Dell WFP 2007 No image
+ More Options
Posts
  • noisepc
    • Apr 2012
    • 26
    • Argentina
    Hi guys,
    My monitor just stopped working a few days ago. I´ve tried it in another computer but the problem persist. The thing is that when PC send signal to the monitor, power lights on green light, but is not showing the image, a few second later goes to amber light. The backlight starts when the pc send signal. I´ve opened the case and checked the caps but no one is damage.
    OSD is not showing either.
    Here are a few pictures I took from the logic board:
    http://*************/g/98/resizeddsc04634.jpg/
    Thanks in advance!!!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell WFP 2007 No image
    1) For several reasons, I prefer pictures so they are hosted on this forum. Follow my sig file below exactly to post your pictures. We want them in the following composition.
    https://www.badcaps.net/forum/showpo...94&postcount=1
    2) Do you have a multimeter and do you know how to use it?
    --- begin sig file ---
    --- end sig file ---
    • noisepc
      • Apr 2012
      • 26
      • Argentina
      Thanks for the recommendations, I´m gonna try to upload the pictures as you said. I´m new in this forum, and I´m sorry if I brake any rule :S . Also wanna say that I´m from Argentina therefore my English sucks! so please be patience, as is kinda difficult to explain the problems I have with this monitor.
      I have no idea how to use a multimeter , but I can buy one and learn how to use it if it´s not difficult.
      • retiredcaps
        • Apr 2010
        • 9271
        Does the screen stay white the entire time?
        • noisepc
          • Apr 2012
          • 26
          • Argentina
          It went to stand by mode after a few seconds (amber light).
          • selldoor
            Slow Learner
            • 7870
            When it went into standby was it connected to a pc that was not in standby.
            Repeat retiredcaps question - "Does the screen stay white" that is does the back light stay on.
            You will almost certainly need a multimeter.
            Also a soldering Iron and solder.
            There is an inverter board in this set with 3 gray rectangular transformers on it
            Can you see if the number on it begins 4001R - picture would be good
            • noisepc
              • Apr 2012
              • 26
              • Argentina
              Hi Selldoor,
              Let me try to explain the issue again. The display is connected to the PC, when It starts the green light on the display lights on, then the backlight starts too, a few seconds later the monitor goes to stand by mode (amber light), that´s all. Same behavior in another PC, tried on DVI and VGA port too.
              Regarding the Inverter, I don´t know where is located or where is it. If you need more pictures, please guide me thru and I´ll post them here.
              Thanks!!!!
              PS: I have a solder and a tester (but I don´t know how to use the tester)
              • selldoor
                Slow Learner
                • 7870
                Ok post a picure of your tester say what make and model is if its not clear in the picture.
                Just to confirm - that back light comes on then goes off..
                This is "two seconds to black" and retiredcaps has written a guide here:
                https://www.badcaps.net/forum/showthread.php?t=10419 start from post#19
                The inverter board is shown in the 4th picture on this thread https://www.badcaps.net/forum/showth...ight=dell+2007
                He is from Argentina also coincidence or all bad 2007s in Argentina?
                • noisepc
                  • Apr 2012
                  • 26
                  • Argentina
                  I don´t have my tester here, but I´ll post a picture later. Regarding the issue, is not the same as the other mate.
                  The backlight comes on when the PC send signal and then goes off cuz of the power save screensaver.
                  Am I clear?
                  • selldoor
                    Slow Learner
                    • 7870
                    Hi sorry - no we are not clear.
                    Set up the pc with no screen saver , no sleep mode, it needs to stay on for
                    at least 15 minutes. Then tell us what happens after 5 minutes and ten minutes.
                    • noisepc
                      • Apr 2012
                      • 26
                      • Argentina
                      Ok, I'll reassemble it back and then I'll post you the results.
                      Thanks!
                      • noisepc
                        • Apr 2012
                        • 26
                        • Argentina
                        Update: The monitor stays with green light on, and the backlight started. It has been there for about 15 minutes, no image.
                        • Jasgriff
                          • Feb 2012
                          • 578
                          Ok,
                          your picture shows 2 voltage regulators on the bottom left of your picture above.
                          One has a tab and 3 pins and the other has a tab and 2 pins. Please can you tell us the measurements off each pin and can you tell us what it written on the top of each one.
                          Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                          How to resize your pictures guide click HERE
                          Retiredcaps Ideal post example click HERE
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            A picture of the problem would help.
                            We also need a picture of the panel board. It is the long board that runs the entire length of the lcd at the top.
                            • noisepc
                              • Apr 2012
                              • 26
                              • Argentina
                              This is a picture of my monitor connected to the PC, without image but with the backlight on.
                              • selldoor
                                Slow Learner
                                • 7870
                                @Jasgriff - I think he's going to need some guidance
                                "I have no idea how to use a multimeter , but I can buy one and learn how to use it if it´s not difficult."
                                @noisepc - Having sorted the screensaver it is NOT" 2 seconds to black"
                                • noisepc
                                  • Apr 2012
                                  • 26
                                  • Argentina
                                  I have added 2 more images, please let me know if you need more of them.
                                  • Jasgriff
                                    • Feb 2012
                                    • 578
                                    @ Selldoor - I thought that when I wrote the post.
                                    @noisepc - We have found out that your screen is lighting up which means that we need to do some further checks. We can talk you through the next stage but you are going to need to get a multimeter.
                                    Thanks for the pics of the bottom of your boards your are going to need to unscrew them and take a similar picture of the top of them as clear and as close as you can. Remember that we are having to look very closely to see what's going on and that can be impossible with a poor picture.
                                    • noisepc
                                      • Apr 2012
                                      • 26
                                      • Argentina
                                      I have uploaded more images at the top of this post, from the other side of the cards, please let me know if you need something specific.
                                      Thanks man!
                                      • noisepc
                                        • Apr 2012
                                        • 26
                                        • Argentina
                                        I´m gonna buy the multimeter, what kinda specs should it has?
                                        • Borse2008
                                          Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                                          by Borse2008
                                          Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                                          I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                                          • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                                          • There’s
                                          07-15-2025, 04:55 AM
                                        • andrhouseolly
                                          Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                                          by andrhouseolly
                                          Hi.
                                          I kindly ask you to help me solve the problem.
                                          Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                                          The board turns on, there is no image.
                                          Read more. When the power supply is connected, the front panel indicators light up briefly.
                                          When you press the power button, the button indicator lights up. The board works
                                          there is no image, there is no matrix initialization, there is no image on HDMI.
                                          When turned on, the fans do not spin, but when they warm up they start spinning.
                                          When you turn off the button, the fans spin up to full speed for a short...
                                          05-11-2024, 03:14 PM
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • 3D Modelka
                                          AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                                          by 3D Modelka
                                          Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                                          02-09-2024, 02:42 AM
