Samsung 931BW no power
  • s_henya
    • Jan 2011
    • 483
    • Israel
    Hey guys, got this monitor for repair yesterday,
    When plugged in there is no power, no led light, but if you
    listen you could hear there is a problem whith the power suplly,
    opend the case no caps are bulged, fuse ok, there is a shorted "big" diode
    SR310.
    what else should i look for, before ordering a replacment,
    i will upload pics later today, and i'll check all the caps anyway.
    anyone know this power suplly, how to check voltages when open and disconnected from logic board.
    thanks,
  • selldoor
    Slow Learner
    • 7870
    Re: Samsung 931BW no power
    Have you read this post
    https://www.badcaps.net/forum/showth...ighlight=931BW
    • s_henya
      • Jan 2011
      • 483
      • Israel
      now i have, :-)
      the problem is bit diffrent, all of my caps on power board seems fine,
      but the diode is shorted,
      never saw a doide that big shorted, that's why i asked....
      • selldoor
        Slow Learner
        • 7870
        Ok - waiting for the pictures thought it might be useful for checking voltages.
        You normally need the logic board connected.
        • s_henya
          • Jan 2011
          • 483
          • Israel
          sorry for the delay, but here are the pics,
          had to shrink them...
          checked all caps esr and capacitance, all good,
          ill search the diode, localy if i wont find it i'll have to order from ebay.
          any suggestions...
          • Rtech
            • Jul 2010
            • 1095
            I find that these standard Diode types (DO-201),are used on quite a few different Psu/Inverter Boards, and tend to fail more than the one that is normally screwed to a heatsink.I suppose there are various reasons for this,but when i see them on a Board, they are always one of the main points of interest in the the fault finding procedure.
            • s_henya
              • Jan 2011
              • 483
              • Israel
              couldn't find the diode SR310, but i could find ct pr3002 or 1n54004
              the thing is that there are 2 diodes in parallel the shorted one, and another one just like it which is good, if i would replace the shorted one with a substitue will it still be ok?
              • Rtech
                • Jul 2010
                • 1095
                I always change both, as you do not know what caused the the failure, and the second one may well be weakened.But the choice is yours.The replacements need to be 'fast recovery' diodes, and if so and current etc is fine,(I have not checked your choice),then all should be fine.
                • s_henya
                  • Jan 2011
                  • 483
                  • Israel
                  i decided to buy the originals from ebay, 10 diodes for 5 dollars.
                  i will update as soon as i'll get the shipment.
                  • s_henya
                    • Jan 2011
                    • 483
                    • Israel
                    hey, iv'e got good news,
                    recieved the diodes today,
                    replaced both as suggested, works as good as new!
                    thank you all for helping!!
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • mrtek
                      Samsung UN43NU6950FXZA No power
                      by mrtek
                      Hi
                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                      Main fuse = OK
                      Back light LED = OK. Power them with aux power source
                      LED output = OK 156V
                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                      07-20-2025, 08:06 PM
                    • hill01
                      Samsung UE75MU7009TXZG Endless Power Cycle
                      by hill01
                      Hi everyone and thanks in advance for any help I might get here
                      My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                      About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                      Since a few days, the TV won't turn...
                      11-17-2021, 02:52 PM
