Gateway LP2407 troubleshooting help
  • spydermark
    • Jul 2012
    • 3
    • usa
    Hello My name is Mark. I am the owner of a FPD2485W or Gateway LP2407 from back in 2008. Over the last few years it has had a vertical constant colored line that was distracting but essentially the monitor still worked. However recently this has changed to after a few mins the monitor now flickers then shuts off. I have never posted on these sites and I am somewhat knowledgeable about electronics so I took the unit apart and found no evidence of bulging caps. I have done some reading on the forums here and still don't rule them out. Wondering if anyone might have some insight to assist me. I have some pics of the boards too.
    thanks
    Mark
    https://skydrive.live.com/redir?resi...N3erlE0FYq631c
  • selldoor
    Slow Learner
    • 7870
    Re: Gateway LP2407 troubleshooting help
    Hi pictures are quite good - pity that some of the people who could help you
    will not get to look at them. I suggest you upload them as follows.
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Do you have a multimeter and soldering iron and can you use them.
    Does the set switch completely off or does the powerlight stay on. If so can you see a very dark image of what should be on screen - you will need a
    working pc source connected. Sometimes help to shine a flashlight on it.
    • alexanna
      • Mar 2010
      • 1346
      Check this voltage regulator.
      If my memory is correct it is a 1.8v regulator and it provides voltage to the front button switches.
      If it is below spec. you will notice random shut off of the monitor.
      • selldoor
        Slow Learner
        • 7870
        @alexanna - Hey - good to see you back - ive seen several cases where ive said you could have helped.
        • spydermark
          • Jul 2012
          • 3
          • usa
          Selldoor, I have posted the photos, and have a multimeter and soldering iron. once the screen goes black the light changes color but stays on.
          Alexanna, I will check the regulator this evening and report back on my finding.
          Much appricate everyones help would like to return back to my dual screens asap
          • selldoor
            Slow Learner
            • 7870
            While you are on that board checking that regulator you may as well check the others.There look to be a few - should have a U designation. Test all the pins(ignore the tab)
            and post results in this format
            U602
            AIC 1084-33PM
            Pin1
            Pin2
            Pin2
              by momaka
              03-15-2023, 10:17 PM
            • Rick_1234
              LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
              by Rick_1234
              Good evening, gentlemen.
              I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
              To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
              https://drive.google.com/file/d/1L6S...ew?usp=sharing
              Things I tried
              - Bought a new AC adapter thinking that was the problem but the problem...
              06-22-2024, 04:44 PM
              Wise Wing F199 19'' LCD monitor - recapped
              by momaka
              Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
              I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
              When I saw the Craigslist post, I wasn't...
              08-24-2020, 10:58 AM
            • sew333
              Pc shutdown, monitor flickered with no signal after 10 seconds
              by sew333
              My pc:
              10850K stock 4800mhz stock Kraken X73 good temps
              2x16 GB DDR4 GSKILL 3000mhz XMP
              Seasonic Tx-850 Ultra Titanium
              Gigabyte Rtx 3090 Gaming OC
              Aorus Z490 Pro Gaming
              1 TB SSD
              4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
              Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
              Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
              Power...
              02-22-2022, 10:27 AM
            • litec systems
              Need help with troubleshooting tips\ schematics -LG monitor that goes off quickly
              by litec systems
              Hi all
              Does someone has the test points \ schematics for lg eax65543115 ( 22" version, lg led monitor)
              Or any ideas how to troubleshoot it?
              The screen turns on for like 10 seconds, then goes off ( kinda protection triggered, as it goes off like you've been pressing the power button)
              , but the cpu gets hot quickly within those 10 seconds , AND STAYS HOT EVEN WHEN IT'S OFF
              I'm suspecting it gets over voltage \ current and triggers some OV \ OC PROTECTION but hopefully it's not too late ( that the chip is broken)
              NOTE that it's a trashpicked monitor...
              08-25-2023, 06:34 PM
