HP L1902 - stuck in "service mode"
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Well i picked this up hoping for a cheap and easy fix, as there is a known issue with cold solder joints on a toroid inductor. Sure enough, that was what was preventing the thing from turning on, however i was in for a surprise: It flashes red-green-blue-white screens sequentially and won't do anything else so i assume it's stuck in some sort of service mode. Not even the power button works. Gonna need some help on this one.
    Oh and it also has some dust inside the LCD, i'll have to take it apart and clean it. That is, if i can get it out of this stupid test pattern first.
    Edit: I can be an idiot sometimes. I haven't thought about actually plugging an input signal into it. It works just fine. Looks like all it needs is a good cleaning of the insides of the panel.
    A working TV? How boring!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: HP L1902 - stuck in "service mode"
    Don't worry, you would not be the first and will not be the last to do this. I can't remember how many pages of troubleshooting that PlainBill and I put into before the OP finally plugged in a source and everything was working fine.
    Now I always ask people if they have a source plugged as part of the standard questions.
    --- begin sig file ---
    --- end sig file ---
    • Mr Bill
      • Nov 2011
      • 648
      I guess i just joined the club
      I had an older 17" in the basement that was doing the same thing and i set it aside until today. Actually hooked it up to the test computer and wouldn't you know it
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
      • thesame
        JVC LT-40V750 stuck in service mode switching colors.
        by thesame
        The tv is stuck in service mode, i have unpluged it for several times, tryed to power it separate from remote , tryed some reset method using menu button and 4725 typed twice in a row to enter or disable the service mode but it didn't work. The board has no damaged components, could it need a fresh firmware or the emmc could be dead?...
        01-12-2024, 10:39 AM
      • AustinCER
        Dell XPS 8940 | Manufacturing Mode? | No Service Tag
        by AustinCER
        Hello, I currently have a Dell XPS 8940 in our office for repair.
        Service Tag: HG1Y673
        The most recent BIOS is pictured below -- being available as an .exe on Dell website.
        Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
        Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
        07-15-2025, 05:28 PM
      • RRice25541
        Sharp Lc-50UB30U may be locked out of Service Mode and Factory Mode
        by RRice25541
        So i got this tv from my neighbor, when it wasn't working right for him,, he purchased another tv and gave his old to me.
        the color is all outa wack, like the settings have been corupted,
        I've already done a firmware search using the wifi connection update from the tv and it didn't find any new update so it's got the most recent version.
        so
        The issue is i can't get into service mode or factory mode, tried resetiing it from user mode and it didn't change anything.
        when i bring up the menu and type the pass codes to access either mode the menu disappears...
        05-13-2022, 10:44 PM
      • modtool
        HP x360 Chromebook 14A-CA, DA00GIMB6H0 REV:H, flooded, restored, slow and stuck in tablet mode
        by modtool
        Dear colleagues,
        I've entered the repair of the chromebook machines just one month ago and I've found some significant differences from the classic laptops or macbooks, so I'm searching some advices.
        The owner of this chromebook gave it to me after it has been left flooded by water for almost a week, so chances of repair were not so high, the mainboard was oxidyzed in many spots but I made a nice cleaning, resoldering and component replaging work and now it is almost working.
        Among other things I've cleaned many spots from oxyds, reballed CPU, EMMC, EC, replaced...
        05-07-2025, 06:10 AM
