SCEPTRE X9G Naga V water around screen border
  • wilsoncomputer
    • Dec 2011
    This is my first post here. And I just replaced caps on my 2nd monitor (this SCEPTRE X9G). The 1st monitor went very well thanks to the great info I have learned from these forums!
    The SCEPTRE monitor would not power on at all, so I took it apart and found 2 swollen 1000uf 16v caps. I replaced them both, and they were the only 2 of that same type on the board. The monitor powers on fine now with the new caps, but I must have messed something else up since there is this weird looking layered (like a topography map), cloudy or wet looking border all the way around the screen. Almost like a border you would add around a picture. Any ideas what would cause this?
    I took several pictures of it, but none of them do justice. The best one is attached here.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: SCEPTRE X9G Naga V water around screen border
    Try cleaning and reseating all your connectors?
    --- begin sig file ---
    --- end sig file ---
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Looks like the layers of the LCD are separating.
      Mann-Made Global Warming.
      - Dr Seuss
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • dbuergi
        Macbook A1466 820-00165A heavy water damage but working with "flashing" screen
        by dbuergi
        i got a A1466 with serious water damage. I was able to clean the whole board and only found a fuse with a coroded trace. Cleaning and resoldering did the job and the macbook started normal but after some time the screen began "flashing" like turning on and off while the Macbook was still running. I checked the board again but was not able to find the problem until now.
        Any ideas where to look?...
        11-07-2024, 10:57 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
