Westinghouse L2046NV 2 seconds to black
  • Mr Bill
    • Nov 2011
    • 648
    I got this monitor from the trash. 2 Caps failed so i recapped the entire board with panasonic fm caps (same valued). Turned the monitor back on and i still have the same symptoms. I did shine my flashlight on the screen and the picture is still there just no backlight.I've been trying to test the MOSFETS but i am not sure i am doing it correctly. If i put the leads on the the mosfet pins as per Retired caps's guide, i get a brief flash of a number then OL. I'm using a craftsman 82141 multimeter. I did check the 2 fuses on the inverter side of the power board and i am getting .3 ohms, so i am assuming they are ok. I checked the diodes on the board and they appear to be ok, (value one way and OL the other).
    The MOSFET is 40T03GP
    I've read in a few older posts that they do fail. If someone can chime in on the testing procedure. Or if i need a better multimeter to perform this test.
    I am a little confused on the transformer check also. The guide says check pins 1-2 1-3 1-4.....Is this from top to bottom on either left or right side??
    If anyone has any suggestions as to what to check or input on the mosfets i'm all ears.
  • jayoung
    • May 2011
    • 172
    Re: Westinghouse L2046NV 2 seconds to black
    You said you still have the same symptoms - What are the symptoms?
    • retiredcaps
      • Apr 2010
      • 9271
      Odd for a manual ranging multimeter to display "0L". Most manual multimeters display "1" on the left hand side to indicate out of range.
      Anyway, it sounds like the mosfet is not shorted. However, it still could be bad. You can perform another test following
      http://www.4qdtec.com/mostest.html
      Please circle the 2 fuses. The flash on the picture makes it difficult to identify them. Also on this board, there may be a hidden fuse underneath the glue. If the PCB designator starts with a "F" that is a fuse.
      Your multimeter is fine.
      It doesn't matter how you number them because it tests every possible combination to identify which are the secondary pins. Your inverter transformer starts with 2874. If you look at
      http://www.lcdparts.net/T.aspx
      there are two part numbers with 2874. Both show that the outer corner pins are the secondary pins. So measure the resistance between S1 and S2. Do the same for S3 and S4. Report both numbers. An example,
      http://www.lcdparts.net/TransformerD...ProductID=3359
      --- begin sig file ---
      --- end sig file ---
      • retiredcaps
        • Apr 2010
        • 9271
        I'm assuming 2 seconds to black as per title. And he can see image with flashlight.
        • alexanna
          • Mar 2010
          • 1346
          Just to make sure you checked the corect fuse for the inverter,it's F200 on the back side of the board.
          • Mr Bill
            • Nov 2011
            • 648
            Originally posted by retiredcaps
            Odd for a manual ranging multimeter to display "0L". Most manual multimeters display "1" on the left hand side to indicate out of range.]
            Your right, i was typing faster than thinking
            I measured s1-s2 and s3-s4, i'm getting a brief flash again (nowhere near 610) then "1". I also measured p1-p2 &p3-p4 for giggles and i got .3 ohm
            As for the MOSFET i checked the 2 40T03GP, the one i get nothing, just 1. On the other i'm getting 733 between the source and gate. But when i put my finger between the leads it doesn't change.
            Here is the pic of the 2 Fuses that i can find on the inverter side (F100, F101) I can zoom in on that particular area with the flash off if you would like.
            • Mr Bill
              • Nov 2011
              • 648
              I missed that one. Took a few minutes to find it. I'm getting .3 ohm
              • retiredcaps
                • Apr 2010
                • 9271
                Hmm, I knew something was funny about this board. I think you spotted that last year too!
                • Mr Bill
                  • Nov 2011
                  • 648
                  i just checked the S1-S2 and S3-S4 on the inverter transformer with another meter (craftsman 82040 auto ranging meter) and i am getting 739 ohms on S1-S2 and 736 on S3-S4. 000.0 on P1-P2 & P3-P4.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    What did you have your multimeter set to? Did you set it to 2000 (two thousand) Ohms?
                    The primary winding rarely fails.
                    I have never tested mosfets using the other method so I can't tell you if the readings are right or not. In addition, if you tested the mosfets "in circuit", you may not get reliable readings.
                    There are still the ccfls and/or wiring along with the secondary inverter transformer that need to be checked.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      With manual range multimeters you have to get the range correct otherwise you get "1" or out of range. With those two readings, we can assume that the inverter transformer is good and move on.
