Samtron CRT Monitor. Power LED Blink
  • nish_pinto
    The Adventurist
    • Oct 2011
    • 83
    • India
    I have a Samtron 15" CRT Monitor in workshop. It belongs to my friend.
    Problem: Green Led light keeps blinking and I can hear a clicking sound. Does any one know what the problem might be? He said it has been repaired before because of the same problem. I have never worked on CRTs before. So I need expert opinions on what could be the cause. Here are the pictures of the PCB.
    http://nishantpinto.blogspot.in/
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Samtron CRT Monitor. Power LED Blink
    That Capxon! Is it a previous repair?
      Samsung use Capxon in their products, too... had a 32 inch LCD TV with them.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        LOL, if that capxon was for the 'repair', it was put there to make the relay delay longer :P
        I suggest that you test the power rails for shorts. Also, check the big transistor on the heatsink near the flyback for shorts.
        Muh-soggy-knee
        • nish_pinto
          The Adventurist
          • Oct 2011
          • 83
          • India
          I am not sure about that.
          • nish_pinto
            The Adventurist
            • Oct 2011
            • 83
            • India
            Delay longer? sorry, what does that mean?
            And I hear a clicking sound, what could that indicate?
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              The relay is usually used to turn the degaussing coil on and off. The capacitor is used to provide a time delay.
              Muh-soggy-knee
              • nish_pinto
                The Adventurist
                • Oct 2011
                • 83
                • India
                Thanks for the quick reply. Anything else I should look closely on? Should I try replacing that capxon?
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Look for burned areas, capacitors leaking from the top or bottom, broken/cracked solder points.
                  Muh-soggy-knee
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    firstly if that thing has a blue label samsung crt just junk it now unless this is a practice repair.these were all going to air in the first year.guess what your chances of a good one now are?
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      and the hot is shorted causing the blink/click.
                      • ben7
                        Capaholic
                        • Jan 2011
                        • 4059
                        How do you know? Maybe that is not the problem...
                        Muh-soggy-knee
                        • nish_pinto
                          The Adventurist
                          • Oct 2011
                          • 83
                          • India
                          whats that?
                          • ben7
                            Capaholic
                            • Jan 2011
                            • 4059
                            whats that?
                            In CRT repair terms, HOT means Horizontal Output Transistor.
                            Muh-soggy-knee
                            • nish_pinto
                              The Adventurist
                              • Oct 2011
                              • 83
                              • India
                              Damn, I am noob here. How to check if it is short using a multimeter?
                              • nish_pinto
                                The Adventurist
                                • Oct 2011
                                • 83
                                • India
                                No burns, No bloated/leaking caps. Everything looks fine on the board.
                                • ben7
                                  Capaholic
                                  • Jan 2011
                                  • 4059
                                  Measure the voltages on the power rails.
                                  What is the part number of the HOT? (the BIG 3-leg plastic case transistor by on the heatsink next to the flyback transformer)
                                  Muh-soggy-knee
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    its called seeing several hundred busted units.
                                    this thing is good for practice fodder.nothing else.
                                    the gassy crt trashes the hot when it arcs.
                                      by momaka
                                      03-15-2023, 10:17 PM
                                    • ant3202
                                      HP 27es - LED monitor - Monitor Flashing On - Off
                                      by ant3202
                                      Hi Everyone
                                      Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                      https://www.badcaps.net/forum/troubl...lashing-on-off
                                      The monitor is HP 27es LED Monitor
                                      https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                      The monitor will randomly blackout and display no signal and will recover again.
                                      Sometimes need to power and off again to restore the display but...
                                      03-20-2025, 07:30 PM
                                    • Rick_1234
                                      by Rick_1234
                                      Good evening, gentlemen.
                                      Things I tried
                                      06-22-2024, 04:44 PM
                                      Wise Wing F199 19'' LCD monitor - recapped
                                      by momaka
                                      Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                      I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                      When I saw the Craigslist post, I wasn't...
                                      08-24-2020, 10:58 AM
                                    • sew333
                                      Pc shutdown, monitor flickered with no signal after 10 seconds
                                      by sew333
                                      My pc:
                                      10850K stock 4800mhz stock Kraken X73 good temps
                                      2x16 GB DDR4 GSKILL 3000mhz XMP
                                      Seasonic Tx-850 Ultra Titanium
                                      Gigabyte Rtx 3090 Gaming OC
                                      Aorus Z490 Pro Gaming
                                      1 TB SSD
                                      4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
                                      Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
                                      Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
                                      Power...
                                      02-22-2022, 10:27 AM
