LG Flatron W2353V - Two hours to black
  • turcobom
    • Jun 2020
    • Brasil
    Re: LG Flatron W2353V - Two hours to black
    After the replacement of the IC303, the monitor returned to work properly again. Thanks for your help.
    • lepace5381
      • Feb 2023
      • canada
      hi. isnt it 5 pin and not 4 pin?
      i have the same monitor and the same problem. i replaced all capacitors, didnt work. now i want to replace the ic303 but cannot find online where to buy. any help please? thanks
      • lotas
        • Jan 2016
        • 4759
        • Russia
        https://aliexpress.ru/item/327984843...id=64138336990
        https://aliexpress.com/item/1005001268673031.html
        • conrado.g
          LG Flatron W2353V no power on, nothing.
          by conrado.g
          Hi folks,
          This is my first post. Richard over at YT Learn Electronics Repair recommended this forum in one of his videos. I am learning electronic repair now in my thirties.
          I have an LG Flatron W2353V that doesn't power on. It just stopped working from one day to the next. No lights, no nothing, and I don't know how to test the keypad since it doesn't have buttons, just a touch keypad. I took out the power supply board, and am attaching pictures. Some of the capacitors are bulged. I have a multimeter and have tested voltage at several places:
          Capacitors:...
          06-01-2023, 09:07 AM
        • nothinghyper
          Blackscreen after couple of hours playing (PC)
          by nothinghyper
          Hi Everyone,
          After couple of hours playing a game i get blackscreen , i can still hear the sounds and i can move the character but the image doesnt come back until i reset the computer. I have tried running Furmark 1080p settings fullscreen for 7 hours and didnt encounter the same problem. It used to give me an error as driver not responding so i have installed only the driver itself and not the radeon software since than that message doesnt come up anymorre but i still have the same issue. Sometimes it happens after 30 mins gaming time , sometimes after 3 hours , sometimes even after...
          08-27-2025, 07:23 AM
        • JohnML1975
          LG 49UK7550PTA - after couple of hours screen starts to blink
          by JohnML1975
          Hello Forum team
          Have this TV; searched for the model and could not anything so thought I would share in here
          Had an issue, some years ago, and looks like some placed sticky tape over some of the lines on the FFC cables between the T con and the mainboard
          Anyway, the owner, who gave me the TV, says it starts to blink after a few hours
          So I removed the covers, and could not see anything visibly
          Removed the power supply and thought some of the solder joints, on the hot side, were not the best. I thought some looked like they were cracked.
          07-25-2025, 10:48 PM
        • Eh546
          LG Flatron W2353V slight red hue and kind of dim.
          by Eh546
          The screen has a red hue and is dim, when i try to boost the gamma and turn down the red in the monitor osd, then the blacks are more pale, and the screen has blue hue instead if red. Also even if the brightness is set at 100 in the osd, i can't get the screen to be to be brighter and the white to be white. I also tried to change the color profile and nothing. Can this be because of the capacitors in the power board or the light bulb, or just the lcd panel that is bad?
          Heres a video of a dim display fixed by chamging the caps in the power brick. So i don't know if this could be...
          07-18-2020, 07:03 PM
          by momaka
          03-12-2025, 03:42 PM
