Monitor dim and burn smell
  • thedarkmist
    • Nov 2012
    • 7
    • Italy
    I own a dual monitor set with 2 different samsung monitors. Yesterday I disconnected one while the computer was on (and the other monitor as well) and after about an hour I came back and plugged again the monitor. I discovered that the monitor that was remained on (a Samsung Syncmaster T240) was smelling like plastic burn or something. Now, I can see that the monitor is dimmer that normal. Not black, but it seems the brightness is set to, let say, 60% while it's at 100% indeed.
    Can the detouch and reattach of the secondary monitor have cause the damage? Should I investigate for a bad cap or this kind of problem cannot be related to that?
    In the next hours I'm going to open the monitor and take some pictures, but... opening it should I have care about not touching the big capacitor on the power card to avoid shocks? Or does it discharges itself when the monitor powers off? Should I use plastic gloves? I have basic skills. I replaced some capacitors on another monitor, and I have solder, multimeter and other basic equipments, but I'm new to practical electonics (I studied it at school, but it was 15 years ago and my job is in the software field).
    Kind regards.
  • thedarkmist
    • Nov 2012
    • 7
    • Italy
    Re: Monitor dim and burn smell
    Hello. this is the picture of the power board. Capacitors seems all ok, but the problem is in the inverter, in my opinion.
    Do you think it worth to change it? Never done a inverter replacement before.
    • selldoor
      Slow Learner
      • 7870
      Ok if it was the inverter transformer it would probably not come on at all.
      Do a quick test on it - power off wait 5 mins then measure S1>S2 and S3>S4 on your transformer as in attached
      You do not need to remove from the board - find the pins on the back
      • thedarkmist
        • Nov 2012
        • 7
        • Italy
        Ok, but if you see the pucture you can see the plastic is melt and the right side of the inverter is brown colored.
        Sorry for the ignorance, but what I have to measure? Impedance?
        • selldoor
          Slow Learner
          • 7870
          Sorry - my error missed a bit out.
          Set your meter on Ohms 2000.
          • selldoor
            Slow Learner
            • 7870
            Originally posted by thedarkmist
            Hello, could you explain me how to replace the power inverter? Is it soldered on the board, or there is some easier connection?
            Kind regards.
            It is soldered
            this is how I removed it.
            https://www.badcaps.net/forum/showpo...95&postcount=9
            • thedarkmist
              • Nov 2012
              • 7
              • Italy
              Oh, well, thank you.
              Think it's too complicated for my skills...
              Thinking about buiyng a brand new power board. :/
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Yes, I see the transformer has a melted spot in it. That is evidence of an internal arc. I'd bet that the transformer is the problem! The PCB's commonly turn dark brown, it rarely causes issues.
                You might also want to check the blue capacitors in the inverter section for shorts.
                Also, you should look at the wires that go to the lamps - just to be sure there was no arcing anywhere else.
                -Ben
                Muh-soggy-knee
                  by momaka
                  03-15-2023, 10:17 PM
                • wattage
                  AOC AG493UCX 49-inch monitor - Firmware request
                  by wattage
                  Hello Badcaps Community,
                  The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                  07-13-2025, 04:41 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                  by Rick_1234
                  Good evening, gentlemen.
                  I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                  To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                  https://drive.google.com/file/d/1L6S...ew?usp=sharing
                  Things I tried
                  - Bought a new AC adapter thinking that was the problem but the problem...
                  06-22-2024, 04:44 PM
                  Wise Wing F199 19'' LCD monitor - recapped
                  by momaka
                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                  When I saw the Craigslist post, I wasn't...
                  08-24-2020, 10:58 AM
