what happens if I put 1000uf25v in place of 680uf25v in a monitor inverter?
  • chriz74
    • May 2011
    • 16
    I have this Mirage Electronics inverter PI-190DTLB mounted on a packard bell maestro which has 6 caps gone. I found two 470uf25v I need but the 680uf25v were not available at the store, they had only 1000uf25v. Can I put the 1000 ones instead of the 680? Will it work?
    Re: what happens if I put 1000uf25v in place of 680uf25v in a monitor inverter?
    You can use them for testing to see if it will fix the problem, 1000uF will have much higher surge current than 680uf. you can use 820uf instead also.
    • chriz74
      • May 2011
      • 16
      I don't know what that means. If the monitor works can I leave the 1000s and close the chassis and forget about that? Or do I need to find the 680 at last?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Yes.
        A working TV? How boring!
        • chriz74
          • May 2011
          • 16
          thanks
