than hacky. In any case it was only a cheap repair to see if that was the only problem with his set.
        • ItFinallyWorks
          • Dec 2012
          When I said hacky, I wasn't just referring to his fix. There was one other I saw that truly was. I will admit, the repair kazkasneaiskaus did does look nice and neat, but from an electrical engineering point of view it is a hack since it throws away the differential signaling and carefully designed line impedance you need to keep good signal integrity for those high speed data lines. That's why he had those issues with artifacts on the screen. But, like you said, if the point was only to demonstrate that the monitor works, it was quite successful.
          My concern is, lets say I prove the monitor is still viable. Now what? A fix like that is great to demonstrate viability, but as he mentioned in his post, it has serious issues. To fix it right, differentials pairs are, at a bare minimum, an essential. But for it to be truly right and be assured that it works as designed, the wire really should be the gauge and twists per inch of the original to obtain the same line impedance as the system was designed for. Plus, you really shouldn't just solder new wires on since that does create stubs that can reflect edges and degrade signal integrity. So, to be right, the best way is to crimp pins on the new wires and replace the old. But those crimpers are specialized and expensive.
          Remember, at the high speeds that cable operates at, this is RF territory. So, think transmission lines, proper termination, source impedance, and all the rest of that. It makes fixing it a whole lot more difficult since you really do need to do it right for it to work well. For alot of things, realistically, any old hack will work just fine - being neat and clean counts though. But once you start getting to these kinds of speeds, it gets more difficult. Not impossible, but you do have to pay attention to good high speed signal design practices. Neat counts here too, but there's more at play than just electrical connection.
          If I had to guess, it's probably sufficient to carefully and neatly solder on something like http://www.computercableinc.com/ccin...+Cable&id=8376 (or similar - teflon insulation would be nice). But I can't guarantee that. Part of what makes me think its probably OK is this https://cdn.badcaps-static.com/pdfs/...5414ffa38e.pdf . My cable isn't just twisted pair - it has shielding too, but I'll bet it isn't essential (but nice).
          • ResoluteHawk
            Connecting an LVDS/eDP cable into a live motherboard
            by ResoluteHawk
            Could anyone explain the reasoning behind why connecting an LVDS or eDP cable into a laptop motherboard, with the battery still connected, kills the CPU/PCH/SuperIO/GPU?
            Today I had a customer with a Lenovo Legion 5 that I diagnosed as a dead iGPU inside their Ryzen 5900HX. They told me that they connected their screen to the motherboard without first disconnecting the battery.
            I want to understand the nitty gritty behind why it kills components if power is not disconnected first.
            08-04-2025, 04:39 PM
          • alfredomfr1
            HP M32f FDH Monitor: 12v missing after connect the LVDS ribbon cable to the LCD circuit
            by alfredomfr1
            12v pin is shorted to ground in the LCD board (1st picture) if the LVDS cable is disconnected, 12v are OK in the Main Board (2nd Picture)
            06-04-2025, 10:23 AM
          • mon2
            A1466 Macbook Air (Liquid damage repair)
            by mon2
            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
            Macbook AIR Model A1466 Diagnostic 09-01-2021
            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
            Problems & Resolutions
            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
            09-01-2021, 09:31 AM
          • NolesFan
            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
            by NolesFan
            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
            10-24-2024, 06:36 PM
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
