HannsG 281D Recapped Won't get bright
  • tom2tone
    • May 2012
    Thanks for all the help so far. I had a dead monitor brought back to life with new caps but now it won't get bright. Kinda like it's owner!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HannsG 281D Recapped Won't get bright
    1) Check all your soldering work especially on the main board. Check to make sure the caps have correct polarity and they are seated firmly.
    2) Reseat and clean all your internal cable connections regardless whether you touched them or not.
    3) What brand and series of caps did you use for replacements?
    --- begin sig file ---
    --- end sig file ---
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Hi - can you explain a bit more - wont get bright is a bit relative - what happens when you adjust contrast/brightness.
      Usually when a screen is dull the whole thing shuts down.
      Have you tried it on a different pc /with a different cable
      or another screen on the pc this is on.
      Is the on screen menu display dull as well.
      Pictures are really what we need so we can see what you mean - we also need pictures of the boards
      pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      https://www.badcaps.net/forum/attach...7&d=1280167246
      It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
      • Schwoin
        Philips 243v5lhsb00 Monitor Picture too bright
        by Schwoin
        Hey everyone,
        the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
        While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
        you can see them on the top half of the photo.
        At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
        03-21-2023, 12:40 PM
      • tmhobadcap
        LG 55UJ6200 TV with bright spots
        by tmhobadcap
        There are a few bright spots on the screen. I checked on youtube and most probably they are caused by the led lens fell off and can be fix by gluing back the lens.
        But one of the bright spots is actually a bright ring (circled in red as shown on the attached photo). That means a bright spot with a dark center. What is the cause of that bright ring and how to fix it?...
        03-06-2021, 08:54 PM
      • user546087
        Keyboard backlight too bright - Asus Zenbook S16 / UM5606
        by user546087
        I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
        - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
        - tint the keycaps from behind - I have already tried that - it is kind of a last resort
        - try to find out, how it is done, look at schematics - this is, where we are at.
        - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
        02-24-2025, 02:03 AM
      • ttmi100x
        HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
        by ttmi100x
        Greetings everyone,
        I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
        The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
        Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
        Upon closer inspection...
        07-31-2024, 06:36 PM
      • BlueNitesFire
        I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
        by BlueNitesFire
        So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
        03-08-2025, 03:49 PM
