Re: Dell E228WFPC goes dim after 10 minutes, not 2 seconds
Are c805 and C 811 the two caps on the inverter section.
Did you measure the voltage at them yet
I dont think we know yet that the c806 is a problem on your board.
Try easy things first.
I suppose setting it up then heating where c806 is to see if it makes it go off would be a test
These are easy to do if u smother the end in solder and quickly heat up both sides then lift using tweezers or push to the side with the soldering iron.
Smd caps can be bought from the usual places. Can't see ur location on your profile so not are where to suggest.Leave a comment:
FYI - I replaced C805 and C811 today (470uf 25v each) and no change. On the off chance that POM_MJ meant C805 instead of C806. I didn't check this thread for updates until AFTER I'd swapped out those caps.
OK, I'm pretty handy with a soldering iron, but WTF?
How am I supposed to change that surface mounted cap?
Metal tweezers and a low temp iron with a pencil tip?
Where can I find said cap?Leave a comment:
That makes sense since it is hooked up as softstart, but with resistor in place (leaky cap), then it is setup as Deadtime control.Leave a comment:
When BAD C806 (in my case) warmed-up, it has leakage current flow through it then cause the voltage at PIN4 goes higher than normal and pulse duty cycle goes wrong, that make lamps current incorrect, then protection scheme shutdown the oscillator, I thought.
edit: IPboard 715G2594-1-4 (HUDSON8) schematic uploaded for reference.Attached FilesLeave a comment:
I look at the SCH, PIN 4 is the Dead time controller pin, per SCH, it is setup as SOFT-START mode since R818 is not used. It is interestin that C806 caused the lamps to go dim, it must have change the ON time of the lamps.Attached FilesLeave a comment:
Cant see C806 is that a ceramic smd on the back?
What voltages do you get on the two black caps in the inverter side of the PS (one is possibly c805)Leave a comment:
Try to replace C806.
I had the same symptom with the same IPboard.
I used hot-air to locate heat affected component then found C806 conduct when it heat, replaced with 0.1uF/50V 0805 running fine for 2 months.Leave a comment:
I am just trying to find out if the two ballast caps have leakage resistance when you check them with the Ohm meter.Leave a comment:
How do you do that?
I did test all the caps on both boards with my ESR meter.Leave a comment:
"I metered the blue caps near the transformers and got similar ohms between the two (secondaries, right?)"
So are you able to read the resistance of these two blue ballast caps?Leave a comment:
Oops! Been looking at too many Dell boards today. Some of them had separate inverter boards.Leave a comment:
A photo of your inverter board would be helpful.Leave a comment:
Update: I brought a sister monitor home today and swapped in the boards from the known good monitor with my panel. I gave it to my wife to work on all day with her design work.
Result: no problems all day.
OK, that's good, at least that means I've narrowed the issue down to the inverter or logic board(s).
So what now? Start stressing my suspect boards with brightness adjustments, or a hair dryer?Leave a comment:
See budm's thread on "Inverter tester using old CFL"
https://www.badcaps.net/forum/showthread.php?t=19987Leave a comment:
"Before I try any hair dryer tactics, it would probably be a better idea to place my panel on the boards of a known working donor monitor. If the problem migrates, then I know it's a CCFL issue."
Sounds good plan to me likewise if you have the panel off a donor try it on
these boardsLeave a comment:
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by aaronkatriniHi all,
I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
- Put the card in my testing motherboard and start running Heaven benchmark
- Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
- Try to start it again and I get a slight move from the PSU fan - a clear short
- A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
- Put the... -
by DrFalkenHello everyone!
Motherboard model: FDI55 LA-J081P
Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
I found and replaced a shorted MOSFET (PQZ3).
Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
BIOS has already been updated (both 64MB and 128MB IC)
+3VALW and +5VALW are still present.
+VCCIN = 1.8V stable (measured on PLZ1 at power up)
Abnormal readings:
PLZ1 to GND = 0 Ohm
PLZ2 to GND = 0 Ohm
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by Kambi13Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
Not heat related, everything is ok regarding to that.
All voltages are present.
Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
Motherboard is Cedar 13269-1 F3XMC Rev A00... - Loading...
