Garmin Dashcam 20
  • Adubey
    • Oct 2020
    • 21
    Garmin Dashcam 20
    Hi All, I have a Garmin Dashcam 20. It allows functions to work only if SD card is inserted but it freezes upon inserting a working SD card. So far I have cleaned the SD card socket with alcohol and all of the connections looks good. I also tried using a brand new class 10 SD card as its manual requires but still its not working. Garmin Express is also not able to detect the device.
    I am able to get into menus using a bad SD card.
    Let me know if anyone has ideas on what to do.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8309
    Re: Garmin Dashcam 20
    Try a factory reset, a firmware update, a different SD card, maybe a different power cable. I messed with these around many years ago. One instance in a large 18 wheeler truck, a brand new dashcam 20 did the freezing thing. A new power adapter fixed the issue.
    • Adubey
      • Oct 2020
      • 21
      Thank you for taking out time to read through and responding to my post!
      After I posted, I was able to connect it via Garmin Express and firmware update was done. I ran the dashcam on battery so the power cable having issue is ruled out. As I mentioned in my original post, using a new SD card with same class category that Garmin prescribes - Class 10 still no avail. My next step is going to buy a new SD card with the exact same specs as mentioned below:
      https://support.garmin.com/en-CA/?fa...UU5B9KCAnuVqr8
        • 31178
        wipe the card with something powerfull like Gparted
        cards are sold pre-formatted and sometimes have junk or hidden partitions on them
        unfortunatly garmin being useless fucks dont actually say what filesystem they use.
        but it may be FAT32 judging by the 32gig references
        • redwire
          • Dec 2010
          • 3912
          I would try a low level format using the PC, with the right filesystem. SD cards come pre-formatted with a lot of junk as well.
          I have a Lukas dashcam and the in-camera SD card format is actually just a delete *.* so any issues with the filesystem such as wrong format type or corruption it cannot fix and the dashcam hangs. It's FAT32 I think.
          After the in-cam format of a blank SD card, the cam creates a bunch of folders and puts a default config.bin file there if it can't find an existing one.
          you might try post here: [url=https://dashcamtalk.com/forum/categories/garmin.365/[url]
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8309
            Always format the dashcam SD or whatever card in the device not on a PC if possible. I do that with all my cameras and video devices.
            • Christos Tsiligiannis
              Marian Trace Alpha sound card repair help
              by Christos Tsiligiannis
              Hello to the forum.
              My name is Christos, I am new to the forum here and i am posting from Greece.
              So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
              To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
              So i tried asking for a schematic from the company and they would not give me one. Instead they...
              11-18-2024, 05:26 AM
            • Kemer
              Graphics Card mounting frame
              by Kemer
              Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
              As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
              I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
              What worries me right now is the possibility that...
              09-14-2024, 08:57 AM
              HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
              This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
              09-06-2024, 08:30 AM
            • FZG
              EVGA Nu Audio Sound Card - Not Working
              by FZG
              I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
              The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
              I found...
              03-07-2025, 11:44 AM
            • benwaterson
              Gigabyte Aorus 1080ti - card not initialising
              by benwaterson
              Hi there.
              Have searched various forums but haven't come across the exact issue I am having.
              Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
              I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
              Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
              02-05-2022, 11:42 AM
