Advice sought on repairing a Belinea 101902 Monitor
  • garyhodgson
    • Dec 2011
    • 6
    I'm trying to repair a Belinea 101902 Monitor (Art#111916) and would like to ask the forums advice before I send off for the spare parts I think I need, or whether the monitor is perhaps beyond repair.
    When it is turned on, the power button is green for approx. 5 seconds and then it appears to restart, i.e. turn off briefly and then back on, and then repeats. When I had a laptop hooked up I saw a very brief, and faint, overlay which I believe was the "No Signal" because I perhaps didn't have the dual-screen mode in Ubuntu on correctly.
    When I opened the back I saw one cap on the display board was definitely blown (C58, 16v/330uF) and I suspected the large cap on the power board was also blown (C114 400v/100uF). After reading some of the posts in this forum saying that the large caps rarely blow I decided to replace the c58 - largely because I had a spare laying around - however the problem still persists and so I will order a replacement fot the C114. Looking closer. I think there is electrolyte at the base of one of the pins, so I am pretty sure it's blown.
    My concern is that the inductor (?) next to the C114 capacitor (L111) seems to also be damaged. The photos attached should give a reasonable view of it.
    I've only dabbled in electronics and I am not too sure how to go about taking measurements on the live circuit to determine if this component is damaged or not. If anyone could give me a hint where to start I would be most grateful.
    And if anyone could glance over the circuit photo and suggest other components that may need replacing before I send off my order that would also be really appreciated.
    If I've missed any critical information i'll be happy to add it.
    Many thanks,
    Gary
  • mariushm
    • May 2011
    • 3799
    Re: Advice sought on repairing a Belinea 101902 Monitor
    Yeah, the large capacitor definitely needs to be replaced but that's not a fix, you need to fix what caused the large cap to go bad.
    I would also be concerned about that glue they used that turned black - it may become conductive when it warms up, which may explains the resets.
    I see what looks like glue right under the bridge rectifier (the thin rectangle between the inductor and heatsink - could try to test if the rectifier still works by measuring the dc voltage it outputs.... it should be the same as probing the two leads of the large capacitor.
    I see more of that stuff on the small ceramic capacitor and a bit above that, where it's a diode or something... I'd clean it up and rub the terminals with isopropyl alcohol or something just to make sure they're not shorted.
    The inductor doesn't look that bad to me... looks more like overheated plastic. But it could be bad.
    • retiredcaps
      • Apr 2010
      • 9271
      The big cap is definitely bulging. I use the phrase "rarely, but not, never" when talking about the big cap.
      With the big cap, I count 6 electrolytic caps in total on the power board. I would recommend replacing all 6 since they have in service for nearly 7 years.
      Your power board has signs of running really temperature hot from all the white glue turned brown and pcb discoloration so it wouldn't suprise me if some of the caps on the power board are dry, but not bloated. Remove all the brown glue as mariushm suggests.
      Capacitors die from age, heat, and shoddy build quality. Capacitors DO NOT have to be visibly bloated in order to bad. They can be out of tolerance uF (a 1000uF measures 20uF) and/or have high ESR (ohm). A multimeter will be insufficient to test for ESR. For that you need an ESR tester which costs between $50 and $300.
      Most members here will recommend that you replace ALL capacitors with reputable brands from reputable sellers. Brands like Rubycon, Panasonic, Nichicon and United Chemicon are suggested. A list of recommended caps can be found at
      https://www.badcaps.net/forum/showthread.php?t=2280
      Here is an example of how to choose capacitors with respect to capacitance, voltage, diameter, height, ripple and ESR.
      https://www.badcaps.net/forum/showpo...4&postcount=19
      --- begin sig file ---
      --- end sig file ---
      • PlainBill
        • Feb 2009
        • 7034
        The inductor (L111) looks bad in the first picture, but in the last picture it appears to be varnish.
        PlainBill
        • Scenic
          o.O
          • Sep 2007
          • 2642
          The primary cap (the biggest one) is definitely bad. Bulging at the top and bottom, and electrolyte has been leaking out on one of the legs (last pic).
          Like retiredcaps said, I'd replace all the caps in there, seeing how hot it runs/ran.
          It was probably on 100% brightness (factory default) for its whole life..
          If you want to take the "crude but effective" way, you can modify the monitor to use an external 12V 3+A PSU brick if you want to (if the inverter is still OK)
          You could also do that modification temporarily to verify the signal board / mainboard is OK.
          The connector between the PSU and the mainboard should be labelled as to which pin is what. You could use that to "inject" 12V at at least 3A to see if it fires up.
          Alternative way would be to remove one of the output caps on the PSU board (all 4 caps are in parallel on the 12V output) and solder wires in place for testing.
          Try replacing the caps first. If it turns out to be a more in-depth problem, you could still use the external PSU method.
          • garyhodgson
            • Dec 2011
            • 6
            Thanks for all the suggestions, I will certainly take them on board. I'll make the order for all the caps and clean up the board too.
            I'll update once the order arrives and I get them in place.
            Cheers!
            • klkmalik
              seeking Tips
              • Nov 2011
              • 68
              • UAE
              you can use from old notebook adaptor component such as, cap 100/400v and inductor
              and more i am using this way.
              • Borse2008
                Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
                by Borse2008
                Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
                I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
                • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
                • There’s
                07-15-2025, 04:55 AM
                by momaka
                03-15-2023, 10:17 PM
              • wattage
                AOC AG493UCX 49-inch monitor - Firmware request
                by wattage
                Hello Badcaps Community,
                The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                07-13-2025, 04:41 PM
              • ant3202
                HP 27es - LED monitor - Monitor Flashing On - Off
                by ant3202
                Hi Everyone
                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                https://www.badcaps.net/forum/troubl...lashing-on-off
                The monitor is HP 27es LED Monitor
                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                The monitor will randomly blackout and display no signal and will recover again.
                Sometimes need to power and off again to restore the display but...
                03-20-2025, 07:30 PM
              • Rick_1234
                LG 23MP55HQ LED Monitor turns off after a few seconds or flickers.
                by Rick_1234
                Good evening, gentlemen.
                I have a problem with my monitor. It turns off after a few seconds or flickers. Shining a flashlight on the screen doesn't show any image, so I guess it's not the "2 seconds to dark" I read in the forum.
                To turn it back on, I have to press the power button twice. Then after a few seconds it turns off again or flickers. See video.
                https://drive.google.com/file/d/1L6S...ew?usp=sharing
                Things I tried
                - Bought a new AC adapter thinking that was the problem but the problem...
                06-22-2024, 04:44 PM
