Samsung Synchmaster 2693HM WHITE SCREEN
    Re: Samsung Synchmaster 2693HM WHITE SCREEN
    Yes they look okay to me as well.
    Next, measure the voltages on these rails. For ground, you can use any metal part of the monitor's case.
      Hi!
      I hope that it is ok, that I'll post with my Problem in this thread too. If not tell me and I'll opend a new one.
      I have got a 2693HM which starts only with a white screen. I knew before I read this thread, that my fault comes from T-CON board.
      I already measured the resistances between the testpoint and their voltages:
      VEEG 41,8k / 0,385V
      VDDG 304 / 0V
      VDDD 141 / 3,325V
      VDDA 5,7k / 0V
      5V supply voltage is ok.
      And I can't find any blown tracks on the PCB.
      I hope you have got also some tipps for me and we three can fix both monitors!
      Regards
      Chris
        VEEG 41,8k / 0,385V
        VDDG 304 / 0V
        VDDD 141 / 3,325V
        VDDA 5,7k / 0V
        Resistances seem okay, but the voltages for VDDA, VDDG, and VEEG are all gone. Without VDDA, VDDG and VEEG won't come on either.
        Measure the resistance for all of the small ceramic capacitors to the right of IC301 and IC302 (those RAM chips).
        Since your board my be slightly different, it is advisable to post some pictures of your board. At this point, I would say open a new thread, just so that we don't confuse which member had which problem with their t-con.
          Sorry for too long delay.
          Here are the readings:
          VDDA 5,9K / 13,12V
          VDDO 1,5k / 3,3V
          VEEG 41k / 7V
          VDDG 100k / 27,4V
          Regards!
          Leo
            Those readings seem good. Not sure what's wrong with the t-con then (if anything).
            Just out of curiosity - was VEEG 7V or -7V when you measured it?
              @momaka
              yes the VEEG is -7V, is these ok or wrong?
              Regards!
              Leo
                i took a look at the pdf and the VEEG in -V so the T-con is ok.
                Why then white screen?
                Regards!
                Leo
                Originally posted by OncleOh View Post
                @momaka
                Regards!
                Leo
                  The voltages are right.
                  My only guess would be if the video signals are somehow not getting to the t-con board or if the video/logic board is not sending any. That's a bit above my level of troubleshooting expertise, though.
                  Perhaps just check the other small ceramic caps for short circuit. If none, I don't know what else to suggest.
                    @momaka
                    will check all the caps and let you know.
                    Thanks for now.
                    Regards!
                    Leo
                      Everything about my fix of 2693HM you can find in this thread
                      OncleOh asked me if I can measure the testpoint from my working t-con board. Here are the calues of the working one.
                      Name of Testpoint Voltage / Resistance to GND
                      VDDG 27V / 100k
                      VEEG -7V / 41,5k
                      VDDA 13V / ~5,5k (it seems that the TP is connected to any C which charged while measuring)
                      I hope it will help anyone to fix much more 2693hm!
                      Regards from Germany
                      Chris
