Viewsonic VX2235wm-5 _ Will not power up.
  • hairykiore
    • Mar 2012
    • 83
    • New Zealand
    Re: Viewsonic VX2235wm-5 _ Will not power up.
    OK......T3.15A 250CQ.....The AC cable goes right over it and I would never have seen it without the nice bright sun outside and a headband magnifier....Unfortunately I think the board position # is covered with a white gue but there is a T103 nearby ..But that may refer to the next component ....However ? and I hope I am correct here ..there is no way I can actually measure the fuse (s) with a multimeter unless I take the Power Board off ....and I presume that if I take the four screws out ,the board will lift off and disconnect itself from the circuit board ....If I am correct is there anything to be wary of before I do this ....and if there is could I please be advised... I can then do the fuse check etc and post the results ...Thanks
    • Jasgriff
      • Feb 2012
      • 578
      Yes you will need to unscrew the board and check the fuse from the bottom.
      Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
      How to resize your pictures guide click HERE
      Retiredcaps Ideal post example click HERE
      • hairykiore
        • Mar 2012
        • 83
        • New Zealand
        OK..The Power board is off so am checking fuse now..Ron
        • hairykiore
          • Mar 2012
          • 83
          • New Zealand
          OK..I could not find anything that resembled a second fuse on the underneath of the power board...I have two identical cheap multimeters and get the reading across the fuse of 02.2 on one and 02.5 on the other..So presume its ok so will move onto the next text..(#3)
          I will put Power board back on ...Just one question to show my ignorance ? for the test below does the unit have to be powered up??
          Thanks Ron
          3) If both fuses are good, then set your multimeter to 20V DC. Put your black probe onto a ground screw. Put your red probe on the connector pin between the two boards that is labeled +5V. What is the reading?
          • retiredcaps
            • Apr 2010
            • 9271
            It may or may not be there. Some versions of this Delta board have it.
            You didn't provide photos of the backside so we don't know.
            The reading of 2.2 and 2.5 ohms suggest your fuses are good. However, it likely that your probes are falling apart internally. A good set of probes when shorted together should read less than 0.4 ohms.
            Yes.
            --- begin sig file ---
            --- end sig file ---
            • hairykiore
              • Mar 2012
              • 83
              • New Zealand
              #26
              I actually took a photo and then wondered about attaching it so here it is attached.Each photo I take is coming in at just over 2mb so I resave it in another program and its reduced to round 500 Kb ??
              BTW I am still struggling with my camera and getting the photo...My probes shorted together 0.3 on one and 0.2 on the other ...They are cheapos IE 2 for one in a package at the local Electronic Shop...
              Now This indicates to me that I can now go ahead and powerup and do the #3 20V multimeter test ground to 5v..?? while its outside in the sun..Thanks Ron
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                You have 2 more fuses (F101 and F200) on the backside of the board. They are marked with red spray paint.
                • hairykiore
                  • Mar 2012
                  • 83
                  • New Zealand
                  #28
                  Hi ..the reading is flucuating between 0.05 and 0.10....The multimeters I have are probably inferior to what is required so a reasonable multimeter is on my shopping list....I hope the readings help..Ron
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    They readings indicate there is no power. Check fuses F101 and F200 before buying a new multimeter (see post 27).
                    For the fuse check, make sure your multimeter is on the 200 (two hundred) ohm scale.
                    • hairykiore
                      • Mar 2012
                      • 83
                      • New Zealand
                      #30
                      OK..retiredcaps..so grateful to see marked photo.....F101 shows nothing on both multimeters while F200 shows 0.07 on one and 0.08 on the other multimeter..so that seems to me we have a fuse problem with F101 but whats causing it....?? Ron
                        F101 feed the Logic board, F100 feeds the Inverter circuits, so you may have shorts circuits on the main board. Put meter in Ohm mode, black lead tot eh chassis, red to the top end (this end is connected to the multi-pin connector) of the F101 fuse as shown in your picture, take the reading.
                        • hairykiore
                          • Mar 2012
                          • 83
                          • New Zealand
                          #32
                          OK Sorry I fell Asleep?? As I understand I set my multimeter at 200 Ohm and take a reading ..Now as I see it this will have to be done with the board removed??...I put my red lead to the end of the F101 fuse connected to the multi pin connector ....and the black lead to the chassis which would be ground?? Right.....so I would get the same result putting the black lead to the ground on the board where the screws hold the board in place (as marked on photo attached ) or am i missing something ..Thanks Ron
                          • hairykiore
                            • Mar 2012
                            • 83
                            • New Zealand
                            #33
                            Budm..Please..I need some guidance on how to actually acomplish this ...Thanks Ron
                            • hairykiore
                              • Mar 2012
                              • 83
                              • New Zealand
                              #34
                              OK..There is no reading ..I put the black lead of my meter set at 200Ohms to the corner of the power board (or is it inverter board) where it would connect to the chassis if it was actually screwed onto the chassis and the red lead I put to the F101 Fuse at the end nearest the 8 pin connector.....Its Dead ..there is no reading from either of my multimeters..Ron
                                OK, that is good, next thing to do is to get 1/4 Watt 1 or 2 Ohms resistor and solder it in place of the blown F101 fuse, you do not even have to remove the fuse, just solder it carefully on to the old fuse and see if it will turn on now. Worst case it just blow the resistor, we are just using resistor as a fuse for now to test.
                                • hairykiore
                                  • Mar 2012
                                  • 83
                                  • New Zealand
                                  #36
                                  Hi...I do not have the inverter board actually installed in the monitor...Plus I do not want to be a nuisance but I have hundreds of new resistors but I cannot find the colour code for a 1/4 watt 1 or 2 ohm resistor....I can of course buy one but its about 3 miles away at the other sude of the city and I only have a bicycle...??Ron
                                  • Jasgriff
                                    • Feb 2012
                                    • 578
                                    Take a look here
                                    http://www.elexp.com/t_resist.htm
                                    • hairykiore
                                      • Mar 2012
                                      • 83
                                      • New Zealand
                                      #38
                                      I have found what I think is a Brown-Black- Blue ....Gold Resistor But I am colour Blind so will attach a photo??? Sorry photos are no good? Its actually too hot here today to bike 6 miles to a shop for a resistor?? Ron
                                        If you are brave enough, you can try using a very small jumper wire to bypass the fuse for now. Or put your meter in DC AMP (set to 10A) mode and use the correct probe input ports for AMP, then touch the two ends of the fuse with the meter leads then see if the monitor will come on, then you can also see how much current the logic/control board is drawing so we can figure the size of the fuse you will need. just make sure the probes touch the fuse's ends only and NOTHING ELSE! This will be difficult since you need to put the board back in place.
                                        • hairykiore
                                          • Mar 2012
                                          • 83
                                          • New Zealand
                                          #40
                                          No NO? I have just returned from my bike ride with a packet of 1.2 ohm resistors....So I need a lie down? But I think you have already answered my next question ....and that is how neatly does the resistor have to be put across the fuse cause this will be determined by whether the power board is either left out or has to be put in....By your previous post I believe the inverter board has to be put back on the chassis so will solder the resistor across the fuse as neat as possible..at least I have found out who apparantly services Viewsonic in the city ( for a fuse or any part ) so I did learn something...Thanks Ron..
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
