Phillips 19s1
  • lcdman
    TinkerTech
    • Nov 2010
    • 232
    • U.S.A.
    Phillips 19s1
    Hello All,
    I'm currently working on a Phillips 19s1 monitor. When I first got it on my bench,
    it had a fault after the Phillips splash screen it would go out (turn off). And then I changed all but the big cap with Panasonic FM,FC. Now it comes on and I can't shut it down with its power switch? I suspect that I might need to change the caps on the logic card next. They're Elite after all. Does anyone on the forum have any ideas or direction to go before the caps get changed?
    Thanks For Now,
    lcdman
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Phillips 19s1
    I would check the button panel first to make sure the voltage changes when you press the on/off button or that the plastic "extender" isn't broken.
    --- begin sig file ---
    --- end sig file ---
    • lcdman
      TinkerTech
      • Nov 2010
      • 232
      • U.S.A.
      Re: Phillips 19s1
      Hello To The Masses,
      Retiredcaps, when you say "I would check the button panel first to make sure the voltage changes when you press the on/off button or that the plastic "extender" isn't broken." I tried depressing the power switch right on without it being in the bezel. No change to the monitor (it stayed on). How would I test for voltage changes? Could you be more descriptive please?
      Thanks For Your Assistance,
      lcdman
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Phillips 19s1
        1) Get your multimeter out. Black probe on a ground screw. Put it on 20V DC if a manual range multimeter.
        2) On my Benq on/off switch panel, there are 4 solder points to hold the on/off button to the pcb board (it is 11:17pm here so any photo of it would be useless due to the flash).
        3) Put your red probe on each solder point, one at a time.
        4) Now press the on/off button and see if the voltage changes.
        5) On mine, one of the 4 reads 3.300V when the lcd is off. When I press the on/off button, it drops to 0.00V temporarily and then when the lcd is on, it goes up to 3.285V.
        6) So above, the on/off switch is going from "high" (3.300) to "low" (0.00) to turn on the lcd. Your monitor may vary in this implementation.
        7) A multimeter with a min/max function or analog bargraph might help.
        • lcdman
          TinkerTech
          • Nov 2010
          • 232
          • U.S.A.
          Re: Phillips 19s1
          Hello & Thanks So Far Retiredcaps,
          Sorry for the delay in getting back to you and the forum. My power switch assy. has a coating on it so I don't know if I can perform the tests that you mentioned in your previous posts? I also tried another identical logic board and got the same results. When the monitor is first turned on it comes on and then goes off. If I unhook the power switch board and then reattach it comes on? I'm enclosing three photos of the board that i'm having trouble with.
          Thanks As Always,
          lcdman
          • retiredcaps
            • Apr 2010
            • 9271
            Re: Phillips 19s1
            If you have an identical monitor, you can swap out the front panel "keyboard" and retest. You can also try swapping out the power supply as well.
            Having identical monitors makes troubleshooting much faster and easier if you are willing to do process of elimination via board swapping.
            • lcdman
              TinkerTech
              • Nov 2010
              • 232
              • U.S.A.
              Re: Phillips 19s1
              I've tried two identical power switches, no change. I didn't try another inverter board. Doesn't the logic board control on/off of the monitor? Any ideas on testing the power switch assy. thats got a clear cover over the buttons? Otherwise I'm going to move on to another project.
              Take Care,
              lcdman
              • retiredcaps
                • Apr 2010
                • 9271
                Re: Phillips 19s1
                Yes the logic board controls the on/off. It never hurts to eliminate the obvious too.
                Maybe you can test the voltage at the SMD resistors? Or switch the keyboard panel with the "good" one.
                • Adenitz
                  Choosing appropriate PoE extender
                  by Adenitz
                  I have an application that uses 4 cameras PoE. I have one PoE switch in a cabinet in a server room while Cameras are outdoor at different locations. The closest camera is at distance about 80m (that is the cable length), while the furthest camera is about 160 meters. For sure, three cameras are more than 100 m from the switch in cable length. Voltage level is about 48VDC (that PoE switch is supplying.
                  Since PoE is working reliably up to 100 meters, obviously I neeed to use some kind of PoE extenders. In order have two options:
                  1. To buy 4 outdoor PoE extenders, like this...
                  10-31-2024, 02:42 AM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • Scruit
                  Does the Oak OTI067 have a splash screen / initialization message at bootup?
                  by Scruit
                  tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
                  More detail:
                  Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
                  My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it....
                  04-17-2022, 06:03 AM
                • paparazzo79
                  sparklling and buzzing around the switch on the extender cable
                  by paparazzo79
                  My dear electronics repair guys:
                  I switched off this thing (on picture) via switch and switched back ON but immediately I could hear buzz and like a little electric shock around red switch and these 2 lights started to blink but should be ON all the time.
                  I then switched it OFF,got afraid that I burnt the PCs via electric shock.
                  I saw a little current flash around this red switch and I could hear buzzing.
                  All the devices were connected to the extender when I did that but none of them were working at that time (they were in standby mode)-
                  This is second time it...
                  06-06-2021, 10:37 AM
                  Phillips OLED TV 55P0S9002/05 715G8886-P01-000-004Y Schematic
                  Brand: Philips
                  MPN: 55POS900255
                  GTIN: 8718863012352​...
                  11-05-2024, 02:45 PM
