Gateway FPD1976W - Power button flickers
  • Hooker Jay
    • Mar 2010
    • 7
    Hi there. I recall posting in another multi-page thread regarding this LCD and finally got around to recapping the inverter on Monday. Here it's the following Saturday and just a moment ago, I could've swore I saw the power button LED flicker to orange for about 1.5 seconds and back to blue. Thinking the LCD was about to puke, I sat here sipping coffee and watched the power button. The blue LED flickered again - that time briefly off and on.
    Is there any known issue with this button in other Gateway FPD models? I hope its no real cause for alarm. Heck, I hope it was my eyes playing tricks on me -- it's kinda hard to detect out of ones peripheral vision since the Windows taskbar has a blinking network activity icon right above that blue LED ... and you know the old saying "watched pots never boil" ...
  • alexanna
    • Mar 2010
    • 1346
    Re: Gateway FPD1976W - Power button flickers
    Flickering of the PLED can be caused by several reasons.
    Assuming you used the correct capacitors and they soldered in properly you have ruled one cause out.
    An excessive load on the system could be another, what voltages do you notice going to the logic board and are they steady?
    Do you have a way to post some photos of the power supply?A top down view of top and bottom woul be helpful.
    • Hooker Jay
      • Mar 2010
      • 7
      No experience. No testing equipment. Total noobsauce here, and $15 to roll the dice using one of Scott's (LCDAlternatives) was the farthest thing from horrifying. The unit had been unplugged and on my desk collecting cobwebs for 18 months, wasn't disassembled, and judging from other posts here, I was either gonna have 1 capacitor short or 1 capacitor too many despite Scott's efforts to stay on top of it all. Sure enough 1 capacitor short, but it was a smaller 47uf 25v capacitor just above the largest one. Unlike every cap grouped near the mosfets and heatsinks, it wasn't blown/bulged. I would have to live that ...
      Worst case scenario: the recap job wouldn't work, cut my losses, dump the LCD.
      Best case scenario: best $15 I ever spent refurbin' my daughter's great-grampa's $300 monitor for FREE!
      Overall, the odds of a recap are much better than the odds of winning the $2,700 progressive cover-all jackpot down at the bingo hall with that same $15 ...
      Before disassembly, I read reams of material and watched many videos on Youtube on many Gateway FPD series LCDs so that I had a general idea on what to expect when cracking this thing open. Was very slow and careful near the PLED when prying it all open. I lucked out big time as the PLED's PCP was clipped in place to the rear bezel, so when the front bezel peeled off, it stayed locked in place.
      The hardest part of the disassembly was the taped flat ribbon cable running to lamp controller board to the video logic PCB. I'd rather have unhooked that from the PCB inside the compartment instead of removing the tape and unclipping it. But that couldn't be helped ... and it was quite a chore of getting it plugged back in upon reassembly. Replaced the old tape with a good strip of electrical tape.
      I'll have to post the pics later -- the camera is a wretched old 1.3 mega-pixel Sony Cybershot with a junk battery. I keep it plugged in - replacing the battery is about 75% the cost of a new camera. The max resolution and limited space on the memory card leaves alot to be desired. The pictures I took probably suck universally -- flash on or off. Will have to check them later ...
      Other than that, I've been here lurking the forums for the last few hours and the PLED hasn't done it again. But I had only been awake with the LCD turned on for about 30-45 mins though - I was still trying to find a vein on arm for the coffee when it happened the first time!
      • retiredcaps
        • Apr 2010
        • 9271
        Email Scott and tell him you are one cap short. He might send it to you.
        --- begin sig file ---
        --- end sig file ---
        • Hooker Jay
          • Mar 2010
          • 7
          I intent to, but I'd hate to see him do that for just 1 cap. I might have to order his kit for an OptiQuest Q9-2 some day, so he could pop that cap in there at his leisure if/when that happens ...
          • retiredcaps
            • Apr 2010
            • 9271
            I have done some analysis of DIY versus buying a "kit". I estimate the sellers make close to $10 per kit.
            DIY can save you about 1/2 the cost.
            • Hooker Jay
              • Mar 2010
              • 7
              Now you're talking -- my lawnmower could use that extra gallon of gas!
              Here's the pics ... and they're worthless ...
              Last person to use didn't set it to max resolution ...
              • retiredcaps
                • Apr 2010
                • 9271
                Here's the pics
                Are these the before or after pics? If they are after pics, you have an obviously bloated green cap.
                • Hooker Jay
                  • Mar 2010
                  • 7
                  Those were before - the only after pic is the last. The caps I replaced are the 6 around the mosfet heatink in the center of the PCB that follow a \ and / slashing pattern. Those 6 were replaced with the back and yellow caps I ordered from Scott. At first, I didn't think they were Panasonics because all I saw on them in terms of logo was a fancy "M" that reminded me of Realtek's crab logo. Then I remembered "Panasonic" is just the American name for Matsushita in Japan. The one I was missing from the kit was the tiny one above the transformer. I'm thinking Gateway used stock that didn't have a cap there and some that did. The big fatty I left alone. One thing that did concern me was just above that heatsink in the center is a resistor with some discoloration underneath it. I was hoping it was just heat related instead of an actual burn spot.
