Blown Photocoupler
  • gustav
    • Nov 2011
    • 80
    Blown Photocoupler
    I recently replaced my power supply board and the photocoupler blew its lid. Replaced it with another one from the orginal board and now no power or power light. On the output pins, there is no voltage showing on the PSON. So far, the fuse tested good, and getting dc voltage from the big cap.
    During the testing phase of the new board, the metal cover was loose and may have shorted the board, thus blowing out the coupler. That's one theory. Of course there might be other reasons for the blowout.
    Any suggestions from the wise and experienced would be appreciated.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Blown Photocoupler
    Trace the circuits and replace any defective or damaged components.
    PlainBill
    • gustav
      • Nov 2011
      • 80
      The monitor is toast. DOA. Opened up the screen panel today and two of those film thin ribbon cables were torn. Someone had pryed open the metal casing using a screwdriver ripping them. No sense in pursuing this endeavor anymore. At least, I could have sold the panel, but now that's not happening.
      Thank you all for the site and sharing your wisdom
        master hoarder
        • May 2008
        • 12175
        In that case, open up the panel and scavenge the CCFLs. You never know when you'll run into a monitor with bad ones. They can be also very useful when testing an inverter of another monitor.
        • gustav
          • Nov 2011
          • 80
          Thanks momaka. I calmed down and decided to continue to work/play with the board abit more. And your right. There are some parts in there, since it is a 28", that will be of some use. This is a golden opportunity to learn more of the circuitry without the pressure to get it right. I am sure in the near future, there will be a broken lcd up for sale that's cheap and will be easily repairabel. The glass is half filled.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • cmlewis89
            LG 47LB5DF blown power supply board
            by cmlewis89
            Hi folks,
            I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
            09-03-2024, 07:50 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • odtech
            Asus UX490U laptop blown (caps?) on power board.
            by odtech
            Greetings friends.
            I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
            I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
            Any guidance...
            08-06-2023, 10:29 AM
