Belinea 2025 S1 2 seconds to black
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Neighbor of mine gave me this one to take a look at. It used to work then shut down by itself, and lately wouldn't light the display at all, or light up briefly, display colored lines and patterns and shut back down.
    Found two bloated 25v 470uF Capxons on the 12v rail. Replaced, no more funky patterns, nice clean "No Signal" display but shuts down 2 seconds later, way before the LED turns amber to indicate standby state.
    The inverter area is fairly toasty also, this thing seems to have run with the bad caps for a while and drawn excess current. I think the FETs or the transformer could be gone. I'm 90% sure the lamps are good, but i'll test them tomorrow before starting to snoop around the inverter.
    A working TV? How boring!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Belinea 2025 S1 2 seconds to black
    Fixed. Redone all the soldering in the areas showing heat damage, and found another bad cap on the 12v rail - a 25v 1000uF Ltec. This one was before the pi filter inductor, hence why output voltage was still low, causing the inverter to shut down.
    For some reason they put heatshrink tubing over it, that's why it eluded me at first. Replaced with a Nichicon PS 16v 2200u.
    • wolf1976
      philips 42pfl3506 working for few seconds and after shut down
      by wolf1976
      hi
      i have the above tv it turns on for few seconds and after shut down
      can you suggest me what can be cause this problem ?
      05-25-2024, 12:18 PM
    • twonk9098
      Lenovo Legion 5 high fan spin turns off after 34 seconds
      by twonk9098
      I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
      I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
      I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
      I have tried a few new bios but exactly...
      07-14-2024, 11:19 AM
    • Rolin
      Lenovo Legion 5 15IMH05H No Display
      by Rolin
      I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
      A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
      06-21-2025, 11:32 PM
    • liquidzorch
      Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
      by liquidzorch
      Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
      10-18-2024, 05:19 PM
    • Rick_1234
      by Rick_1234
      Good evening, gentlemen.
      Things I tried
      06-22-2024, 04:44 PM
