Inverter or Backlight?
  • ShadowReaper
    • Aug 2008
    • 6
    a friend of mine dropped his laptop and he has a problem with the screen. It appears to function normally except that it's very very dark...
    I tried the tv-out and it functions properly, so the problem is either the inverter or the Backlight.
    Since I do not have a spare Backlight to test it, is there any other way to find
    which of the two malfunctions?
    Thank you
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Inverter or Backlight?
    Step 1:
    Locate brightness control and see if it changes anything.
    The fall may have inadvertently adjusted it.
    If that isn't it then it's hard to say which is bad without taking it apart.
    An inverter circuit board is less likely to be damaged by a drop than a glass tube.
    The screen may have more than one tube and only one tube is out.
    Might also be that a brightness control wire to the inverter came loose although I don't know if that method is used in this particular laptop.
    Mann-Made Global Warming.
    - Dr Seuss
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      I would say inverter cable came loose. I had acouple of HP laptops do this, since they forget to put a little sticky tape to hold the cable in place.
      • ShadowReaper
        • Aug 2008
        • 6
        I wouldn't say that the cable came loose... I opened it and checked it.
        By brightness control you mean the software?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          No I mean the IC chip that is operated either by a switch, a combination of switches, and/or some software.
          Some laptops have the chip in the chassis with wire[s] running to the inverter in the lid.
          With others it's built right into the inverter.
          - Dr Seuss
          • kb48
            • Nov 2011
            • 14
            99% of time it is the inverter, due to usually liquid spill or just the transformer or ceramic/polymer caps die on the inverter.
            Simple test, take and unplug the FL lamp from the inverter, take a clip lead ground it to the notebook hinge, and turn on notebook. Carefully bring the other end of cliplead near the plug of the FL lamp (white or pink wires). and if it draws a spark or arc then inverter ok. Have to do this when first turned on, as the inverter will just shutdown otherwise.
            Using meter carefully proble the other plug, to verify it is getting voltage, usuallyu 5V and also usually 9 or 12 volts. There are also PICO microfuses on the inverter, that may be open. They are white surface mount devices.
            IF the FL tube has aged out, or cracked then you would also get same symptoms.
            If cracked it may arc over from the inverter board to ground. The FL tubes last a long time, but if either goes bad, the inverter is designed to shut down.
            For may HP newer laptops these are very reasonably priced, at $40 or less, I got one for an HP for only $17.50 with free shipping.
            Don't try to fix the inverter that is a waste of time.
            Too delicate to repair.
            Also if the transformer goes bad, it can burn a hole in it as well.
            • kb48
              • Nov 2011
              • 14
              Also something simple to check but make sure the lid switch is not stuck. I had this on an older notebook, to cause backlight to shut off. Usually t will also cause system to enter standby mode as well.
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
              • jimbofz
                lg 32LC46 backlight inverter board fault
                by jimbofz
                Hi this oldie had no backlight .after replacing caps on 24v rail ,
                still no b/l this uses inverter type:1315 B1-16A,
                im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                this allows protect to be temporary overridden.
                b/l now comes on
                but the left hand side of pic is gradually darker than the right side
                i have the cct for the tv
                but it does not have inverter cct.
                i opened it up to inspect the ccfl tubes
                and they dont have any...
                12-19-2021, 06:58 AM
              • cheebster
                iPad Pro 12.9 5th Gen Backlight Issue
                by cheebster
                Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                Anyone...
                05-20-2025, 09:17 AM
