Samsung 710n bad image
+ More Options
Posts
  • giorgio130
    • Mar 2012
    • 7
    • Italy
    Hi all! first post
    I have bought a used Samsung Syncmaster 710n, it worked fine for about a day then the image went bad, as you can see in those pictures:
    http://*************/photo/my-images...225180753.jpg/
    http://*************/photo/my-images...225183427.jpg/
    I was not present when it happened, but I know that it was connected with a bad cable (such as moving it changed from a perfect image to a purple tint), and the power cord was wrongly attached such as ground was not connected. I don't know if that information is useful but better giving more
    What I'd like to know is if it's easily fixable, if it comes from bad caps or what... It's the first time I try such a repair!
    Thanks for your attention!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Samsung 710n bad image
    For a number of reasons, I prefer that you upload your photos using the manage attachment feature.
    Please post clear focused top down view pictures of all your boards (both sides) following the instructions in my sig file below EXACTLY.
    --- begin sig file ---
    --- end sig file ---
    • jayoung
      • May 2011
      • 172
      Check the following thread as it might be a similar issue:
      https://www.badcaps.net/forum/showthread.php?t=18809
      I posted pictures of my screen (Samsung SyncMaster Model 731N) and the issue turned out to be a faulty 1.8V voltage regulator on the signal board.
      • giorgio130
        • Mar 2012
        • 7
        • Italy
        Thanks for the replies!
        @retiredcaps: I already uploaded these images for using on another forum, and deleted them from my computer. If it's that important I can download them and reupload here. As for the boards photos, it will pass some time since I don't actually have access to it right now.
        @jayoung: yes it's quite similar! Thank you... the difference is that the osd is equally distorted (as you can see in the first image)
        • Jasgriff
          • Feb 2012
          • 578
          giorgio130 as you can see by the post that jayoung highlighted the clear picture of the signal board allowed us to see exactly what you are dealing with. Without good clear pictures it takes a lot longer to talk things through and at worst some people might skip through the post and move on to the next one.
          when you say you had a bad cable are the pictures you have uploaded show the image with a new cable?
          is the socket loose in anyway as in does the screen have a funny tint when you move the new cable?
          other than that in order to help you try and fix this monitor you will need to open it up and take some good pictures. You also mention that this is the first time that you are to attempt a repair. Do you own a multimeter and a soldering iron?
          Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
          How to resize your pictures guide click HERE
          Retiredcaps Ideal post example click HERE
          • giorgio130
            • Mar 2012
            • 7
            • Italy
            The pictures were taken using a new working cable, so it shouldn't be the cause. I've got a soldering iron and a multimeter, I should be able to go through the steps required to replace a bad cap or identifying a failing component. I'll be able to disassemble the unit in a couple weeks, maybe I should have waited before posting but I thought that maybe someone could give me directions based only on the symptoms.
            • giorgio130
              • Mar 2012
              • 7
              • Italy
              After about forever, I'm back with the photos of the board
              I didn't take those of the power board because I've swapped it with one that I know for sure it works, and the symptoms persist.
              Thank you for your directions!
              • selldoor
                Slow Learner
                • 7870
                Thats a bit odd id have expected voltage regulators at
                IC 502 and IC 602 was there never anything on those pads, perhaps they have used different type
                what are the part numbers on IC600 and IC501 and IC201 and
                IC 106.
                Check the data sheets and if they are voltage regulators see this on how to test.
                https://www.badcaps.net/forum/showthread.php?p=261329
                • giorgio130
                  • Mar 2012
                  • 7
                  • Italy
                  IC106: 5AG4? 5A64?
                  IC201: A81SC-Q530
                  IC600: PF4AG FDS 9933A
                  IC601: APL5522-AH70E
                  No IC501, or at least I couldn't find it. I'll check the manuals.
                  • giorgio130
                    • Mar 2012
                    • 7
                    • Italy
                    http://www.datasheetdir.com/APL5522+LDO-Regulators
                    I could not find some of those so there could be more VRs.
                    I'll check it out.
                    • giorgio130
                      • Mar 2012
                      • 7
                      • Italy
                      I turned it on and it suddenly worked! No problem at all! Maybe some bad cable connection.... Thanks for your help
                        09-07-2024, 05:50 AM
                      • rattlesnake
                        Samsung SyncMaster 955DF dim image fix
                        by rattlesnake
                        This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
                        To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
                        08-12-2023, 07:03 PM
                      • shlomim412
                        samsung ua55es6800 - no image
                        by shlomim412
                        hi
                        having problem with samsung ua55es6800
                        tv had backlight on, sound working - responds to the remote control but no image.
                        check tcon board - had 12v in but no other voltages present.
                        when disconnected left ribbon cable - got back voltages and half image with lines and distorsion
                        when leaving only left side connected - again no voltages and no image.
                        put a tape on all (cd?! lines) on the left ribbon cable and got complete but distorted image (horizontal lines).
                        kept trying to block less pins on the left ribbon cable...
                        05-15-2024, 05:00 AM
                      • soopacrucial
                        by soopacrucial
                        Hi folks,
                        10-29-2024, 02:40 PM
                        09-06-2024, 11:40 PM
