Asus MK241H no power
+ More Options
Posts
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • ShadowAi
    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
    by ShadowAi
    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
    03-15-2024, 10:46 AM
  • meraklinetx
    Asus Z97-a power cycle, no boot no cpu voltage
    by meraklinetx
    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
    05-10-2023, 06:08 AM
  • conghuyms
    Request for Help – ASUS G531GW Rev 1.6 – No Power On
    by conghuyms
    I need your support with an ASUS G531GW Rev 1.6 laptop.
    When I plug in the charger, the battery charging LED turns on, but the board does not power on when pressing the power button.
    Here’s what I’ve checked so far:
    • Motherboard has been removed for inspection.
    • 3V and 5V always-on rails are present (3V/5V_ALW).
    • 1.8V and 1.09V at the PCH are present.
    • I don’t have the boardview/schematic, so troubleshooting is limited.
    • I tried checking the power button signal from the
    07-20-2025, 09:14 PM
