Samsung SyncMaster 920WM, part identification.
+ More Options
Posts
  • jet
    • Apr 2012
    • 58
    Hi All,
    I am trying to identify the part number for D803 and D805. The monitor is a Samsung SyncMaster 920WM, type number GH19WS.
    This monitor does the typical back-lite comes on for two seconds and then off. I have removed and re-soldered transformers to the lite and replaced all caps. Still no joy, D805 is discolored and I can't read the value of the part. I also need to confirm the part number of D803.
    Both D803 and D805 are dual diodes, what are typical reading I should get across there junctions with a DVM?
    Thanks, Joe
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Samsung SyncMaster 920WM, part identification.
    Hi - I cant see this model has featured on here before so we are just guessing what the diodes you mention look like - a picture wold have done it.
    If you read this 2 seconds to black guide by retiredcaps it says how to test
    most things - start at post 19
    https://www.badcaps.net/forum/showthread.php?t=10419
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say a bit about yourself - skills tools etc.
    • Rtech
      • Jul 2010
      • 1095
      Two things spring to mind....the 1st is have you confirmed that it is not the Backlights themselves,which included the wiring to them that is NOT causing the problem ????
      2nd..I assume that the diodes you are referring to are 3 pin devices,probably mounted on a Heatsink,and are Schottky Diodes ??/If so Put you meter on 'Diode check' if you have that function, and with the Black lead on the Centre pin (MAKE SURE NO POWER IS ON), you should get a reading the same to both outside pins of each Device. Then put the Red in the Middle and do the same....IF you get a short Circuit then they are faulty,if not they are probably OK.
      A Photo would br helpful of course..
      • Gingerbeer
        • Jun 2012
        • 11
        I don't know if this of any help, but I had a Syncmaster 932 exhibiting identical symptoms, to those mentioned in the OP.
        I only had to replace the inverter transformer on the power board, and it's been working flawlessly for about 6 months.
        • soopacrucial
          Samsung Syncmaster 740BF repair
          by soopacrucial
          Hi folks,
          I'm new here and was wondering whether you might be kind enough to give me some advice on troubleshooting the following problem:
          Quite a few years ago now, a couple of years from new, my Samsung Syncmaster 740BF LCD monitor starting playing up by making a buzzing noise and then the display would go blank. I seem to remember the blue power led would also go off when this happened but that I'm not 100% sure of. By pressing the power button I do remember I could at first get it working again but eventually the problem would come back. At the time I had read about...
          10-29-2024, 02:40 PM
        • Shulgin
          Acer predator XB241YU Component identification
          by Shulgin
          I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
          After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
          In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
          I...
          05-11-2024, 11:06 AM
        • thebomb602
          ASUS GA402R IC identification
          by thebomb602
          Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
          also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
          EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
          11-21-2023, 02:30 PM
        • Tend0
          hp elitebook 840 G4 no 5v IC identification
          by Tend0
          Hello everythone
          i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
          i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
          05-31-2025, 09:13 PM
        • Tomylee
          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
          by Tomylee
          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
          I'm looking for help with the following:
          The exact identification or part number of the T5 component
          05-28-2025, 12:42 PM
