syncmaster 913n flickering led
+ More Options
Posts
  • onejay09
    • Nov 2011
    • 67
    I got given this monitor by my brother who got given it from someone else, so im not sure how the monitor failed, ive replaced all the medium and large caps with new ones low esr, i matched the voltage and fareds too, ive resoldered all the pins on the board too, ive checked the diodes with my dmm also.
    but its led is still flashing rapidly,
    theres no heat from any components when power is in no funny noises or smell or smoke whitch is good but means i havnt found whats wrong
    Any advice would be appreceated.
    im new here from uk
  • jetadm123
    • 2169
    Re: syncmaster 913n flickering led
    im new here from uk
    Welcome to the forum! Just a few words of advice:
    1) Picture are ALWAYS welcome, but they need to be in focus and it's better if you take a overhead photo of the top and bottom of the board as members cannot see through components of photos taken at an angle.
    2) It's good that you replaced caps, but you should have also replaced the small ones. I see at least one capxon cap that's pure junk and should have been replaced. One small cap is generally used in the power supply startup process. If you had replaced all the caps, then we would have had a good starting point.....
    • onejay09
      • Nov 2011
      • 67
      Thanks, and sorry about the pictures, i did take one of top and bottom and made sure they were clear i must have uploaded the wrong ones, its my fault i posted them via android mobile. I am planning to replace all of the caps i just thought id wait and see whether the new caps would solve it first, the caps are on there way so hope they get here soon. Yes i read somewhere that one small one is the startup cap but i was also told the big caps rarely fail,
      So do you think it is the other caps that need changing too?
      thanks
      Jamie
      • onejay09
        • Nov 2011
        • 67
        Heres the other pic it wouldnt upload before
        • jetadm123
          • 2169
          thanks
          Jamie
          You can generally leave the 450V cap alone as that rarely fails. All other caps (including the small ones) should be replaced with low-esr caps.
          • retiredcaps
            • Apr 2010
            • 9271
            1) On connector CN201, there is a legend. List each pin and its legend.
            2) With a multimeter, measure each pin on CN201 with respect to ground. List the DC voltage readings along with the expected value.
            3) We also need a clear focused picture of the main/logic board.
            --- begin sig file ---
            --- end sig file ---
            • onejay09
              • Nov 2011
              • 67
              Sorry im still learning all this, i understood what u meant about cn201 but what legend? Do u mean measure voltage on each pin on the ribbon going to the other board?
              • retiredcaps
                • Apr 2010
                • 9271
                Legend. See
                https://www.badcaps.net/forum/attach...3&d=1303127782
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Yes. Put your multimeter on 20V DC (if manual ranging). Put your black probe on a ground screw closest to the connector. Put your red probe on each pin and report it like
                  Pin # - Legend - Reading
                  Pin 1 - 5V - 4.98
                  Pin 2 - GND - 0.0V
                  • onejay09
                    • Nov 2011
                    • 67
                    Right i thought so thanks
                    Pin 1 red- 10.0v +13v
                    Pin 2 blk- 10.2v
                    pin 3 blk- gnd
                    Pin 4 blk- gnd
                    Pin 5 blk- gnd
                    Pin 6 blk- 1.6,1.7v +5v
                    pin 7 blk- 1.6v
                    pin 8 blk- 1.5v
                    pin 9 blk- 0.7,0.6v on/off
                    These were with the other board plugged in hope thats right
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      Pin 2 blk- 10.2v
                      pin 3 blk- gnd
                      Pin 4 blk- gnd
                      Pin 5 blk- gnd
                      pin 7 blk- 1.6v
                      pin 8 blk- 1.5v
                      1) Hmm, all those readings are way off to what is the legend states (if that is the last column).
                      10V is way off from 13V. 1.6V is way off from 5V.
                      2) Let's rule out the multimeter first as being possibly bad. A weak battery or poor test leads will lead to inaccurate readings.
                      a) Take a fresh akaline battery (say AA) and measure it. For a fresh battery, I think you should get 1.6V DC.
                      b) Put your multimeter on 200 Ohm scale. Touch the 2 probes together. What do you get?
                      3) A picture of your multimeter will also help.
                      • onejay09
                        • Nov 2011
                        • 67
                        I get a reading of 0.01 to 0.02 ?
                        i get 1.5 vdc from battery
                        the dmm is about 2 weeks old, i havnt got it to hand right now for a photo sorry
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          Your multimeter appears to be working correctly given the above readings.
                          Let's try this. Disconnect the logic/main board. Leave the ccfls plugged in. Re-measure all those connector pins and report the readings.
