Asus VE205 .... 2seconds to black
  • Welchs101
    • Sep 2008
    • 979
    Hi, its been a while since i did any kind of repairs..........but a neighbor has a monitor that is not working and they asked me to take a look at it.
    its an ASUS VE205. You turn it on and it onlly stays on for about 2 seconds.
    I have taken pictures of the boards. I took front and back pics of the power supply/ inverter board.
    Any ideas? The caps look ok to me.......but i know that sometimes "looks" are not every thing.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Asus VE205 .... 2seconds to black
    Does the power light stay on?
    PlainBill
    • Welchs101
      • Sep 2008
      • 979
      I know the led light turned on "blue" but i am not sure if it stayed on the entire time. THe led light on this lcd is in a weird position.
      I have the monitor apart right now but i need to put it back together to test if the led light let me know. Again, i know the light came on because i commented on the "Blue LED" light looked nice.
      • PlainBill
        • Feb 2009
        • 7034
        It's really simple - one of the first tests should be to note if the power LED stays on when the screen goes black. If it does, that suggests 'two seconds to black'. If it does not, it suggests a problem with the signal card.
        PlainBill
        • Welchs101
          • Sep 2008
          • 979
          i put the lcd back together enough to check the led.
          When i power the monitor on the led turns on and is a blue color. I see a flash ....i can see image on screen.........it goes away almost instantly........once it goes away the blue led turns "orange" but stays on it does not go out.
          does this answer the question?
          • PlainBill
            • Feb 2009
            • 7034
            To a certain extent. It says the power supply isn't shutting down. Is the monitor hooked to a working computer?
            PlainBill
            • Welchs101
              • Sep 2008
              • 979
              when i first tried the monitor it was hooked to a working computer. the screen would flash and then go out. for the led test i reported on previously it was not hooked to a wokring computer. i will connect it and then report back.
              • PlainBill
                • Feb 2009
                • 7034
                It's beginning to sound like 'two seconds to black'.
                PlainBill
                • Welchs101
                  • Sep 2008
                  • 979
                  ok, reconnected computer to monitor
                  powered on computer
                  powered on monitor
                  LED light comes on as blue and stays blue..........screen will flash with computer desktop but then goes blank...........even after monitor goes blank LED light is blue.........
                  • alexanna
                    • Mar 2010
                    • 1346
                    Troubleshoot “2 seconds to black”
                    • Welchs101
                      • Sep 2008
                      • 979
                      transformer tests: (see enclosed pic for labeling)
                      1 to 2: 0.448 Kohm
                      1 to 3,4,5,6,7,8: open
                      3 to 4: 0.3 to 0.4ohm
                      3 to 5: 0.3 to 0.4ohm
                      3 to 6: 0.3 to 0.4ohm
                      3 to 7: 0.3 to 0.4ohm
                      3 to 8: 0.3 to 0.4ohm
                      NOt sure if the above readings are good or bad for transformer
                      IC: alphaomega 4614
                      https://cdn.badcaps-static.com/pdfs/...0e94bf963c.pdf
                      1 to 8: 3meg ohm
                      2 to 8: 3meg ohm
                      3 to 8: 3meg ohm
                      4 to 8: 3meg ohm
                      1 to 2: 10kohm
                      3 to 4: 5kohm
                      Not sure if these are good readings.....i think so but not sure
                      thoughts?
                      • alexanna
                        • Mar 2010
                        • 1346
                        Looking at pictures and telling you what pins to test is something i am not very good at.
                        It is exceptionally difficult with the pictures you provided, a better picture would be one straight down showing the entire board, please try to use natural lighting.
                        I THINK the secondary's are you're numbered pins 1 and 3 and numbers 2 and 8
                        • Welchs101
                          • Sep 2008
                          • 979
                          i am enclosing two pics of the back side......both pics together show the entire back side........i also show the pins on the transformer.
                          • alexanna
                            • Mar 2010
                            • 1346
                            Well my eyes saw it in the very first picture,but i guess my mind didn't let me believe it.
                            This monitor looks like it's only using 2 CCFLs.So it looks like you measured the correct pins.The problem is we don't have anything to compare the reading to.
                            • Welchs101
                              • Sep 2008
                              • 979
                              Yes, your correct. it only has two bulbs in it as far as i can tell.
                              Does not look like a good monitor but i did not want to tell my neighbors that.
                              • alexanna
                                • Mar 2010
                                • 1346
                                Just because it's only using 2 CCFLs doesn't necessarily mean it not a good monitor.
                                Have you checked to see if the monitor will stay on with a different set of lamps?
                                • Welchs101
                                  • Sep 2008
                                  • 979
                                  good idea. I was thinking of trying that. Let me see what i have for spare parts. I had to do a bit of "house cleaning" few months ago and i had to get rid of a bunch of stuff.
                                  Any idea if the readings on the transformer are ok?
                                  • Welchs101
                                    • Sep 2008
                                    • 979
                                    i found a spare monitor with the same bulb-connections as the Asus. I plugged the bulbs from the ASUS into my test monitor and the test monitor lit up the ASUS bulbs with no problem. LIghts stayed on and did not flicker ........i left them on for about 30sec.......then shut down the test monitor.
                                    So i think the bulbs in the ASUS are ok.
                                    any other thoughts of things to try? again, are the transformer readings i posted ok..........
                                    • KalvinAlmeda
                                      • Nov 2011
                                      • 5
                                      I am in the same position. Any findings or info you have would be greatly apperciated. I imported it from the US and in Mexico where technology is 3x more expensive, I do not feel like trashing it.
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        if i figure anything out i will let you know and/or post it here for others to read.
