Dell E172 blinking power LED
+ More Options
Posts
    Have seen a Dell E172 next to me, the green power LED is blinking every second. (It's on maybe 10% and off 90%.) Backlight sometimes flickers in time with the LED. But otherwise dead. Seems okay in standby, glows orange continuously. Suspect bad caps, any idea on the fault for this model?
  • alexanna
    • Mar 2010
    • 1346
    Re: Dell E172 blinking power LED
    If there is a fuse for the inverter remove it,How dose the PLED behave?
      I just saw a similar thread about this monitor, regarding the driver transistors. If I can get hold of it (and that depends if my clueless IT department doesn't just throw it in the dump) then I will see about replacing those transistors.
      • trebo
        • 514
        • Wales, UK
        bad caps
        bad solder on the inverter, especially the 4 transformers, it can cause the failure of the transistors + mosfets and they will take out the inverter pico fuse
        common failure of those benq boards
        • PantherDave
          by PantherDave
          Hi all!
          I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. πŸ˜…
          05-29-2024, 02:01 PM
        • noipi
          DELL INSIPRON 14 No power blinking orange/white
          by noipi
          i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
          05-06-2025, 08:08 PM
        • Mark01
          Dell Optiplex 7490 AIO - red power led after flash
          by Mark01
          Hi guys,
          This is my first post! πŸš€
          I have no idea what I’m doing, but I’m learning by trial and error.
          I’m currently working on a Dell Optiplex AIO 7490β€”one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
          07-04-2025, 12:54 PM
        • zlr8r
          Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
          by zlr8r
          hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
          Ill try and give as much info as I can.
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          When I received this , it would only flicker on the KB backlight for a second, then off and on.
          Then it started getting weirder!
          Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
          12-12-2023, 09:31 PM
