Very Very weird Help please if u can
  • selldoor
    Slow Learner
    • 7870
    Re: Very Very weird Help please if u can
    Sorry forgot power supply is a brick - pics not required.
    You have said the voltage out is 18v+ Was that with is all connected and switched on. If not can you try that just to check the ps has enough power.
    Id still like to see a close up pic of the damage area and
    which cap is above it - is it the one near L10 my top to bottom geography is pretty bad. It that a teapo cap same series as the others? or has it been changed. Maybe the trace is damaged.
    You dont want to be using new teapo caps.
    That is one reason I was asking you to update your profile as its easy for me to say use panasonics but they are not always available in different parts of the world, or only at inflated prices. There are more tests we can do before a full recap.
    • LITEZONER
      GO BOLTS!
      • Mar 2010
      • 223
      Re: Very Very weird Help,, Anybody need a small job?
      I would like to have this board re capped by someone who knows a bit more about what they are doing then me, (Doesn't take Much) Let me know how much and where to send it, I can send you a check or pay you with paypal? Let me know thank you Carl
      39 Soldering Iron burns And Counting
      • LITEZONER
        GO BOLTS!
        • Mar 2010
        • 223
        Sell D, I did not see your reply before I asked for the recap, I am pretty dang sure by the stuff under that cap just above the C144 spot that that cap leaked through the solder joint onto the back of the board, and I cleaned it, I know I probably should not have before I took a picture of it. I just want to get the whole board re capped, what do you think?
        • serious_electron
          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
          by serious_electron
          Hello Everyone!
          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
          06-28-2025, 02:57 PM
        • MOSSEP
          Monitor Audio RSW12 - Green light but no audio
          by MOSSEP
          Hi
          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
          I have already tried replacing all of the...
          01-26-2025, 08:18 AM
        • mosfetratus
          macbook A2918, orange light off when shut off
          by mosfetratus
          When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
          Works with battery and charges, but when i shut off i get this problem.
          It had liquid spill. Board has no corrosion, keyboard is working, power button...
          05-31-2024, 03:34 AM
        • MOSSEP
          Monitor Audio RSW12 - Green light, but no sound
          by MOSSEP
          Hi
          01-26-2025, 08:33 AM
          by momaka
          03-15-2023, 10:17 PM
