Asus MM17D no power
  • senndogg
    • Dec 2011
    • 383
    • Albania
    Asus MM17D no power
    i have this 17inch old monitor which doesnt even light the led. i inspected the circuit, no blown fuses, the caps seem good. i get 11V and 3V from the main rails of the circuit. is this normal?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Asus MM17D no power
    If this is on the power board, 11V and 3V are not normal voltages. We tend to see 12V and 5V. 5V usually found on every monitor for standby.
    Most power boards have their input and output rating written right on the pcb.
    --- begin sig file ---
    --- end sig file ---
    • senndogg
      • Dec 2011
      • 383
      • Albania
      true. thats why i figured this out. there is nothing written but i know that the voltage could be the problem.
      i measured: the secondary diodes: ok. fuses:ok. big resistors:ok.
      the caps seem good too.
      if you want i can post pics.
      • retiredcaps
        • Apr 2010
        • 9271
        See instructions in post #2 on how to post pictures and size limitations. Please do not post inline or offsite.
        • selldoor
          Slow Learner
          • 7870
          This ASUS MM17T might use same similar boards (Are They?)
          it has DVI in whereas 17D doesnt.
          • senndogg
            • Dec 2011
            • 383
            • Albania
            of course i will.
            anyway it is very strange, i just re-measured the voltages, 12,6V and 4,9V. now its confusing me. this voltage is in the logic board too. and 4,9V in the switch board. but the LED doesnt light and there are no signs of life.
            • senndogg
              • Dec 2011
              • 383
              • Albania
              now i am suspecting it not a a power supply problem. i am gonna show some pics of the logic board.
              • selldoor
                Slow Learner
                • 7870
                This chap here seems to have fixed one but of course we dont know what the problem was. http://mypaper.pchome.com.tw/88182846/post/1322648181
                How is your taiwanese.
                • senndogg
                  • Dec 2011
                  • 383
                  • Albania
                  some pics.
                  • senndogg
                    • Dec 2011
                    • 383
                    • Albania
                    i do well in Mandarin but no good in traditional Han :P
                    • selldoor
                      Slow Learner
                      • 7870
                      I have google translated the captions - doesnt help much but i notice
                      he has changed the Blue caps on the logic board so that might be somewhere to start.
                      This is today just repaired LCD, due to bad too! PO to share it out first!
                      Look at its form according to:
                      After the failure of black and white picture ─ start!
                      Posted a good few warranty stickers, I do not know the previous repair a few times?
                      Internal configuration of photographs:
                      First those who do not burst! Have all the updates for the capacitor explosion at Japan's! ! Then the back of the solder joints to strengthen!
                      Unfortunately! Transmission test! Or black and white!
                      Just on top of the machine's motherboard, you have already seen an explosion convex sesame burn it?
                      I did not see the previous note ㄋ! Then it is replacing!
                      I have first measured ground resistance, OK after the power transmission!
                      Otherwise! Here you are not measuring the voltage! Because if it is not OK! Transmission will immediately be burned!
                      5V voltage side that has come TCON-side:
                      Unfortunately! Still black and white!
                      Up into the TCON! Remember just PI board; AD board has been processed! Again ~! The TCON
                      CPT for the CPT panel referred to!
                      Here is the main power supply position TCON:
                      TCON fuse has been open! In addition to the other, measure the resistance to ground on both sides of chip capacitors are turned! There are short-out parts!
                      The TCON from the cut section to find a suitable SMD capacitors, and Fuse replacement!
                      Two-to-ground resistance are ok! Transmission test again!
                      This time the ok now! There was almost a fool! Because in addition to asus's logo, the other is black and white!
                      Display to normal! Motherboard then locks back into the side of the motherboard power supply capacitors further updates!
                      Well! Finally done! pi plate bad! Board also bad! Again tcon also failed! It is a bad lot it!
                      • senndogg
                        • Dec 2011
                        • 383
                        • Albania
                        yes. i m going into.
                        • jetadm123
                          • 2169
                          Suggest you start by measuring the output of the voltage regulator U202, It's marked AIC 1084-33 and should have an input of 5v and an output of 3.3V. I'm not sure what U201 is, but it wouldn't hurt to also measure it's voltages.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            U201 is a 1.8V regulator. The part number is AZ1117-1.8E1
                            • senndogg
                              • Dec 2011
                              • 383
                              • Albania
                              confirmed, U201 input 4,05V, output 1,77V.
                              U202 input 4,7V output 3,22V.
                              i repeat, this monitor doesnt give signs of life.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                What is the part number of U603?
                                PlainBill
                                • senndogg
                                  • Dec 2011
                                  • 383
                                  • Albania
                                  "SPY9". its the transistor between the two freq generators, isnt it?
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Not exactly. It's between the two crystals, but it's a reset controller. With power applied, what is the voltage on each pin?
                                    PlainBill
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      Its a MAX810 Datasheet attached
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Thanks for confirming it. I drew a blank on that one. Probably too early in the day.
                                        Senndogg, I've attached the pinout of U603. What is the voltage on the output, using the Gnd pin for the black lead?
                                        PlainBill
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • TimeRabbit07
                                          Asus FX517ZC charges but power button does nothing
                                          by TimeRabbit07
                                          Hi all!
                                          I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
                                          Here are its various numbers and identifiers:
                                          Model short: FX517Z
                                          Model long: FX517ZC-HN114W
                                          SN: NANRCX01S57842E
                                          CN: 3SDB 12M
                                          MFD: 2022-10
                                          Motherboard model: DA0NJLMBAE0 REV E
                                          Symptoms:
                                          The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
                                          History so far:
                                          The...
                                          09-04-2024, 05:48 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
