Dell 2005FPW with Two Seconds to Black
+ More Options
Posts
  • Mad al
    • Mar 2012
    • 8
    Hello
    I have a Dell 2005 FPW with solid power lights the Two Seconds to Black'
    I think is the general term,
    I have taken the model apart I can see on the power board there is a thing at T303 is brunt out.
    What is it? Will replaing this thing fix the Two Seconds to Black ?
    I know the caps may need replaceing even tho the caps look good.
    The brunt out part has ( IT20. 1 NY0541BC ) on top of it.
    Broard is a Dell 2005fpw inverter and power board YUYANG YP20106D REV 1.1
  • Jasgriff
    • Feb 2012
    • 578
    Re: Dell 2005FPW with Two Seconds to Black
    Its difficult to tell from that picture if it is actually burnt out. Do you have a Digital Multimeter to carry out some tests?
    Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
    How to resize your pictures guide click HERE
    Retiredcaps Ideal post example click HERE
    • jayoung
      • May 2011
      • 172
      Originally posted by Mad al
      Hello
      That is a transformer that drives the high voltage for the ccfl's (bulbs). It is one cause of 2 seconds to black along with many others. The following link is a guide to troubleshooting 2 seconds to black written by retiredcaps. Other issue include bad caps, bad ccfl's and / or wiring to the ccfl's, shorted transistors, etc.
      https://www.badcaps.net/forum/showthread.php?t=10419
      • Mad al
        • Mar 2012
        • 8
        Yes I do, It`s not a Fluke but it do the job.
        jayoung Thank you for the link.
        The Transformer has 2 by 6 pins I can only get readings from the side with 6 pins.
        Doing a reading on all the transformer I get the same readings
        1-2 .6, 1-3 NO reading, 1-4 .8, 1-5 .7, 1-6 NO reading,
        Looking at the board there is brunt mark under Transformer at T303.
        Looks like 1 is brunt and 2 have had heated up.
        I am haveing problems uploading the pic, will repost later tonight with pic.
        • Jasgriff
          • Feb 2012
          • 578
          Yeah another pic would be good.
          Can you also post us the exact reading that you have from your transformer tests so we can see if they are right.
          • Mad al
            • Mar 2012
            • 8
            Haveing the Digital Multimeter on 2k and doing a reading from the solder side
            The transformers have 2 x 6 pins and I have numberd them as below.
            1 2
            3 4 5 6 7 8
            Transformer T301
            A) black probe on pin 1, red on pin 2 = 1.
            b) black probe on pin 1, red on pin 3 = .963
            c) black probe on pin 1, red on pin 4 = 1.
            d) black probe on pin 1, red on pin 5 = 1.
            e) black probe on pin 1, red on pin 6 = .964
            f) black probe on pin 1, red on pin 7 = 1.
            g) black probe on pin 1, red on pin 8 = 1.
            _______________________________________________________
            Transformer T302
            b) black probe on pin 1, red on pin 3 = .992
            e) black probe on pin 1, red on pin 6 = .992
            the rest are 1.
            Transformer T303
            = 1. on all the pins!
            Transformer T304
            b) black probe on pin 1, red on pin 3 = .997
            e) black probe on pin 1, red on pin 6 = .997
            the rest are 1.
            Transformer T305
            b) black probe on pin 1, red on pin 3 = 1.003
            e) black probe on pin 1, red on pin 6 = 1.003
            the rest are 1.
            Transformer T306
            b) black probe on pin 1, red on pin 3 = .984
            e) black probe on pin 1, red on pin 6 = .984
            the rest are 1.
            The Transformer T303 is brun out, where can I find a replamet for it?
              If you take out that transfomer where the burnt spot is, you will more likely to see burnt winding on that transformer. You can see that the glue on that transformer had changed color due to the heat.
              • Mad al
                • Mar 2012
                • 8
                3 transformers glue have changed color due to the heat.T301,T302,T303,
                I do not know where to get replacemets transformers from (IT20. 1 NY0541BC) ?
                • sweetdaddyjones
                  • Feb 2014
                  • 7
                  So, I have the same monitor with the same problem--one of the transformers is burnt, just like in the picture above. Even if I were to find a replacement transformer, successfully desoldering the old one and installing the new would certainly be nerve-wracking for me (to say the least lol)....but I have another idea: can I just wire a ccfl inverter from a laptop to the 12v, 5v, and GND inside the LIPS, connect the backlight to that, and bypass the blown transformer entirely? Is this a bad idea?
                  • HTR-Informatique
                    by HTR-Informatique
                    02-09-2025, 06:51 AM
                  • ChIck3n
                    Dell u2311h 20000 seconds to black issue
                    by ChIck3n
                    So I've had this monitor for probably a decade now, and it's finally starting to fail. Began with a little sporadic flickering, then eventually started going black (power LED stays blue, can still see image on screen with flashlight). A power on/off fixes it for a bit, but then it happens again. Once it got to the point I was dealing with this every few minutes, I opened it up and just replaced all the caps (minus the big one) on the power board with new Panasonic ones. All the old caps tested fine on an ESR meter, and this worked for 5 days. But the screen just went black again today, so...
                    09-09-2024, 11:44 AM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • jake-b
                    dell e6540 boots to black screen (no dell logo)
                    by jake-b
                    good morning all,
                    i purchased a used dell e6540 laptop used 10 months ago from a vendor on ebay. intel i-7 processor, 16 gb ddr3 memory, 256 gb ssd., mobo la-9413p (rev 1.0 dated 2014-08-04). i've inflicted no damage on it since purchase but its past is unknown. starting 2 weeks ago it began to fail to boot (initially 9 of 10 boot attempts failed, now 10 of 10 fail). there was no new hardware or software added (i was using as a kodi video server). the post process doesn't complete and booting no longer displays the dell logo screen - screen remains black with no backlight. some other...
                    01-08-2024, 10:29 AM
                  • hcinne
                    Dell G15 ryzen edition black screen 2 amber 1 white
                    by hcinne
                    I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                    07-23-2024, 07:56 AM
