Hanns G HG281D dead...
  • jimbobaggies
    • Apr 2012
    My friend has a Hanns G which when plugged into mains is dead, screen not on, no LED on front panel. Prior to this he said it had become temperamental, not turning on first time, having to flick switch (mains?) on and off 2 or 3 times before it would come on.
    A quick scan pointed to PSU caps, so I bought a cap kit, 2 actually, the first one was for the wrong model PSU, anyway, I have now changed all the caps on the PSU from the kit and it is still dead.
    Any help greatly appreciated.
  • Jasgriff
    • Feb 2012
    • 578
    Re: Hanns G HG281D dead...
    Welcome to the forums,
    Does the screen come at all when you initially turn it on?
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Welcome to the forum-
      We can help a lot more if you please post good clear pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
      Examples of what is needed
      https://www.badcaps.net/forum/attach...1&d=1290283049
      Photos without the heatsinks please
      https://www.badcaps.net/forum/attach...7&d=1280167246
      Can we assume you have checked the fuse in the power cable / tried another cable?
      • retiredcaps
        • Apr 2010
        • 9271
        Review this megathread first.
        https://www.badcaps.net/forum/showthread.php?t=11329
        It covers almost everything wrong with this lcd. Afterwards, ask questions.
        --- begin sig file ---
        --- end sig file ---
        • double_DD
          How can I be sure that my EC chip is dead?
          by double_DD
          As the title suggests, how can I be sure that my EC chip is really dead?
          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
          03-12-2025, 07:47 AM
        • disorder
          ps5 edm-033 dead after hdmi/usb ports destroyed
          by disorder
          hello guys,
          i need help to repair a edm-033 ps2
          history : as always hdmi port and usb ports destroyed after unplugged
          after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
          so i changed it
          now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
          but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
          i don't see any projection of liquid metal on pcb.
          01-14-2025, 12:48 PM
        • chopduel
          Bad mains power causing TV malfunctions?
          by chopduel
          I've been living in the same apartment for about 5 years now, and moved into it with my old Samsung plasma TV (PS51F5500).
          Ever since we've moved in, we would sometimes see strange power-cycling behavior. For example:
          • TV would randomly turn off then back on.
          • TV would turn off and the LED light would blink for a while (over a minute sometimes) until eventually it went back to a regular off state and could be turned on
          • Sometimes it would require disconnecting the mains cord from the TV, waiting several minutes, then putting it back in and turning the TV back on. This had limited
          12-29-2024, 03:20 AM
        • Beton
          Finding a dead short component
          by Beton
          Hi guys!
          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
          I have a bench PSU and if I try to inject voltage the voltage...
          12-10-2021, 01:05 PM
        • FiguringITout
          MSI Raider GE75 - Not posting, probable dead CPU
          by FiguringITout
          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
          07-25-2024, 07:27 AM
