Re: Asus VE205 .... 2seconds to black
BTW, this isn't really an ASUS problem, its an LG problem (the maker of the panel). The part number of the panel is LM200WD1 TL C1 or LM200WD1(TL)(C1) or LM200WD1-TL-C1.
Hmmm. I just got one from a friend. I will have to check this. Hopefully that's the same problem.Leave a comment:
Yes, thanks I thought it smelled like a short.Leave a comment:
http://lcdparts.net/howto/selectccfl.aspx
http://lcdparts.net/howto/troublesho...sktopCCFL.aspxLeave a comment:
Update i replaced just the top cfl from lcd parts.net (quick shipping) and put it back together powered it on and IT WORKED wahoo. I will add that the bulbs are way fragile and putting all the layers to the panel back together and correct was not a task i enjoyed quite tricky but did it and have a happy friend with a working monitor. Thanks for this forum and all the helpful people hereLeave a comment:
That the burnt wire symptom, very common due to poor soldering workmanship.
I would inspect all the wires, also pull it slightly to see if it will come right out.
http://s807.photobucket.com/albums/y...klight%20lamp/Leave a comment:
I know this thread is old, but this info might help someone else. I just received this same monitor from a friend it had the exact same symptoms as this guy did. push the power button had a brief flash of the pc desktop then dark, with a flashlight the PC desktop is seen just no backlight, power button led stays blue, after reading thru this forum i came to the conclusion it must be a bulb or inverter issue so after taking the screen apart and looking at the cfl's i noticed where the cfl connects to the tube whoever assembled the screen missed putting the tape over the corner where the wires meet the bulbby about 1/8" inch but just enough to cause the wires to short to the case i included a couple pictures (not very good but you will get the idea) i am going to order the cfl from lcd parts.net $14.95 so a fairly cheap fix (I hope) if i do not wreck the thing putting it back toghether.Leave a comment:
it has been a while but i wanted to post an update. My neighbor gave me this monitor because it did not work. They bought a new one and let me keep this one so i removed the AO4614 devices from the circuit board to test them.
I removed both AO4614 devices.
I tested both using the link provided. In diode check mode.
For the N-channel device. I placed black lead on source and red lead on gate. I let it sit there for a few seconds. THen i placed red lead onto the Drain lead. The voltage measured 0.2V for a split second then decreased to almost zero. I reversed the leads and then did the same thing for the p-channel device.........same results.
I repeated the above process for the other AO4614 device and got the same results.
I guess this monitor is headed to the scrap pile unless someone has something else to try. I did want to provide an update in case this helps someone else.Leave a comment:
i could not find another DMM so i think i am just going to try and take the IC out.
I did have a question though. If it is bad...........i looked online to find a replacement and .........i couldnt find one.
I checked digikey but they dont have any all they have is a AO4612 but i am not sure this would work. Any ideas on where to find a replacement part?Leave a comment:
interesting........never thought about using another DMM. Let me see if i can find one............if that does not work then i may just ahve to remove the IC from the circuit.
thanks for the ideas.Leave a comment:
The AO4614 is a complementary pair of enhancement mode mosfets. What the big words mean is it contains one N-channel and one P-channel mosfet.
The test you are doing is for an N-channel mosfet; for a P-channel you would reverse the leads, and should get a similar result.
The fact that you get a brief reading on the first IC indicates it is working; there are several reasons you might not get a reading on the second IC, one of which is it may be defective. Another possible reason is the components driving the gate are turning it off quickly.
The best approach is to remove it from the circuit board and test. A second approach would be to rig up a tester which would allow you to maintain the voltage on the gate while checking the source-drain voltage. That could be as simple as a second DMM with diode test mode.
PlainBillLeave a comment:
is there some way to test it in circuit .........maybe while its powered on? To see if the device is working as it should?Leave a comment:
just maybe they need to be out of cct.Leave a comment:
hi,
ok. i followed the directions of the link.
on diode check mode:NPN device
On say one of the IC's i put the blk lead to the source S1 and then touch the gate G1 (red lead) for about 2 sec then place red lead onto the drain D1. The voltage reading starts out at ~ 2V then increases until i guess it maxes out the diode check meter at ~ 2.5V.
I then repeat this on the other IC-4614. However, on this one i can get a reading once i place the red lead onto the drain. I go back to the first IC and try and repeat the procedure and i cant get a reading. If i wait a while and repeat the procedure on the first IC i can sometimes get a reading like i did the first time. But i cant get a reading on the 2nd IC no matter what i do.
Is this the only way to check the IC? I dont read any shorts as best i can tell.
Have not checked P-channel devices yet.......wanted to make sure i was doing it correct first.Leave a comment:
Although the resistance readings look ok, they still do not confirm for certain if they are working.They are complimentary mosfets,and need to be tested to see if they do switch on and off.It may be worth a try doing that using the diode test function on your meter,hope the following helps, if you are not sure what to do.The system shown still applies to your mosfet drivers even though they are not 3 pin devices.
http://www.4qdtec.com/mostest.htmlLeave a comment:
by sgcampionHello,
Asus rog strix scar 17 G733QR
My Asus laptop started flickering from time to time and more and more in last months. First the screen was going black but sometimes if I moved the screen it would work again, other times I needed to plug/unplug the laptop or close and open the lid to make it work again.
In last days I see that if I move the laptop lid to about 45 degrees it will flicker or get white or black screen(it's random, sometimes white sometimes flickers etc). I was trying to troubleshoot it myself but seems like it's either the cable or the display....10-24-2023, 09:39 AM -
This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...09-07-2024, 02:50 AM
This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-07-2024, 02:50 AM
This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...09-07-2024, 02:50 AM
This specification for the ASUS ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year boardview and ASUS E510MA-EJ015TS 15.6" FHD Intel Celeron N4020 Processor 4GB 64G with M365 1 year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...09-07-2024, 01:30 AM
- Loading...
