Dell E171FPb Monitor Flickers
  • Technoguy3
    • Oct 2012
    • 30
    So I was given a Dell E171FPb LCD monitor and told it "was flickering and then died". When I tested it myself, it certainly flickered (I couldn't get it to die though). It appeared to be the backlight rather than the LCD itself, but I'm not 100%. I opened it up, took off the caps from the power supply and board leading to the backlight, tested them, and replaced 1 bad cap. Still have the same issue. It appears to be working better (maybe it's just my imagination), but it still flickers. Any ideas? I can include pics of the board if necessary.
    ALSO: One 1000uf cap was showing almost 1500uf on my tester. Could that be the problem?
    EDIT: Forgot to mention there's a relatively high amount of "electrical" whine coming from the display. Does the backlight need replaced?
  • Rtech
    • Jul 2010
    • 1095
    Re: Dell E171FPb Monitor Flickers
    Have you got a Test backlight ??
      • Jul 2011
      • 6046
      I would also replaced this one as well it is over ( 20% + or - ) just replaced them
      20 % should not higher than 1200 uf
      When I have seen this before the ESR goes up (.20 ) or more when the temp goes down and it changes a lot when you see a value over 20 % the value marked on the cap compared to a new cap when read the uf value it is may have the same value or a little bit lower than what the cap is marked and the ESR value only goes up a few .05 an then stay at a value
      Just for fun dose it have a date when it was made
      I hope this helps
      • Technoguy3
        • Oct 2012
        • 30
        The manufacture date was March 2003.
        Test backlight? I thought backlights in monitors were all proprietary.
          • Jul 2011
          • 6046
          I would replace ALL CAPS
            • Jul 2011
            • 6046
            Test backlight?
            A test backlight is just a CFL tuble the same size tube out of a broken monitor if you have one to test the monitor that you are working on
              Any pictures of the power/inverter board?
              Home made test lamps:
              http://s807.photobucket.com/albums/y...g%20old%20CFL/
              http://s807.photobucket.com/albums/yy352/budm/DELL/
                • Jul 2011
                • 6046
                Originally posted by budm
                I am glad that you shared this that great way to make a useful tool
                • Technoguy3
                  • Oct 2012
                  • 30
                  The yellow stuff on the one capacitor on the power supply isn't leaking; it's just glue. lol
                    Can you check those two lytic caps ESR and value on the inverter or just solder the caps in parallel and see the result?
                    • Technoguy3
                      • Oct 2012
                      • 30
                      I don't have an ESR meter to measure it. Which caps are you talking about?
                        The two electrolytics caps by your thumb in the second picture post 9.
                        • Technoguy3
                          • Oct 2012
                          • 30
                          So the monitor will no longer actually show any picture..... I'm just going to call it BER and be done with it. I still don't know what's wrong with it.
                          • caphair
                            • Nov 2011
                            • 1249
                            This symptom in these monitors are usually caused by a shorted transistor that drives the back light circuit (inverter). I can't tell where they are from the pics you've provided but they're on the psu. I bet one or two of them are shorted and causing the psu to go into shut down mode.
                            • lionidas
                              • Jun 2016
                              • 8
                              • earth
                              hello,
                              i'll have to dig out this thread again, sorry about that,,
                              i have the same Monitor and the same flickering issue,,
                              so any assistance would be great,
                              thanks
                                Originally posted by lionidas
                                hello,
                                thanks
                                Pictures of YOUR boards?
                                • lionidas
                                  • Jun 2016
                                  • 8
                                  • earth
                                  hey, thanks for your reply,
                                  the board is identical to the one in pictures above
                                  • lionidas
                                    • Jun 2016
                                    • 8
                                    • earth
                                    ok then, here they are,,
                                      • 31094
                                      it probably needs a full recap with panasonic FR, i'v had a few and the 15" version that needed that.
                                      given the age, it probably has worn tubes too - but they are probably o.k. still.
                                      lot's of probably's there, that's the nature of repair work
                                        • 31094
                                        that wont show on some browsers inc mine - upload them as attachments - no damned imgur or fotofucket.
                                        • Borse2008
                                          by Borse2008
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • Rick_1234
                                          by Rick_1234
                                          Good evening, gentlemen.
                                          Things I tried
                                          06-22-2024, 04:44 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • DanPoka
                                          by DanPoka
                                          02-15-2025, 05:05 AM
                                          by momaka
                                          03-15-2023, 10:17 PM
