Testing Repaired Monitors
+ More Options
Posts
  • killian6pk
    • Apr 2010
    • 502
    After getting a monitor running and hooking it up to a computer, how long should you let it run before being reasonably sure that it is going to continue running. Also is there any other testing to do, like turning it off and on several times, that will help insure that it is fixed and will stay that way.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
  • richb74
    • Nov 2010
    Re: Testing Repaired Monitors
    Killian,
    I usually test my monitors for a good hour just in case the panel has a bad lamp.
    Rich
    • alexanna
      • Mar 2010
      • 1346
      I let my repaired monitors run a good 24 hours,Letting them going to sleep and repeatedly waking them up.
      There are some repairs you just know everything will be OK and those are the ones that come back to bite you in the gluteus maximus.
      • retiredcaps
        • Apr 2010
        • 9271
        Same as above. In one of my early Benq board repairs, I didn't resolder the inverter transformer pins and 24 hours later, the picofuse blew again. I changed the picofuse and resoldered the inverter transformer pins and then ran it for about 1 week before I declared it "fixed".
        --- begin sig file ---
        --- end sig file ---
        • mariushm
          • May 2011
          • 3799
          I just give them to my sister or my brother to use them as second monitors on their computers for a while
          • killian6pk
            • Apr 2010
            • 502
            Thanks guys that was what I wanted to know. I have repaired 5 monitors and 2 of them would not come back on several days later. I had tested each one for a couple of hours. I hooked them back up to the computer to recheck them one more time and each would not come on. So I guess I need to be letting them run for a much longer period of time.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I think using them as a secondary monitor, or as the monitor for your workbench (if you have one) so that they get some real-world experiences before being sent back out to brave the wild world by themselves
              • PlainBill
                • Feb 2009
                • 7034
                It depends on the circumstances. Usually I go for a 24 hour burn-in, and test several resolutions and both input connectors if present. However, if this was a 'shotgun' repair - indeterminate cause, replace all caps, now it works, old caps are barely above spec for ESR, I opt for a much longer test time.
                I recently had one - a 17" Dell with 'two seconds to black'. I determine one CCFL is bad, replace it, let it run for 24 hours. No problems, so I button it up and put it on the computer my Grandson uses when he visits. A month and about 60 hours of use later it pops up 'two seconds to black' again. It made me glad I hadn't sold it!
                PlainBill
                • killian6pk
                  • Apr 2010
                  • 502
                  I understand fully. I have a Sharp that ran for several hours on my test computer. I took it off and prepared to try to sell it. Put it back on the computer to get a picture of it working and it would not come on. It was a really pretty monitor when it was running before its second death. I will exhume the body and try again to reinvigorate it, maybe it will live again.
                  • Amraks
                    • Nov 2011
                    • 725
                    I have my girlfriend testing one I just repaired, She don't know she is the test mouse shhh.
                    So far its running fine playing her farkle game.
                    • 999999999
                      • Sep 2006
                      • 774
                      Depends on what part failed. If it acted completely dead and was just bad caps, after replacing the caps and having it work immediately I feel pretty confident about the repair if it is still working after it gets up to steady running temperature, is turned off then back on again at that point.
                      Actually I feel that way about most repairs, but to put things in perspecitve if you have a power issue it can subject parts to excessive ripple/voltage, and that can cause any degree of damage that surfaces immediately, an hour later, a day or week or months later. Every minute it runs you decrease the chance it still has the problem but if a couple fail 3 days later that doesn't really suggest that 4 days, or double it to 6 days, has any significance as the *right* testing period to use. If it's a mission critical part you just get it working and sell it off as repaired, replacing it with new for the critical use.
                      An alternative view might be that test length depends on consequences if it fails again soon vs available time to test, workspace you can devote, etc.
                      • FALKLAN
                        Running Line Voltage and Integrating LED Pods - Automotive
                        by FALKLAN
                        Howdy everyone! I hope all is well where ever you are!
                        I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                        I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                        02-05-2025, 12:30 AM
                      • valvashon
                        Repair Success! Middle Atlantic UPS2200R-IP
                        by valvashon
                        Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
                        Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
                        02-06-2024, 12:54 PM
                      • rumpumpel1
                        ThinkPad X1 Carbon 4th Gen running only at 400 MHz
                        by rumpumpel1
                        Oberservation:
                        X1 Carbon 4th Gen runs very slowly. Task manager shows the CPU running at 400 MHz.
                        In rare cases (1 out of 20) it runs at normal speed.
                        It does so when running on battery or only with the charger.
                        When both are connected - charger and battery (50% charged) - the system switches between charger and battery once per second.
                        The laptop does exactly the same thing when running Windows or Linux, so OS level problems can be ruled out.
                        Flashing CleanME and a different BIOS made no difference.
                        Intel's XTU utility...
                        09-18-2023, 06:13 AM
                      • Kambi13
                        Samsung NP370E4K No backlight running on battery
                        by Kambi13
                        Hi all, need some help. I have a Samsung NP370E4K-KD2BR, which as a 5th Gen Intel CPU that works fine when running with the charger plugged in, but has soon as I remove it and it's running on battery the screen backlight goes off.
                        Tried different battery - no change
                        Tried different screen - no change
                        Removed the plastic film from the screen inverter and looked for pwm signal which as about 3.3v when running with the charger plugged in, when I take it off the voltage drops down to 2.232v, so my best guess is that the EC is not providing the correct voltage....
                        09-04-2023, 11:06 AM
                        Wise Wing F199 19'' LCD monitor - recapped
                        by momaka
                        Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                        I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                        When I saw the Craigslist post, I wasn't...
                        08-24-2020, 10:58 AM
