Samsung Synchmaster 2693HM WHITE SCREEN
+ More Options
Posts
  • OncleOh
    • Dec 2011
    • 16
    i have a samsung 2693HM with white scren when it powers off, already replaced all caps on the power board and still the same result, cheched the fuses on T-CON board and all ok.
    Is it possibel taht the inverter board is bad, i changed the caps on the inverter board too?
    Regards!
    Leo
  • PlainBill
    • Feb 2009
    • 7034
    Re: Samsung Synchmaster 2693HM WHITE SCREEN
    Regards!
    Leo
    No. If the inverter wasn't working you would have a black screen.
    Triple check the seating of the cable from the signal board to the tcon, and the flex strips from the tcon to the panel. If there is a separate power cable to the tcon check that too.
    PlainBill
    PlainBill
    • OncleOh
      • Dec 2011
      • 16
      @PlainBill
      Already checked all the cables all seem ok, have to check voltages.
      Any other idea?
      Regards!
      Leo
      • OncleOh
        • Dec 2011
        • 16
        forgot to mention that after white screen it goest to black (white faids to black)
        Would the pictures of the boards help?
        Regards!
        Leo
          master hoarder
          • May 2008
          • 12170
          I had a monitor with those same problems before. Like yours, the fuse on the t-con was good. Problem turned out to be a shorted tiny ceramic cap the secondary boosted rail on the t-con board. Fairly easy fix.
          Your monitor's t-con is probably very different from mine, but if you just want to get an idea of the problem, you can find my thread here:
          https://www.badcaps.net/forum/showthread.php?t=12210
          Yes, very much!
          You should be able to spot a round inductor on your t-con. The area of interest on the t-con is usually around that inductor. I suggest you take several pictures: one of the whole t-con board, and several close-ups of the area around the round inductor.
          Also, as a very primitive test, power on the monitor and see if anything gets hot on the t-con board, especially any ICs and diodes in the area of the round inductor. You may have to cycle the power to the monitor on and off a few times for this. Be careful, as components can get hot very quickly if there is a fault. Let me know if you find any that do.
          • OncleOh
            • Dec 2011
            • 16
            Here are the photos of the PSU.
            Note that all the caps on the PSU except the big one are changed.
            Regards!
            Leo
            • OncleOh
              • Dec 2011
              • 16
              T-con board.
              Regards!
              Leo
              • OncleOh
                • Dec 2011
                • 16
                T-con board right side. Previous picture was left side.
                Regards!
                Leo
                • mockingbird
                  • Dec 2008
                  • 5484
                  Yikes!
                  Did you use Jamicon as replacements?
                  • OncleOh
                    • Dec 2011
                    • 16
                    @mockingbird
                    Why Yikes!
                    I used 105degre ones , have to check.
                    So what do you suggest about t-con board?
                    Regards!
                    Leo
                    • trebo
                      • 514
                      • Wales, UK
                      hello all
                      was looking back on the first post and oncleOh said
                      (Hi i have a samsung 2693HM with white screen WHEN it POWERS OFF
                      I remember on the old Benq boards the INVERTER transistors and sometimes the FU90?? mosfets use to fail,
                      if you replaced the transistors and had not spotted one of the FU90?? mofets had failed,
                      then the monitor would work but when you powered off, the screen would stay on with a white screen untill you removed AC
                      dont know if this applies to this monitors inverter in some way, but thought I would mention this as it may help those of you who do know
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Originally posted by trebo
                        hello all
                        Good catch. Most monitors in this size turn off the main power supply and the inverter, but better pictures would be required before I could be sure of that.
                        Edit: that appears to be the case here. That would imply either a short on the power supply, or a problem on the signal card.
                        PlainBill
                          master hoarder
                          • May 2008
                          • 12170
                          Short version:
                          Using the picture in post #8 as a reference (this one), first find the 3 test points AVDD, VEEG, and VDDG.
                          AVDD is located under the bank of ceramic capacitors under the round inductor.
                          VEEG and VDDG are located all the way on the right side of the t-con where the "260WU01C" and other board numbers are.
                          Once you find those test points, measure the resistance of each to ground. If you have a manual multimeter, use the 2000 Ohm scale. If you have an auto multimeter, disregard any readings above 2000 Ohms.
                          Basically we are looking for a short circuit or very low resistance on these test points. If any of them measure less than 200 Ohms, post what resistance you got here. I consider anything under 100 Ohms as suspicious, 30 Ohms or less as highly suspicious, and 10 Ohms or less a very likely short circuit.
                          Also, check the ceramic capacitors around D502, Q503, and Q504, and D504 for short circuit/ low resistance. To do that, just measure the resistance across them. If you find any of them to show under 100 Ohms, let me know which ones.
                          Long Version (only for those interested in more info on this t-con board:
                          Background
                          There are 4 important voltage rails on a t-con board:
                          - the main supply rail, which is usually 5v
                          - the main step-up (boosted) voltage rail, usually 9 to 13v (derived from the main supply/ 5v). For this t-con board, test point AVDD is directly connected to this voltage rail.
