Infamous Gateway FPD2185W
+ More Options
Posts
  • Njoe
    • Sep 2012
    • 4
    So heres another one stranger symptoms than the rest
    picked up this monitor for free and would love to experiment and learn so it lead me to this forum.
    firstly, had the blue led no power symptom, cracked it open and the psu caps were all blown. recapped them with 8 local suncon 470uf 25v.
    i now get power, the gateway logo flashes and the back light goes off.
    iv'e read around can't seem to figure out what would be causing this.
    Im new take it easy on me i have only ever fixed a broken garmin gps usb port lol.
    thanks in advance - joe.
    edit: would it be worth it to replace the bigger 68uf 450v caps as well as the 3 on the logic board they all seem fine by visual inspection.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Infamous Gateway FPD2185W
    1) This is better suited posted in
    Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
    2) It sounds like you have 2 seconds to black.
    2 seconds to black can be
    a) bad caps
    b) bad ccfls
    c) bad ccfl wiring (especially the return wiring)
    d) bad secondary windings on the inverter transformer
    More details starting with post #19 at
    https://www.badcaps.net/forum/showthread.php?t=10419
    Also, see budm's Inverter tester using old CFL
    https://www.badcaps.net/forum/showthread.php?t=19987
    --- begin sig file ---
    --- end sig file ---
    • Njoe
      • Sep 2012
      • 4
      thanks for the move to the proper place on the forum saw "monitor" in misc and just though hey that must be the one. thanks for the reply as well currently reading the 2 second symptom is defiantly what im experiencing.
        You did not replace the other two by the output section? 10 total in the cold side.
        http://s807.photobucket.com/albums/y...way%20FPD2185/
        • Njoe
          • Sep 2012
          • 4
          iv'e replaced all caps. only the 450v 68uf and the only 3 on the logic board i have no replaced.
            "recapped them with 8 local suncon 470uf 25v" Unless I did not read your post correctly, since there also two 220/25V caps on the PS/INVERTER board secondary side.
            • Njoe
              • Sep 2012
              • 4
              replaced those as well as the really small two near the big 450v ones.
                Well then, transformer resistance readings will be next, etc. as written by retiredcaps
                • amigamia
                  Hello Njoe!
                  Have you been able to fix your problem? If so, what did you do/replace? I have the same exact problem and it is driving me insane. I don't have a meter and I wouldn't know how to properly use one if I did have one. I am however, capable of replacing the components on the board.
                  • Rtech
                    • Jul 2010
                    • 1095
                    The absolute minimum you need is a meter..to test the inverter transformer secondaries.If you spend some time going through the site(not just your model monitor) you will see this is a common problem.
                    • Adubey
                      Garmin Dashcam 20
                      by Adubey
                      Hi All, I have a Garmin Dashcam 20. It allows functions to work only if SD card is inserted but it freezes upon inserting a working SD card. So far I have cleaned the SD card socket with alcohol and all of the connections looks good. I also tried using a brand new class 10 SD card as its manual requires but still its not working. Garmin Express is also not able to detect the device.
                      I am able to get into menus using a bad SD card.
                      Let me know if anyone has ideas on what to do.
                      10-02-2023, 05:29 PM
                    • lrservicios
                      HP Gaming OMEN no video symptom
                      by lrservicios
                      Hi all my friends ! i have an HP OMEN DESKTOP gaming with no video symptom, i already tested graphic card and RAM they seem to be OK, i suspect BIOS faliure please can you check for me
                      Exact model is: 875-0911ns S/N: 8CG8435D4N...
                      04-25-2025, 12:57 PM
                    • bjhnsonjr2734
                      Gateway laptop model GWTN-156-7BL Needing Schematics
                      by bjhnsonjr2734
                      I am really needing Schematics for the motherboard on my Gateway laptop model GWTN-156-7BL
                      I attached a pic of motherboard info
                      04-25-2025, 07:01 AM
                    • Dan John
                      Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0) - (Possible) Multiple Issues
                      by Dan John
                      Greetings everyone,
                      I have a Gateway P5WS0/NV57H58u laptop (P5WEO LA-6901P REV:2.0). The client said the battery was not charging. Upon checking the laptop,
                      1) On pressing the power button, the (power button) light turns on and stays on.
                      2) There is no boot, or anything on the screen.
                      3) The fan starts and stops a few times, then it stops completely.
                      4) The light on the power button remains on.
                      5) Battery not charging (original issue).
                      The original problem was that the battery was not charging, but the laptop still worked. My belief
                      04-23-2025, 08:12 AM
                    • aes1111
                      need bios for gateway GWTN156-12BL
                      by aes1111
                      Hello everyone, I have a laptop Gateway GWTN156-12BL, (XA133P rev 2.0) There was a crashed BIOS, I was able to find one for the GWTN156-12BK, and it rebooted. Can anyone share a BIOS dump for this model?
                      S/N 2GWTN15612BL2J21J008090...
                      01-02-2025, 07:23 AM
