Have seen a Dell E172 next to me, the green power LED is blinking every second. (It's on maybe 10% and off 90%.) Backlight sometimes flickers in time with the LED. But otherwise dead. Seems okay in standby, glows orange continuously. Suspect bad caps, any idea on the fault for this model?
Dell E172 blinking power LED
Re: Dell E172 blinking power LED
I just saw a similar thread about this monitor, regarding the driver transistors. If I can get hold of it (and that depends if my clueless IT department doesn't just throw it in the dump) then I will see about replacing those transistors.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
bad solder on the inverter, especially the 4 transformers, it can cause the failure of the transistors + mosfets and they will take out the inverter pico fuse
common failure of those benq boardsLast edited by trebo; 12-12-2011, 01:01 PM.Comment
Assuming...7 Photos -
by PantherDaveHi all!
I'm trying to troubleshoot a Microsoft Surface Pro (5th gen) model 1796 that won't power on. Motherboard model is M1007506-015. My priority is retrieving data, but the SSD is integrated so it looks like if I can't repair it it'll need to go to a data recovery company. I've done a little basic board repair before, but nothing this advanced until now. So please forgive my ignorance in advance. ๐
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by noipii have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
by kjchatmanwhen it's plugged in the PCH glows under the thermal camera and the battery charges. the coil PLG1 for +vccin_aux reads 1.8v09-09-2025, 08:04 PM
by Mark01Hi guys,
This is my first post! ๐
I have no idea what Iโm doing, but Iโm learning by trial and error.
Iโm currently working on a Dell Optiplex AIO 7490โone of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...07-04-2025, 12:54 PM - Loading...
