Hi guys,
I've read a couple Hanns-G threads for this very same monitor (281D) on this site, and I concluded that I had a problem relating to bad capacitors (a common problem for this monitor), where the capacitors dry out, causing a high ESR condition. I couldn't get the monitor to turn on at all, and no "Standby" mode either. It was as if the monitor wasn't plugged in at all/
A fine gent was nice enough to post the needed capacitors to do a full replace of the board (on this forum), and I ordered them from Digikey. However, I was a bit too eager in the removal process and "messed up" a couple of the capacitors copper tracks & figured all was lost.
Anyways, I ordered a replacement power supply, supposedly tested from an online site. The part number is PSM217-404-H-R. It replaces several different monitors, from 26-38 inches in size (viewsonic, hannspree, hanns G, etc). I put the monitor back together with the new supply, and still is having the same issue. For trouble shooting they told me to do this:
"We have test the item before we send out it.
Can you Please test below:
+5SB 5V
PSON 5V
connect +5SB and PSON test 24V 12V normal or not
Please don't connect dirver board. just test power board
independently."
Where exactly would I test for this? It's definitely getting voltage from the wall... Could this trouble shooting the company is reccomending pan out, and the monitor would still refuse to turn on? That's where the capacitor issue could come in, however I don't trust my skill to do the job, especially after screwing up last time :-(
Thanks for any suggestions any of you guys have...
Tyler
+5SB 5V
PSON 5V
independently."
Tyler