                  The PLED hasn't flickered yet today -- gonna keep an eye on it though.
                  Other than that, it's a fantastic screen. Looks good in Windows XP, even better in Linux Mint 11 and Windows 7 ...
                  Just gotta get used to its 1440x900 native res all over again ...
                  • Hooker Jay
                    • Mar 2010
                    • 7
                    Sorry to for the thread necromancy, but after a year, Google pulled up my thread here, and I was lucky enough to remember my password!
                    The flickering power button was a fluke - it was actually the network activity icon inside WindowsXP's taskbar blinking the was the culprit!
                    Anyway, after 3 years of rock solid performance, a new issue has cropped up in the last month: the OSD/Menu in the lower right corner appears all by itself. Sometimes, it displays the "Menu" (i.e "Auto", "Brightness", "Color" and other times) but most of the time it displays the "Tour" dialog ...
                    Nevertheless, the OSD is coming on by itself - often times blinking on and off rapidly in succession. When it decides to stay on, it never disappears like it should after 5 seconds. It'll stay there for minutes/hours. Sometimes, pushing the "Menu" button on the side makes it go away for a while (only to come back), but most of time the buttons on the side won't even work. Nor the power button - when it's in this locked state, the power button won't turn the display off if it's been on for a while nor turn it on if it's been off (if the latter is the case, I gotta hold the power button in until it turns blue and fires up the display).
                    Haven't cracked the panel open yet - been trying different things like changing the broadcast channel of my wireless router (it sets about a foot away behind the display) to see if its not a case of electronic noise or interference causing it. This started happening all of a sudden a month ago, disappeared completely for two weeks, then cropped back up worse than before. I don't think its a case of a stuck/junk buttons - they've been messed with no less than a dozen times in the last 3 years. But I'm not ruling anything out and open to other causes: junk wires, cold solder joints, possible recap on the video logic board etc. ...
                    I do recall before ordering and using the recap kit from Scott way back then that a shop out in Texas stated that a temperamental OSD coming and going on its own was an issue with the Gateway FPD1975/6 and FPD2185 models and sold a replacement side button module and power button. For those familiar with these displays, the power button and PCB plugs into the side button module which then plugs into video logic board. Always thought it was a bit extreme having to replace all of that in case that happened ... and now that it has happened, I can't Google-fu that shop for the life of me! :o
                    Anyway, thanks in advance!
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      It's usually the buttons. Unplug the button strip with the monitor powered on and see if it still does it.
                      A working TV? How boring!
                      • themosttogain
                        HP Envy 13-BA1565na with intermittent power button
                        by themosttogain
                        Hope someone can give me some suggestions on this because i'm at my wits end with it...
                        I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                        Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                        07-12-2024, 03:03 AM
                      • TimeRabbit07
                        Asus FX517ZC charges but power button does nothing
                        by TimeRabbit07
                        Hi all!
                        I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                        Here are its various numbers and identifiers:
                        Model short: FX517Z
                        Model long: FX517ZC-HN114W
                        SN: NANRCX01S57842E
                        CN: 3SDB 12M
                        MFD: 2022-10
                        Motherboard model: DA0NJLMBAE0 REV E
                        Symptoms:
                        The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                        History so far:
                        The...
                        09-04-2024, 05:48 PM
                      • reessi
                        Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                        by reessi
                        With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                        No corrosion any where!
                        Tried a replacement power button off ebay and the same.
                        Very occasionally it will work with the power button connected!
                        Same results with or without the battery.
                        Can it be a fault with the Audio board or the mainboard?
                        The touch Id assembly connects through the Audio board first then to the Mainboard.
                        Flex...
                        06-26-2024, 03:31 PM
                      • x_orange90_x
                        Seven Leagues Slot Machine stop button issues
                        by x_orange90_x
                        I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
                        The issue now is the Stop buttons are intermittently...
                        02-12-2025, 10:01 AM
                      • dfear
                        HP 14-bf054sa - weird power button issue
                        by dfear
                        - forum postHP 14-bf054sa
                        LA-F301P Rev 1.0
                        This laptop came in with a number of minor issues (Screen with black bar and battery that needs replacing). The laptop also had issues relating to salt (water/air) corrosion, having been used near the ocean.
                        The HDMI port, 2x usb ports and the SD card reader all needed replacement as they had been affected by salty air and only work intermittently. The HDMI port, 2x usb ports and the SD card reader have been replaced and have been checked for (obvious) shorts.
                        The laptop now fails to turn on (normally)....
                        09-24-2021, 09:33 AM