                          - two secondary step-up rails (derived from main step-up) for turning the transistors in the TFT ON and OFF. For this t-con, test points VEEG and VDDG are directly connected to these rails.
                          A white screen problem usually happens if either the t-con is not receiving power (main supply rail not present) or one of the TFT voltage rails (the step-up rails) on the t-con board has a fault. The fact that the screen fades to black after being white suggests that the main step-up is working but one of the secondary ones isn't.
                          More often than not, the cause for this is a shorted ceramic capacitor on one of those rails. And that's what we're going to look for. Of course, first those rails need to be found on the t-con board.
                          Let's start with the picture of the t-con on post #8.
                          The round inductor is always easiest to spot (IMO). This inductor is part of the main step-up voltage rail. Once located, the secondary step-up rails can be usually found close by. Next, we find the controller that produces these rails. For this particular t-con, the controller is a MAX8795A "smart" IC from MAXIM. Data sheet here:
                          A basic sample circuit diagram is given on page 1, and a more elaborate one on page 15. Page 13 has a table that describes the functions of each pin on the controller.
                          In many cases, the circuit on the t-con will closely resemble the sample circuits given in the data sheet. In the data sheet above, the t-con TFT rails are referred to as Vmain (for AVDD), V_GOFF (for VEEG), and V_GON (for VDDG).
                          As can be seen from the sample circuits in the data sheet, these rails have caps connected to them for filtering. Normally, the t-con board uses ceramic caps for these. The problem is that ceramic caps like to short circuit when they fail, so when one of them fails, it brings down the whole TFT power supply section.
                          All one has to do is follow the sample circuits in the data sheet and then try to determine the corresponding components on their t-con board. This is useful for checking resistances.
                          • OncleOh
                            • Dec 2011
                            • 16
                            @momaka
                            will check and let you know,
                            @PlainBill
                            which photos do you need?
                            Regards!
                            Leo
                            • PlainBill
                              • Feb 2009
                              • 7034
                              @momaka
                              @PlainBill
                              Regards!
                              Leo
                              None. momaka has specified a process that should identify the problem.
                              PlainBill
                              • OncleOh
                                • Dec 2011
                                • 16
                                finaly managed to get the readings, used autorange multimeter set to kilo, and all ok except VDDA reads 5,90K.
                                Have to get another multimeter and repeat the measurments.
                                Regards!
                                Leo
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  5.9 kOhms (5900 Ohms) is actually fine. It's the low resistances (in the 10's of Ohms) that we are looking for as those usually indicate a problem. Like I mentioned, disregard any resistances *above* 2000 Ohms (2 kOhms).
                                  What resistances did you get for VEEG and VDDG?
                                  • OncleOh
                                    • Dec 2011
                                    • 16
                                    @momaka
                                    at VEEG and VDDG i got 0, no reading at all.
                                    Regards!
                                    Leo
                                      master hoarder
                                      • May 2008
                                      • 12170
                                      @momaka
                                      0 (zero) and no reading are NOT the same thing!
                                      Most multimeters will show "OL" or a "1" on the left side of the screen if you set them to measure resistance and you leave the probes not connected to anything. The "OL"/"1" means "out-of-range" reading. On the resistance setting of a multimeter, this means that the resistance you're trying to measure is higher than the scale you selected. So for example, if you have a manual multimeter and you set it to measure a resistor on the 200 Ohm scale but the resistor is 400 Ohms, then the multimeter will show that "OL"/"1" reading.
                                      A zero on the other hand, as in 0.00 Ohms, means short circuit.
                                      Do this test for me... set your multimeter on the lowest resistance setting (only if it is a manual one, of course) and touch both probes together. The resistance you get for that setting is the SHORT-CIRCUIT resistance for your multimeter. Whenever you get this reading at this scale on your multimeter, then that's when you have a short circuit or a very low resistance. Good multimeters will show around 0.6 to 0.8 Ohms. Cheap ones will show around 1 or 2 Ohms.
                                      Now check VEEG and VDDG using the lowest resistance setting on your multimeter and tell me what you get.
                                      • OncleOh
                                        • Dec 2011
                                        • 16
                                        Sory for the delay,
                                        here are the reading but think they are ok:
                                        VDDA 5,9k
                                        VDDO 1,5k
                                        VEEG 41k
                                        VDDG 100k
                                        Regards!
                                        Leo
                                        • harp
                                          White screen repairs
                                          by harp
                                          To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                          Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                          On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                          05-13-2024, 03:43 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • aczelkri
                                          Samsung LE37B650 white screen
                                          by aczelkri
                                          Hey guys,
                                          I have a Samsung LE37B650 screen with the following symptoms:
                                          - Image suddenly turned into almost completely white while I was watching a movie. I can make out some details, but they are very faint. There is definitely an image there, but very very bright and maybe inverted colors.
                                          - If I unplug the cable between the main panel (that has all the video in-out ports) and the tcon board (T315HW02 V3 CTRL BD 31T06 C03), the screen is black as normal (there is backlight and it is masked by the pixels), but of course there is no actual...
                                          10-14-2020, 05:10 PM