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            The small caps that you didn't replace all play an important part of the entire SMPS application. Depending on your voltage readings with the main board disconnected, you may be asked to get replacements for them especially if the caps are Capxon brand.
                            • onejay09
                              • Nov 2011
                              • 67
                              Hi just measured voltages without the video board plugged in
                              1 13.14v
                              2 13.14v
                              3 0v
                              4 0v
                              5 0v
                              6 5v
                              7 5v
                              8 0v
                              9 0v
                              so does that mean a short on the other board ?
                              • PlainBill
                                • Feb 2009
                                • 7034
                                1 13.14v
                                2 13.14v
                                3 0v
                                4 0v
                                5 0v
                                6 5v
                                7 5v
                                8 0v
                                9 0v
                                Maybe, but there is another possibility. There are 5 small caps - C103 C105, C204, C33, and another net to R101 whose component number is obscured (C104?) Were those replaced?
                                PlainBill
                                • onejay09
                                  • Nov 2011
                                  • 67
                                  No i havent replaced them yet the parts are on their way, should be here in a few days. So would they cause an issue with the voltage drop?
                                  also should the voltage from big cap be steady or fluctuating?
                                  Should it be changed also?
                                  • onejay09
                                    • Nov 2011
                                    • 67
                                    Those caps are
                                    50v 47 uf
                                    35v 47uf
                                    50v 22uf
                                    50v 4.7uf
                                    Ill post the results when i replace them
                                    thanks
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      The voltage on the big cap should be steady.
                                      The short story is I spent hours troubleshooting a Samsung TV/monitor that would try to start up, and fail. It didn't have a power led, but the speakers would click every second or so. After a LOT of troubleshooting I discovered that the startup cap in the external power supply was bad. The funny thing was I had tested the supply at about 2 1/4 amps load. The supply was rated at 4 Amps, the TV/monitor drew about 3.
                                      PlainBill
                                      • onejay09
                                        • Nov 2011
                                        • 67
                                        It seems that my thoughts turned out to be right in the big cap fluctuating ! :-) I replaced it and it started right up ! Whoo, only to find that when me and the ex fell out the other day shed taken her anger out in the LCD panel ! She did a his job in it too :-(. So now am selling the power board and video board anybody in Lancashire UK area is welcome to PM me
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • Jaysean
                                          Acer VN7-591G-70RT Display Flickering
                                          by Jaysean
                                          Hello Badcaps coummunity hope you all are having a bless day,
                                          Hope I didn't post it wrong kinda new at forum site rules and tradition
                                          So I'm dealing with screen flickering problem on my laptop.
                                          I'm not quite sure if it's the display cable or the screen itself that's causing the issue,
                                          so I'm turning to you all wonderful expert on Badcaps for some guidance. Your help is much appreciated!
                                          [Screen Flickering](https://i.imgur.com/xK9vHqc.mp4)
                                          [HDMI port to external display seem to work be working](https://i.imgur.com/snSC24e...
                                          10-27-2023, 10:22 AM
                                        • arctor
                                          LG 55uh661v flickering images and lines
                                          by arctor
                                          Hi, I have this tv a LG 55UH661V that show flickering images and lines. I tried to take off one at time the right and the left ribbon cable and put the tape for ask the pin…but nothing working. Or I stop to have picture or still flickering. Someone can help me to understand what pin I have to mask? What I notice the buffering board, the flat cable becomes very hot, I don’t think it s normal, I’m talking about the orange flat cable soldering on the buffering board, both side are very hot. I give you the photo with both the ribbon cable on and a photo with the right off and with the lefts...
                                          06-16-2025, 11:57 AM
                                        • Adenitz
                                          Cutting the jumper on Samsung TV to solve the flickering
                                          by Adenitz
                                          Hello to all,
                                          I have just seen this YT video about solving flickering issue on SAMSUNG TV. Reading many comments it seems this works.
                                          But I wonder what is done here and how this solved the issue. I'm not able to find the schematics so cannot explain to myself.
                                          Few years ago I had a flickering problem on one monitor in some factory which I managed to solve by inserting UPS between monitor and power outlet. I also notice on this occasion the flickering was gone if I put insulation tape on the power plug like shown in the attached picture to remove connection with the PE conductor...
                                          01-06-2024, 12:20 PM
                                        • survivalbloke
                                          HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                                          by survivalbloke
                                          SN: 8CG0213H8W
                                          ProdID 3C311UA
                                          This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                                          05-08-2025, 12:21 PM
