Replacing CCFL tubes in double tube assys.
  • EdDataFix
    • Mar 2011
    Techs;
    Has anyone have pictures/video of removing the tubes in double ccfl
    assemblies ? Most of my repairs are inverters and unsoldering single lamp
    assemblies is no problem. If I need a double ccfl tube assy. I usually have
    used ones from junkers.
    Do must techs just buy these double tube assemblies to forego unsoldering/soldering new tubes?
    Thanks EdDataFix
  • Rtech
    • Jul 2010
    • 1095
    Re: Replacing CCFL tubes in double tube assys.
    I have not seen, complete in their channel,new double tube assemblies for sale anywhere,and here in the UK I think there is only one supplier of 'bare' bulbs, and in a lot of cases it makes the repair totally uneconomic,by the time you add P&P and Tax(VAT).Certainly after asking LG the question, they say they do not supply replacement,fully wired, Backlight assemblies
    • EdDataFix
      • Mar 2011
      http://www.davandisplay.com/index.ph...hbjatvrnurp246
      Carries wired up assemblies minus the metal reflector . Others accept mail in repairs of the the full ccfl assy.
      Do you repair double tube CCFL assemblies ?
      EdDataFix
      • retiredcaps
        • Apr 2010
        • 9271
        Another alternative
        http://www.ccflwarehouse.com/17setof2ccdu1.html
        --- begin sig file ---
        --- end sig file ---
        • EdDataFix
          • Mar 2011
          The following site has the pictorial replacement/soldering of dual lamp CCFL assy.
          I always had problems of removing the rubber end holders. The lamps would break on
          me which is why I use an exhaust fan when I work on these.
          http://www.ccflwarehouse.com/lasotu.html
          • retiredcaps
            • Apr 2010
            • 9271
            Sorry I forgot to provide that link for you.
            Alexanna is the king of this type of repair.
            This person has repaired 40 of them so far (out of 60). See
            https://www.badcaps.net/forum/showthread.php?p=201289
            • ttmi100x
              HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
              by ttmi100x
              Greetings everyone,
              I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
              The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
              Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
              Upon closer inspection...
              07-31-2024, 06:36 PM
            • DCJack
              B&K 707 tube tester. I need help.
              by DCJack
              Hi everyone!
              I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
              Initially I noticed that I was not getting the red on-light to turn on, but it...
              03-05-2024, 05:05 PM
            • mikey5791
              Help on Samsung Syncmaster T220 dead ccfl lamp
              by mikey5791
              This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
              Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
              10-18-2020, 03:17 AM
            • howardc64
              TCL 49S405 double image
              by howardc64
              LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
              This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
              06-23-2025, 03:20 PM
            • Topcat
              Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
              by Topcat
              This was rescued from a recycle gaylord from a hospital along with some other things....
              I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
              Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
              08-02-2023, 10:07 PM
