Dell 2405FPW
  • kmoonen
    • Dec 2011
    • 61
    Dell 2405FPW
    Ok anyone know if this would be the TCON Board, or the main board ?
    Dell 2405FPW
  • jetadm123
    • 2169
    Re: Dell 2405FPW
    Do you get the same garbled screen if you press the menu button?
    • kmoonen
      • Dec 2011
      • 61
      Re: Dell 2405FPW
      Yes the screen is still the same if you press menu.
      If you leave the monitor sitting for an hour or so, it will turn on and work for about 5 minutes, and then it gets vertical grey lines, and after that goes crazy . with colors and squares
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
      • Garret Matt.
        DELL Latitude 5430 Rugged CORE_D5K Rev.A00 Schematic and/or Board View
        by Garret Matt.
        I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
        Thank you in advance for any assistance you can render.
        Inductor In question. Buzzes like...
        06-20-2025, 01:21 PM
