AL196W Acer Monitor- Slightly Different Issue
  • Solder Boy
    • Nov 2006
    • 178
    Re: AL196W Acer Monitor- Slightly Different Issue
    Originally posted by selldoor
    Id keep this one as spares and use the other "w" fuse to replace the one in the screen you seemed to quickly set aside as it had a blown "w" fuse?
    Try google smd fuse marking
    I set it aside because I don't have the experience nor the right equipment to deal with SMD parts. Considering the prices of used LCD's have been dropping hard to justify the expense in a hot air station etc.
    I did try Googling smd fuse marking.. found everything but W
    www.bcrelectronics.ca
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Ok not all of us have hot air stations - these fuses are big enough to solder.
      It is a 4A 32V FAST blow as seen here:
      http://www.ebay.com/itm/4A-SMD-Fuse-...item4aa5841cae
      You can get them ( though not necessarily with a W on) at various places cheaper than ebay if you are buying other things to defray the postage.
      It can be soldered fairly easily using a 25up to 40 watt soldering iron - you just
      put it on top of the one that is already there - you can even glue it down in the middle and then it is easy just to apply a small smear of solder at each end.
        You do not have to remove the old blown fuse, just lay the new one on top and solder both ends to the old fuse.
        • Solder Boy
          • Nov 2006
          • 178
          Thanks for the lead on Ebay for this fuse.. next stock order I do, will see if Digikey has them.
          Thanks for all your help with this monitor.. what the heck I will order the mosfets as well and see what happens. Might be a while before I report back.. have other obligations before I do this but will keep you posted.
          • Mirenia
            Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
            by Mirenia
            got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
            The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
            If this happened once, then the laptop only runs for a few minutes until restart.
            This happens regardless while staying in windows or uefi or in a linux environment.
            At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
            01-05-2025, 05:15 PM
          • maralexbar
            How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
            by maralexbar
            I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
            It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
            If anyone knows how to force the external monitor as primary for Notebooks of those models
            11-02-2024, 09:18 AM
            09-06-2024, 05:27 AM
            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
            09-07-2024, 05:00 AM
            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