                      • Mr Bill
                        • Nov 2011
                        • 648
                        I think the range was set to 200ohms on my meter. I retested the MOSfET and i'm getting 12.31, then i put my finger over the leads and it drops to 8. On the other it climbs to 40.12, then it drops to 2.2-2.3 I'm still using the auto range meter.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          I suggest moving on to check the ccfls and its wiring. If you have a spare ccfl (doesn't matter what size), this test shouldn't take too long.
                          Luckily for you, alexanna is the king of ccfl wiring repair and can offer many suggestions.
                          See the following for examples of bad wiring or burnt out ccfls.
                          http://s807.photobucket.com/albums/y...klight%20lamp/
                          • alexanna
                            • Mar 2010
                            • 1346
                            Just to make sure I understand your problem, do you see a brief flash of the backlights?
                            • Mr Bill
                              • Nov 2011
                              • 648
                              yes, The monitor displays for 2 seconds then goes black. You can shine a flashlight on the screen and the images are there. how involved is it to remove the ccfl for inspections?
                              • alexanna
                                • Mar 2010
                                • 1346
                                Don't disassemble just yet.
                                Let's call the CCFL connectors “Top” and “bottom”
                                Unplug the top connectors; do the bottom CCFLs light briefly? Repeat with top plugged in and the bottom unplugged, do the top CCFLs light?And dose everything look the same top and bottom
                                • Mr Bill
                                  • Nov 2011
                                  • 648
                                  There is 4 connectors for this montor. I plugged in the 2 going to the top and it lit up "no signal". I then unplugged the top and plugged in the 2 for the bottom and also lit up "no signal". As for the top and bottom it looked the same, brightness ect ect. It also os still doing the 2 seconds to black condition.
                                  • alexanna
                                    • Mar 2010
                                    • 1346
                                    How easily would it be to come up of a pair of known good CCFLs?
                                    These could be from another monitor/panel; there would be no need to disassemble anything.
                                    • Mr Bill
                                      • Nov 2011
                                      • 648
                                      I do have an I-inc 19" monitor i bought back in 2007. It still works. I got a 32" tv i'm using as my computer monitor now. What would i need to do?
                                      • alexanna
                                        • Mar 2010
                                        • 1346
                                        Before we disassemble anything there are some mor things we can check.
                                        I am going to attach a schematic of the DCA19m-005 monitor/inverter.
                                        there are some pins on the back light controller you could verify are good.
                                        give me a moment to make some suggestions.We need to verify power/grounds and a back light on signal.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • pandrew
                                          Thinkpad T490 doesn't detect NVME
                                          by pandrew
                                          I have a Thinkpad T490 (NM-B901 Rev 1.0) that cannot detect an NVME M.2 SSD,
                                          but it works fine with a SATA M.2 SSD.
                                          When connecting an NVME M.2 SSD I get while booting:
                                          "2101: Detection error on HDD0 (Main HDD)"
                                          I can continue and boot a live linux distro from a USB stick, but it doesn't show up in lspci,
                                          and I don't notice any relevant error messages in dmesg.
                                          I have tried two different M.2 NVME SSDs (both working fine on a different machine),
                                          and the behavior is the same.
                                          I am pretty sure that all the important...
                                          11-13-2023, 03:04 PM
                                        • twonk9098
                                          Lenovo Legion 5 high fan spin turns off after 34 seconds
                                          by twonk9098
                                          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                                          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                                          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                                          I have tried a few new bios but exactly...
                                          07-14-2024, 11:19 AM
                                        • Spoonicks
                                          Samsung 2233SN no CFL backlight
                                          by Spoonicks
                                          Have a Samsung 2233SN with no CFL backlight. Testing with a flashlight, I can see the image is displayed, but the backlight fails after some seconds.
                                          Sometimes, after being off for a while, the backlight will remain on for a couple minutes, but most of the times it fails immediately.
                                          I tried to follow the guide present in this forum, but so far I haven't de-soldered any components. I need some advice on how to proceed to diagnose this display.
                                          Following the guide I tested the following:
                                          The transformer...
                                          07-01-2023, 11:10 AM
                                        • corrize
                                          Where to find a very small fpc connector 0.3mm between 2 pins ?
                                          by corrize
                                          Hello, I search this connector (oxydated).
                                          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                                          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                                          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                                          Do you know how to find this connector please ? What is the exact name for find it ?
                                          08-06-2024, 05:25 PM
