TM-0915 transformer
  • dcooke570
    • Jul 2012
    • 11
    TM-0915 transformer
    Samsung Syncmaster 2233RZ
    Tried replacing capacitors with new ones.
    Screen still shuts off after 2 seconds.
    Can see the screen still with flash light.
    Removed the transformer and tested the secondaries.
    1st pair: 854
    2nd pair: 902
    So they are just barely within 3%.
    Anything more definitive I can test for or just order a new one?
    I have pics just can't post them from this iPod.
    Dan
    Re: TM-0915 transformer
    Try test lamp, such as this: https://www.badcaps.net/forum/showthread.php?t=19987
    or T5 4WATTS lamps.
    or inspect the lamps and wiring.
    http://s807.photobucket.com/albums/y...klight%20lamp/
    • Nocta
      • Mar 2012
      • 117
      • Argentina
      What about mosfets and transistors? Are they working?
      • retiredcaps
        • Apr 2010
        • 9271
        1st pair: 854
        2nd pair: 902
        1) For most of the time, you don't have to remove the transformer to measure the resistance of the secondaries.
        2) I always do the math this way. If 854 is the "correct" reading, then
        854 x 0.97 = 828.38
        854 x 1.03 = 879.62
        So if the second transformer falls in between the two above numbers, then it is good.
        3) Before buying a new transformer, do the ccfl test and examination as suggested by budm. If your transformer readings were 854 and 1500, then it is more obvious what is wrong.
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          BTW, this person had a 2 seconds to black problem (same monitor), but his transformer readings were more obvious.
          https://www.badcaps.net/forum/showth...hlight=tm-0915
          • dcooke570
            • Jul 2012
            • 11
            I don't have access to spare pink or blue connectors for the ccfl test. The connector is pretty tiny to get anything in there to make the connection with anything else. What type of connection could I use in place of the pink/blue connectors?
              You can solder the wires directly to the connectors on the board, you can see the two pins per lamp on the soldered side of the board.
              • dcooke570
                • Jul 2012
                • 11
                What gauge wire do you recommend to solder to the connector?
                  24AWG should be fine, or even 26AWG.
                  • dcooke570
                    • Jul 2012
                    • 11
                    or T5 4WATTS lamps.
                    OK, bought a 3 pack of 14w cfls and hooked one up to the inverter board. Same result; cfl lights for 2 then goes off like the screen did.
                    Anything else to test before ordering the transformer?
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      My checklist (regulars may skip the URL below)
                      More details starting with post #19 at
                      https://www.badcaps.net/forum/showthread.php?t=10419
                      • selldoor
                        Slow Learner
                        • 7870
                        I am assuming your panel has more than one lamp and if so you should
                        be using the test lamp in turn with each lamp. As I recall it explains this in
                        retiredcaps guide quoted above.
                        • dcooke570
                          • Jul 2012
                          • 11
                          My bad. 4 lamps. The 2 connectors on the side where the push button connector is are the ones that turn on 2 seconds. The other 2 connectors are not lighting the test lamp at all.
                            So is this a single transformer setup or two transfromers, one per two lamps? If it is two lamp setup, then I would swap the working one with the one that does not light up the lamp, if the problem follows, then you have bad transformer, if the same two lamps still do not light with the know good transformer, then more components in that section will have to be investigated.
                            • dcooke570
                              • Jul 2012
                              • 11
                              Single transformer (one tm-0915). Each lamp will light for 2 sec if I plug them in to the connector near the push button connector.
                                If it is single transformer, then that will eliminate the transformer driving circuits problem since the primary winding is driven by single circuit, so it does look like you do have one bad secondary. Are there four small blue caps close to the secondary side of the transformers that lead to the lamp connectors?
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  http://www.ebay.com/itm/150861446003
                                  • dcooke570
                                    • Jul 2012
                                    • 11
                                    Yes, there are the 4 small blue caps.
                                      Please use the Ohm meter set to the highest scale and see if they are leaking on that bad section.
                                      Let me see if I have the transformer at the recycling place, I will be working there tomorrow.
                                      I save some boards from monitors with broken screen.
                                      http://s807.photobucket.com/albums/y...pply%20boards/
                                      • dcooke570
                                        • Jul 2012
                                        • 11
                                        0.893 K ohms at secondary pins 1&2.
                                        0.897 K ohms at secondary pins 3&4.
                                        Same for the 2 blue caps near pins 1&4
                                        http://t.co/gbXoWzO
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 04:40 PM
                                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 12:00 PM
                                          ASUS Transformer T304UA-GN042T Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA-GN042T Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-GN042T boardview and T304UA-GN042T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 11:50 AM
                                          ASUS Transformer T304UA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                          This specification for the ASUS Transformer T304UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA boardview and T304UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
